Other Parts Discussed in Thread: LM5050MK-1EVAL, LM5051, TPS23521
Q1
At Figure 31 of the datasheet, since this is Vin=-48V case, VIN and Vout should be 0V and GND should be -48V as follows by right?
Q2
My customer does not understand well what the D3(SS16T3) is doing at Figure 31. Could you elaborate?
Q3-1
My customer would like to evaluate -48V case using LM5050MK-1EVAL.
In this case the flowing connections are correct?
Q3-2
Up to how much A current can this LM5050MK-1EVAL be used?
Since my customer replace the external FET by a much bigger one, you do not need to consider FET thermal performance.
K.Hirano
