TPS6594-Q1: Is it other way to distinguish TPS659411 and TPS659413?
Part Number: TPS6594-Q1
Hi Team,
Customer use TPS659411 and TPS659413. The Silk screen are the same. Is it other way to distinguish them?
  • Amelie,
    The best way to distinguish them is the packaging material that they are shipped in. If the units are no longer with their corresponding packaging, then they should have unique lot trace codes on the top side marking between TPS659413 and TPS659411. You would need to follow up with TI to determine which lot trace code goes with which part number (varies by shipments).
    Nastasha
