On page 17 of the datasheet section 8.3.8 describes how the BQ25100A will halve the charging current between 0C and +10C. Will halving the charging current halve the Iterm current or will that remain at the +10C to +45C value?
Hi Lauren,
When the BQ25100A falls into the 0C to 10C range, the device should reduce the Iterm current. I will confirm with some lab tests and update in a few days.
Hi Lauren,
To update after checking in the lab, the BQ25100A will not reduce the Iterm current and only the fast charge will be reduced when in the 0 to 10C range.
