Part Number: TPS54560B
Other Parts Discussed in Thread: LM5085, TPS54560
Can TPS54560B replace LTC3864?
Based on LTC3864 with 100% Duty Cycle Capability, I check the TPS54560B SPEC as the below,
It means TPS54560B also can work in Vin=Vout, and the output voltage will be stable?
Because our customer has a LAN by-pass circuit detects the output, so the output cannot drop voltage.ThanksLTC3864.pdf
Rock
