Hi expert,
LM74700-Q1 was used in BMS for one customer. Now they have a issue for EMI;
When we test the EMI, there is a 50M noise for CE(Conduct Emission) around 200MHz. After read the datasheet of LM74700-Q1, there is a charger pump integrated inside. Could you share the inside block and frequency for charger pump? Thansk.
If you can't public the inside block diagram. You can send a Email to me. Thanks.
We also solved the EMI issue, we add a capacity like below, Is there any risk? Could you check it for us? I appreciate it if you can help. Thanks.
Best Regards
Songzhen Guo
