BQ78PL116: Regarding Temperature measurement
Part Number: BQ78PL116
We are using BQ78PL116 for 4S1P battery pack configuration, I want to measure the temperature of each cell. I found from the data BQ78PL116 supports only diode based temperature measurement. Can I use NTC with the BQ78PL116? If not how can I use diode based sensor when the distance between the cells is high (conditions where  I cant use PCB for temperature measurement) lets say for calb batteries.
Thanks & Regards,
Uday Kumar Reddy
