Hi Sir,
Pls kindly advise,
What is OCP current threshold of TLV62565?
Thanks, Ian.
Hi Sir,
Pls kindly advise,
Thanks, Ian.
Hi Ian,
TLV62565 uses the valley current limit, where the inductor current is monitored during Toff using the low-side FET. When the inductor current is above the low-side FET peak current limit (ILIM, LS), the off-time will increase until the low-side current is equaled to ILIM, LS (1.7A, typical). To prevent inductor saturation, the device has an additional high-side FET peak current limit (2.0A, typical). When the ILIM,HS is reached, the high-side FET is immediately turn-off.
For detailed explanation on valley current limit operation, please check the link below.
Excel
Hi Ian,
If you don't have further queries, I will close this thread. To re-open it again, feel free to post your question.
Excel
