Other Parts Discussed in Thread: LM5164
I am using LM5010 to generate 12V/1A across output.
I have used Webench to generate following circuit:
And my final schematic is here after calculating Voltage divider resistor values as per datasheet:
I have followed layout guidelines to design PCB, but after It gives me constant 7V output, even if I replace R2 with 8.2kOhm and 10kOhm.
Another issue thing is how important is values of C3 and C6 for proper operation of circuit, as I am unable to verify their values using Multimeter.
Anurag
