Other Parts Discussed in Thread: LM74700-Q1
Hi team,
Could you please give some comment as below:
Customer wants to use the solution of disconnect VS (as 8.2.4 shows), as it can only reduce Iq, could you please tell the Iq of this solution? We want to confirm if there is leakage from In and Out pin.
In figure 29 of datasheet, D2 and D3 is used for reverse input voltage protection, could you please tell how to select diode and key parameter requirement?
Customer has some concern of disconnect GND, floating GND may damage device. The application is battery pack connected with Vin. Appreciate if you can give some comment on this application, is there some risk comparing with disconnecting VS?
Thanks a lot.
Best reards
Chen
