Other Parts Discussed in Thread: UCC24612
Hi, I have seem Hi Volt Interactive slide discussing how SRs allow negative current flow under light loads to improve cross regulation
Based on this document, the controller allow negative current.
The first question is if there is a simulation model for this controller?
I have been checking the datasheet and use the voltage-seconds value to calculate the Ton, so it is probably why allow negative currents. I could not see on the documentation related with this UCC24630 any reference to the cross regulation. The only demo board is single output converter.
Maybe you could help me to get some information about it? Anyway I will run some simulations to try to get a better idea of how it works.
