Hello everyone,
I am attempting to determine the maximum output current for the LM317M across a range of input and output voltages.
Section 6.5 Electrical Characteristics of the datasheet provides the following information:
However, this information potentially conflicts with Figure 6 of the datasheet, which shows significantly higher output currents:
Manually computing the maximum output current via RθJA and power dissipation leads to more confusion:
Using this equation for I results in the following data table:
In summary, the Electrical Specification, Figure 6, and manually calculating maximum output current are all giving differing results. Which should I trust?
Thank you for your help!
Ryan
