Hi
I want to know what is max current on VRef. Since I want to run a small microcontroller with it and turn some LEDs. In the datasheet mentioned a minimum of 35mA what is Typ or max.
Thank you
Hi
Thank you
Hi Amir,
The spec means that the minimum current to cause VREF to droop to 0V is 35 mA. You should not have VREF pulling more than 35mA.
