Part Number: LMZ36002
Hi Team,
I want to know the error range of the internal adjustment resistor.
Because my customer would like to know the maximum and minimum output voltage values during use.
It is described in the data sheet below.
"The stated limit of the set-point voltage tolerance includes the tolerance of both the internal voltage reference
and the internal adjustment resistor. The overall output voltage tolerance is affected by the tolerance of the external RSET resistor."
I found the accuracy of the internal voltage reference in the datasheet.
”an internal voltage reference that is 2% accurate over temperature. ”
Kenji
