TPS25942A: Output current limitation
Part Number: TPS25942A
Hello expert,
I have question regarding TPS25942A.
I'd like to know about the source current limitation but datasheet said it is internally limited.
Do this mean internal power path can support above highest current which is limited by internal limiter regardless of any measurement condition?
Kazuki Kuramochi
  • Hi Kuramochi,
    The pins (dVdT, ILIM, IMON) have current sources internally and have limited values. Any OPEN/Short condition at these pins does not cause any problem to the device as the current is internally limited.
    Best Regards, Rakesh
