BQ34Z100-G1: Support the wrong battery capacity with BQ34Z110!
Part Number: BQ34Z100-G1
Other Parts Discussed in Thread: BQ34Z110, BQ34Z100, 4213, 4460, 4430, 4428
Dear Texas Instrument's Supporter.
My's name is Chien, I have some problems with your BQ34z110 product, The problem's code: The battery capacity is wrong!
My application is Lead Acid Battery pack (24V 75Ah): 2 Battery (12V 75Ah).
When I discharge from 100% capacity (remaining capacity/full charge Capacity: 6940/6940; Voltage: 26.4V) at 3A untill empty (Voltage: 20.2V). Allow the battery to relax, and i read bq34z110 (Voltage 22.4V, remaining capacity/full charge Capacity: 3147/6941; SOC: 46%). And i reset BQ34z110 (power off and on), then I read bq34z110 again (Voltage 22.4V, remaining capacity/full charge Capacity: 770/6952; SOC: 12%). Full available capacity: 7316mAh.
The same thing happens when I charge the battery.
I also changed the Chem ID (8 ID of battery Lead acid) but the situation is the same.
My configuration:
+Qmax Cell 0: 7500 mAh (scale x10)
+Design Cell Capacity: 7500 mAh
+Design Cell Energy: 1500 mWh
+Design Cell Voltage: 2000mV.
+Number of Serious Cells: 12
+Design Energy Scale: 10.
+I Calibrated Voltage and Current (= Actual Current /10).
2 problem: Why there was a miscalculation? There is a big data change when I reset bq34z110.
I want to know how to calculate the full charge capacity (6940mAh) and Full available capacity (7316mAh). Why not 7500, Is it due to battery life?
  • Hello Chien,
    If you do a power cycle during a discharge or charge the gauge will not be able to pick up in the same place because the RAM will be lost. When the gauge is powered on again it takes an "OCV" reading, and if the voltage is still recovering from a discharge it will think the battery is less charged than it really is, which seems to be happening in your application.
    The FCC is calculated with multiple parameters like the temperature and discharge rate, if you decrease temperature and increase discharge rate the FCC should drop and adjust for these changing conditions. SOC = RemCap/FCC
    Sincerely,
    Wyatt Keller
  • Hello Wyatt Keller,
    Thanks for your answers, but i still don't understand, can you say more clearly ?
    When I discharge the battery from full untill (SOC = 100%) empty and relax Battery (the power supply for BQ34 is maintained), Why SOC = 46%? And when the power is reset, the new battery capacity (SOC = 12%) seems correct.
    After a period of testing, I found that the battery's power consumption was calculated by integrating the current over time, that's right ?
  • Hello Chien,
    It is most likely something with the scaling, can you send the .gg for the configuration you have?
    Part of the gauging incorporates integrating the current, but when you power down the gauge it will lose it's RAM and have to take an OCV to know what SOC it is had from voltage correlation.
    Sincerely,
    Wyatt Keller
    Here is my configuration (.gg):
    testBQ34z110.rar
  • Hello Chien,
    Could you post the .gg file as a .csv format to review? Can you also post any log data you have of your tests, it will make any debug quicker.
    Sincerely,
    Wyatt Keller
    Here is my configuration. I don't have any log data, if it's necessary I will prepare it and send it to you later.
    [Header]
    bq EVSW Version = 0.9.90
    DeviceName = bq34z110 v0.04
    Time = 10/3/2020 6:07:07 PM
    [Safety(Configuration)]
    OT Chg = 55.0
    OT Chg Time = 2
    OT Chg Recovery = 50.0
    OT Dsg = 60.0
    OT Dsg Time = 2
    OT Dsg Recovery = 55.0
    [Charge Inhibit Cfg(Configuration)]
    Chg Inhibit Temp Low = 0.0
    Chg Inhibit Temp High = 45.0
    Temp Hys = 5.0
    [Charge(Configuration)]
    Suspend Low Temp = -5.0
    Suspend High Temp = 55.0
    Chg Eff = 100
    Chg Eff Temp Comp = 25
    Chg Eff Drop Off % = 96
    Chg Eff Reduction Rate = 10
    Maintenance Current = 0
    [Charge Termination(Configuration)]
    Taper Current = 100
    Min Taper Capacity = 25
    Cell Taper Voltage = 100
    Current Taper Window = 40
    TCA Set % = 99
    TCA Clear % = 95
    FC Set % = 100
    FC Clear % = 98
    DODatEOC Delta T = 10.0
    [Data(Configuration)]
    Rem Cap Alarm = 100
    Design Cell Voltage = 2000
    Initial Standby = -10
    Initial MaxLoad = -500
    Manuf Date = 01-Jan-1980
    Ser. Num. = 0001
    Cycle Count = 14
    CC Threshold = 900
    Design Cell Capacity = 7500
    Design Cell Energy = 1500
    SOH Load I = -400
    TDD SOH Percent = 90
    Cell Charge Voltage T1-T2 = 2200
    Cell Charge Voltage T2-T3 = 2450
    Cell Charge Voltage T3-T4 = 2350
    Charge Current T1-T2 = 10
    Charge Current T2-T3 = 50
    Charge Current T3-T4 = 30
    JEITA T1 = 0
    JEITA T2 = 10
    JEITA T3 = 45
    JEITA T4 = 55
    ISD Current = 10
    ISD I Filter = 127
    Min ISD Time = 7
    Design Energy Scale = 10
    Device Name = bq34z110
    Manufacturer Name = Texas Inst.
    Device Chemistry = PbA
    [Discharge(Configuration)]
    SOC1 Set Threshold = 150
    SOC1 Clear Threshold = 175
    SOCF Set Threshold = 75
    SOCF Clear Threshold = 100
    Cell BL Set Volt Threshold = 1800
    Cell BL Set Volt Time = 2
    Cell BL Clear Volt Threshold = 1850
    Cell BH Set Volt Threshold = 2450
    Cell BH Volt Time = 2
    Cell BH Clear Volt Threshold = 2400
    [Manufacturer Data(Configuration)]
    Pack Lot Code = 0000
    PCB Lot Code = 0000
    Firmware Version = 0000
    Hardware Revision = 0000
    Cell Revision = 0000
    DF Config Version = 0000
    [Integrity Data(Configuration)]
    Static Chem DF Checksum = 6DCC
    [Lifetime Data(Configuration)]
    Lifetime Max Temp = 97.4
    Lifetime Min Temp = 20.0
    Lifetime Max Chg Current = 1361
    Lifetime Max Dsg Current = -1119
    Lifetime Max Pack Voltage = 33504
    Lifetime Min Pack Voltage = 16872
    [Lifetime Temp Samples(Configuration)]
    LT Flash Cnt = 106
    [Registers(Configuration)]
    Pack Configuration = 2951
    Pack Configuration B = FF
    Pack Configuration C = 30
    LED_Comm Configuration = 0A
    Alert Configuration = F040
    Number of series cell = 12
    [Lifetime Resolution(Configuration)]
    LT Temp Res = 1.0
    LT Cur Res = 100
    LT V Res = 25
    LT Update Time = 60
    [LED Display(Configuration)]
    LED Hold Time = 4
    [Power(Configuration)]
    Flash Update OK Cell Volt = 1000
    Sleep Current = 10
    FS Wait = 0
    [Manufacturer Info(System Data)]
    Block A 0 = 00
    Block A 1 = 00
    Block A 2 = 00
    Block A 3 = 00
    Block A 4 = 00
    Block A 5 = 00
    Block A 6 = 00
    Block A 7 = 00
    Block A 8 = 00
    Block A 9 = 00
    Block A 10 = 00
    Block A 11 = 00
    Block A 12 = 00
    Block A 13 = 00
    Block A 14 = 00
    Block A 15 = 00
    Block A 16 = 00
    Block A 17 = 00
    Block A 18 = 00
    Block A 19 = 00
    Block A 20 = 00
    Block A 21 = 00
    Block A 22 = 00
    Block A 23 = 00
    Block A 24 = 00
    Block A 25 = 00
    Block A 26 = 00
    Block A 27 = 00
    Block A 28 = 00
    Block A 29 = 00
    Block A 30 = 00
    Block A 31 = 00
    [IT Cfg(Gas Gauging)]
    Load Select = 1
    Load Mode = 0
    Max Res Factor = 15
    Min Res Factor = 3
    Ra Filter = 500
    Fast Qmax Start DOD % = 92
    Fast Qmax End DOD % = 96
    Fast Qmax Start Volt Delta = 100
    Cell Terminate Voltage = 1800
    Cell Term V Delta = 25
    ResRelax Time = 200
    User Rate-mA = 0
    User Rate-Pwr = 0
    Reserve Cap-mAh = 0
    Reserve Energy = 0
    Max Scale Back Grid = 4
    Cell Max DeltaV = 100
    Cell Min DeltaV = 0
    Max Sim Rate = 2
    Min Sim Rate = 20
    Ra Max Delta = 44
    Qmax Max Delta % = 5
    Cell DeltaV Max Delta = 10
    Fast Scale Start SOC = 10
    Charge Hys V Shift = 40
    [Current Thresholds(Gas Gauging)]
    Dsg Current Threshold = 60
    Chg Current Threshold = 75
    Quit Current = 100
    Dsg Relax Time = 60
    Chg Relax Time = 60
    Quit Relax Time = 1
    Cell Max IR Correct = 400
    [State(Gas Gauging)]
    Qmax Cell 0 = 7500
    Cycle Count = 0
    Update Status = 06
    Cell V at Chg Term = 2400
    Avg I Last Run = -299
    Avg P Last Run = -1131
    Cell Delta Voltage = 2
    T Rise = 20
    T Time Constant = 1000
    [OCVa Table(OCV Table)]
    Chem ID = 0803
    [R_a0(Ra Table)]
    Cell0 R_a flag = FF55
    Cell0 R_a 0 = 179
    Cell0 R_a 1 = 157
    Cell0 R_a 2 = 140
    Cell0 R_a 3 = 129
    Cell0 R_a 4 = 125
    Cell0 R_a 5 = 127
    Cell0 R_a 6 = 127
    Cell0 R_a 7 = 143
    Cell0 R_a 8 = 147
    Cell0 R_a 9 = 153
    Cell0 R_a 10 = 158
    Cell0 R_a 11 = 165
    Cell0 R_a 12 = 201
    Cell0 R_a 13 = 277
    Cell0 R_a 14 = 369
    [R_a0x(Ra Table)]
    xCell0 R_a flag = FFFF
    xCell0 R_a 0 = 179
    xCell0 R_a 1 = 157
    xCell0 R_a 2 = 140
    xCell0 R_a 3 = 129
    xCell0 R_a 4 = 125
    xCell0 R_a 5 = 127
    xCell0 R_a 6 = 127
    xCell0 R_a 7 = 143
    xCell0 R_a 8 = 147
    xCell0 R_a 9 = 153
    xCell0 R_a 10 = 158
    xCell0 R_a 11 = 165
    xCell0 R_a 12 = 201
    xCell0 R_a 13 = 277
    xCell0 R_a 14 = 369
    [Data(Calibration)]
    CC Gain = 51.51
    CC Delta = 51.41
    CC Offset = -0.71
    Board Offset = 0.33
    Int Temp Offset = 0.0
    Ext Temp Offset = -.9
    Voltage Divider = 40948
    [Current(Calibration)]
    Deadband = 5
    [Codes(Security)]
    Sealed to Unsealed = 36720414
    Unsealed to Full = FFFFFFFF
    Authen Key3 = 01234567
    Authen Key2 = 89ABCDEF
    Authen Key1 = FEDCBA98
    Authen Key0 = 76543210
    cần thiết, tôi sẽ chuẩn bị và gửi cho bạn sau.
  • Hello Chien,
    Can you send the log data as well? it will be helpful for debug.
    As I mentioned before, the gauge will use a voltage lookup if the power is removed and reconnected to the gauge, what it seems is happening is the design energy is actually higher than what is programmed. This makes the gauge think there is a higher SOC than there really is.
    Are you using the bq34z100 or bq34z110? both are linked in the description.
    Sincerely,
    Wyatt Keller
    Here is my log data, discharge from 100%. I'm using the bq34z110.
    bq EVSW Version: 0.9.90 for bq34z110 v0.04
    Device:110,Ver:0.04
    Sample Stamp ~Elapsed(s) Control CtrlStatus StateofCharge RemCap FullChgCap Voltage AveCur Temperature Flags @Rate(@) @TimeEmpty NomAvailCap FullAvailCap AvgTimeEmpty AvgTimeFull StandbyCurr StandTTE MaxLoadCurrent MaxTTE AvailEnergy AvailPower TTEConstPwr IntTemp CycleCnt StateofHealth Charge Voltage Charge Current Passed Charge DOD0 SelfDischargeCurrent PackConfig Current
    1 ######## 0 5 5 100 6946 6946 26196 5 32.3 200 0 65535 7298 7298 65535 0 -10 43788 -500 834 1375 1 65535 35.8 14 96 29400 0 0 0 0 2951 6
    2 ######## 12 5 5 100 6946 6946 26196 6 32.3 200 0 65535 7298 7298 65535 0 -10 43788 -500 834 1375 1 65535 35.8 14 96 29400 0 0 0 0 2951 6
    3 ######## 24 5 5 100 6946 6946 26196 6 32.5 200 0 65535 7298 7298 65535 0 -10 43788 -500 834 1375 1 65535 35.9 14 96 29400 0 0 0 0 2951 6
    4 ######## 36 5 5 100 6946 6946 26196 6 32.5 200 0 65535 7298 7298 65535 0 -10 43788 -500 834 1375 1 65535 35.9 14 96 29400 0 0 0 0 2951 6
    5 ######## 48 5 5 100 6946 6946 26196 6 32.4 200 0 65535 7298 7298 65535 0 -10 43788 -500 834 1375 65472 65535 35.9 14 96 29400 0 0 0 0 2951 -291
    6 ######## 60 5 5 100 6945 6946 25932 -45 32.4 201 0 65535 7297 7298 9260 65535 -10 43782 -500 833 1375 65519 4853 35.8 14 96 29400 0 1 0 0 2951 -80
    7 ######## 72 5 5 100 6945 6946 25884 -62 32.2 201 0 65535 7297 7298 6614 65535 -10 43782 -500 833 1375 65519 4853 35.7 14 96 29400 0 1 0 0 2951 -79
    8 ######## 84 5 5 100 6945 6946 25860 -70 32.3 201 0 65535 7297 7298 5869 65535 -10 43782 -500 833 1375 65519 4853 35.7 14 96 29400 0 1 0 0 2951 -79
    9 ######## 96 5 5 100 6944 6946 25824 -76 32.1 201 0 65535 7296 7298 5482 65535 -10 43776 -500 833 1375 65519 4853 35.6 14 96 29400 0 2 0 0 2951 -78
    10 ######## 108 5 5 100 6944 6946 25812 -77 32.1 200 0 65535 7296 7298 5411 65535 -10 43776 -500 833 1375 65519 4853 35.5 14 96 29400 0 2 0 0 2951 -78
    11 ######## 120 5 5 100 6944 6946 25800 -78 32.1 200 0 65535 7296 7298 5342 65535 -10 43776 -500 833 1375 65519 4853 35.5 14 96 29400 0 2 0 0 2951 -78
    12 ######## 132 5 5 100 6944 6946 25800 -77 32.2 200 0 65535 7296 7298 5411 65535 -10 43776 -500 833 1375 65519 4853 35.5 14 96 29400 0 2 0 0 2951 -77
    13 ######## 144 5 5 100 6944 6946 25800 -77 32 200 0 65535 7296 7298 5411 65535 -10 43776 -500 833 1375 65519 4853 35.4 14 96 29400 0 2 0 0 2951 -77
    14 ######## 157 5 5 100 6943 6946 25800 -77 31.9 200 0 65535 7295 7298 5410 65535 -10 43770 -500 833 1375 65519 4853 35.3 14 96 29400 0 3 0 0 2951 -77
    15 ######## 169 5 5 100 6943 6946 25800 -77 31.7 200 0 65535 7295 7298 5410 65535 -10 43770 -500 833 1375 65520 5156 35.2 14 96 29400 0 3 0 0 2951 -76
    16 ######## 181 5 5 100 6943 6946 25800 -76 31.7 200 0 65535 7295 7298 5481 65535 -10 43770 -500 833 1375 65520 5156 35.1 14 96 29400 0 3 0 0 2951 -76
    17 ######## 193 5 5 100 6942 6946 25800 -76 31.7 200 0 65535 7294 7298 5481 65535 -10 43764 -500 833 1375 65520 5156 35.1 14 96 29400 0 4 0 0 2951 -76
    18 ######## 205 5 5 100 6942 6946 25800 -76 31.7 200 0 65535 7294 7298 5481 65535 -10 43764 -500 833 1375 65520 5156 35.1 14 96 29400 0 4 0 0 2951 -76
    19 ######## 217 5 5 100 6942 6946 25800 -76 31.6 200 0 65535 7294 7298 5481 65535 -10 43764 -500 833 1375 65520 5156 35 14 96 29400 0 4 0 0 2951 -76
    20 ######## 229 5 5 100 6942 6946 25800 -76 31.4 200 0 65535 7294 7298 5481 65535 -10 43764 -500 833 1375 65520 5156 34.9 14 96 29400 0 4 0 0 2951 -75
    21 ######## 241 5 5 100 6941 6946 25800 -75 31.3 200 0 65535 7293 7298 5553 65535 -10 43758 -500 833 1374 65520 5153 34.8 14 96 29400 0 5 0 0 2951 -75
    22 ######## 253 5 5 100 6941 6946 25800 -75 31.2 200 0 65535 7293 7298 5553 65535 -10 43758 -500 833 1374 65520 5153 34.8 14 96 29400 0 5 0 0 2951 -75
    23 ######## 265 5 5 100 6941 6946 25812 -75 31.2 200 0 65535 7293 7298 5553 65535 -10 43758 -500 833 1374 65520 5153 34.7 14 96 29400 0 5 0 0 2951 -75
    24 ######## 277 5 5 100 6941 6946 25812 -75 31.3 200 0 65535 7293 7298 5553 65535 -10 43758 -500 833 1374 65520 5153 34.7 14 96 29400 0 5 0 0 2951 -74
    25 ######## 289 5 5 100 6934 6940 25680 -117 31.3 201 0 65535 7295 7301 3556 65535 -10 43770 -500 832 1372 65505 2655 34.7 14 96 29400 0 6 0 0 2951 -145
    26 ######## 301 5 5 100 6934 6940 25704 -124 31.2 201 0 65535 7295 7301 3355 65535 -10 43770 -500 832 1372 65511 3293 34.7 14 96 29400 0 6 0 0 2951 -119
    27 ######## 313 5 5 100 6933 6940 25704 -119 31.2 201 0 65535 7294 7301 3496 65535 -10 43764 -500 832 1372 65511 3293 34.7 14 96 29400 0 7 0 0 2951 -118
    28 ######## 325 5 5 100 6933 6940 25716 -118 31.3 201 0 65535 7294 7301 3525 65535 -10 43764 -500 832 1372 65510 3166 34.7 14 96 29400 0 7 0 0 2951 -121
    29 ######## 337 5 5 100 6932 6940 25632 -137 31.3 201 0 65535 7293 7301 3036 65535 -10 43758 -500 832 1372 65497 2111 34.7 14 96 29400 0 8 0 0 2951 -181
    30 ######## 349 5 5 100 6932 6940 25608 -161 31.2 201 0 65535 7293 7301 2552 65535 -10 43758 -500 832 1372 65494 1960 34.6 14 96 29400 0 8 0 0 2951 -196
    31 ######## 361 FF4C 5 100 6931 6940 25596 -174 31.2 201 0 65535 7292 7301 2390 65535 -10 43752 -500 832 1372 65497 2111 34.6 14 96 29400 0 9 0 0 2951 -182
    32 ######## 373 FF4B 5 100 6931 6940 25596 -178 31.3 201 0 65535 7292 7301 2336 65535 -10 43752 -500 832 1372 65496 2058 34.6 14 96 29400 0 9 0 0 2951 -184
    33 ######## 385 FF4A 5 100 6930 6940 25596 -180 31.4 201 0 65535 7291 7301 2310 65535 -10 43746 -500 832 1371 65497 2109 34.7 14 96 29400 0 10 0 0 2951 -183
    34 ######## 397 FF4D 5 100 6930 6940 25596 -180 31.6 201 0 65535 7291 7301 2310 65535 -10 43746 -500 832 1371 65497 2109 34.8 14 96 29400 0 10 0 0 2951 -182
    35 ######## 409 FF4A 5 100 6929 6940 25596 -181 31.6 201 0 65535 7290 7301 2297 65535 -10 43740 -500 831 1371 65497 2109 34.9 14 96 29400 0 11 0 0 2951 -181
    36 ######## 421 FF4B 5 100 6928 6940 25596 -181 31.7 201 0 65535 7289 7301 2297 65535 -10 43734 -500 831 1371 65498 2165 34.9 14 96 29400 0 12 0 0 2951 -181
    37 ######## 433 FF49 5 100 6928 6940 25608 -181 31.8 201 0 65535 7289 7301 2297 65535 -10 43734 -500 831 1371 65497 2109 34.9 14 96 29400 0 12 0 0 2951 -181
    38 ######## 445 FF4D 5 100 6927 6940 25608 -181 31.7 201 0 65535 7288 7301 2296 65535 -10 43728 -500 831 1371 65498 2165 34.9 14 96 29400 0 13 0 0 2951 -182
    39 ######## 457 FF50 5 100 6927 6940 25620 -179 31.7 201 0 65535 7288 7301 2322 65535 -10 43728 -500 831 1371 65498 2165 34.9 14 96 29400 0 13 0 0 2951 -180
    40 ######## 469 FF50 5 100 6926 6940 25620 -178 31.9 201 0 65535 7287 7301 2335 65535 -10 43722 -500 831 1371 65498 2165 35 14 96 29400 0 14 0 0 2951 -181
    41 ######## 481 FF4B 5 100 6926 6940 25572 -181 31.9 201 0 65535 7286 7301 2296 65535 -10 43716 -500 831 1370 65497 2108 35 14 96 29400 0 15 0 0 2951 -185
    42 ######## 493 FF50 5 100 6925 6940 25620 -179 31.9 201 0 65535 7286 7301 2321 65535 -10 43716 -500 831 1370 65498 2163 35.1 14 96 29400 0 15 0 0 2951 -180
    43 ######## 505 FF51 5 100 6924 6940 25620 -178 32 201 0 65535 7285 7301 2334 65535 -10 43710 -500 831 1370 65498 2163 35.2 14 96 29400 0 16 0 0 2951 -179
    44 ######## 517 FF4E 5 100 6923 6940 25620 -177 32.1 201 0 65535 7284 7301 2347 65535 -10 43704 -500 831 1370 65498 2163 35.2 14 96 29400 0 17 0 0 2951 -176
    45 ######## 529 FF41 5 100 6923 6940 25596 -179 32.1 201 0 65535 7284 7301 2308 65535 -10 43704 -500 831 1370 65494 1957 35.2 14 96 29400 0 17 0 0 2951 -200
    46 ######## 541 FF33 5 100 6922 6940 25572 -195 32.2 201 0 65535 7283 7301 2130 65535 -10 43698 -500 831 1370 65494 1957 35.2 14 96 29400 0 18 0 0 2951 -185
    47 ######## 553 FF40 5 100 6922 6940 25584 -195 32.1 201 0 65535 7283 7301 2141 65535 -10 43698 -500 831 1370 65496 2055 35.2 14 96 29400 0 18 0 0 2951 -196
    48 ######## 565 FF41 5 100 6921 6940 25596 -192 32.1 201 0 65535 7282 7301 2174 65535 -10 43692 -500 831 1369 65497 2106 35.2 14 96 29400 0 19 0 0 2951 -186
    49 ######## 577 FF4D 5 100 6921 6940 25608 -189 32.1 201 0 65535 7282 7301 2197 65535 -10 43692 -500 831 1369 65497 2003 35.1 14 96 29400 0 19 0 0 2951 -192
    50 ######## 589 FF51 5 100 6920 6940 25620 -190 32.3 201 0 65535 7281 7301 2197 65535 -10 43686 -500 830 1369 65499 2220 35.3 14 96 29400 0 20 0 0 2951 -178
    51 ######## 601 FF51 5 100 6919 6940 25620 -182 32.4 201 0 65535 7280 7301 2294 65535 -10 43680 -500 830 1369 65499 2220 35.3 14 96 29400 0 21 0 0 2951 -179
    52 ######## 613 FF53 5 100 6918 6940 25620 -178 32.4 201 0 65535 7279 7301 2332 65535 -10 43674 -500 830 1369 65498 2162 35.4 14 96 29400 0 22 0 0 2951 -178
    53 ######## 625 FF36 5 100 6918 6940 25620 -181 32.4 201 0 65535 7279 7301 2293 65535 -10 43674 -500 830 1369 65499 2220 35.4 14 96 29400 0 22 0 0 2951 -180
    54 ######## 637 FF53 5 100 6917 6940 25632 -178 32.4 201 0 65535 7278 7301 2332 65535 -10 43668 -500 830 1369 65498 2162 35.4 14 96 29400 0 23 0 0 2951 -185
    55 ######## 649 FF4B 5 100 6917 6940 25620 -179 32.5 201 0 65535 7278 7301 2319 65535 -10 43668 -500 830 1369 65497 2106 35.4 14 96 29400 0 23 0 0 2951 -180
    56 ######## 661 FF4D 5 100 6916 6940 25620 -179 32.4 201 0 65535 7277 7301 2318 65535 -10 43662 -500 830 1368 65497 2105 35.4 14 96 29400 0 24 0 0 2951 -181
    57 ######## 674 FF53 5 100 6916 6940 25620 -178 32.2 201 0 65535 7277 7301 2331 65535 -10 43662 -500 830 1368 65498 2160 35.3 14 96 29400 0 24 0 0 2951 -178
    58 ######## 686 FF4F 5 100 6915 6940 25620 -178 32.1 201 0 65535 7276 7301 2331 65535 -10 43656 -500 830 1368 65498 2160 35.2 14 96 29400 0 25 0 0 2951 -178
    59 ######## 698 FF4A 5 100 6914 6940 25620 -179 32.1 201 0 65535 7275 7301 2318 65535 -10 43650 -500 830 1368 65497 2105 35.2 14 96 29400 0 26 0 0 2951 -179
    60 ######## 710 FF4C 5 100 6914 6940 25620 -180 32.2 201 0 65535 7275 7301 2305 65535 -10 43650 -500 830 1368 65497 2105 35.2 14 96 29400 0 26 0 0 2951 -211
    61 ######## 722 FF4F 5 100 6913 6940 25620 -182 32.2 201 0 65535 7274 7301 2279 65535 -10 43644 -500 830 1368 65497 2105 35.3 14 96 29400 0 27 0 0 2951 -178
    62 ######## 734 FF50 5 100 6913 6940 25632 -180 32.2 201 0 65535 7274 7301 2304 65535 -10 43644 -500 830 1368 65499 2002 35.3 14 96 29400 0 27 0 0 2951 -191
    63 ######## 746 FF4E 5 100 6912 6940 25620 -180 32.2 201 0 65535 7273 7301 2304 65535 -10 43638 -500 829 1368 65498 2160 35.3 14 96 29400 0 28 0 0 2951 -181
    64 ######## 758 FF50 5 100 6912 6940 25632 -179 32.2 201 0 65535 7273 7301 2317 65535 -10 43638 -500 829 1368 65497 2105 35.3 14 96 29400 0 28 0 0 2951 -182
    65 ######## 770 FF4F 5 100 6911 6940 25632 -179 32.2 201 0 65535 7272 7301 2317 65535 -10 43632 -500 829 1367 65495 2000 35.3 14 96 29400 0 30 0 0 2951 -193
    66 ######## 782 FF4A 5 100 6910 6940 25620 -182 32.1 201 0 65535 7271 7301 2278 65535 -10 43626 -500 829 1367 65498 2158 35.3 14 96 29400 0 30 0 0 2951 -179
    67 ######## 794 FF4E 5 100 6909 6940 25632 -181 32.1 201 0 65535 7270 7301 2290 65535 -10 43620 -500 829 1367 65498 2158 35.2 14 96 29400 0 31 0 0 2951 -180
    68 ######## 806 FF4E 5 100 6909 6940 25632 -179 32.2 201 0 65535 7270 7301 2316 65535 -10 43620 -500 829 1367 65498 2158 35.3 14 96 29400 0 31 0 0 2951 -177
    69 ######## 819 FF4F 5 100 6908 6940 25632 -179 32.3 201 0 65535 7269 7301 2329 65535 -10 43614 -500 829 1367 65498 2158 35.3 14 96 29400 0 32 0 0 2951 -180
    70 ######## 831 FF4F 5 100 6908 6940 25632 -178 32.3 201 0 65535 7269 7301 2329 65535 -10 43614 -500 829 1367 65498 2158 35.3 14 96 29400 0 32 0 0 2951 -178
    71 ######## 843 FF54 5 100 6907 6940 25632 -178 32.3 201 0 65535 7268 7301 2328 65535 -10 43608 -500 829 1366 65499 2215 35.3 14 96 29400 0 33 0 0 2951 -175
    72 ######## 855 FF53 5 100 6907 6940 25632 -176 32.2 201 0 65535 7268 7301 2355 65535 -10 43608 -500 829 1366 65499 2215 35.3 14 96 29400 0 33 0 0 2951 -177
    73 ######## 867 FF52 5 100 6906 6940 25644 -175 32.2 201 0 65535 7267 7301 2368 65535 -10 43602 -500 829 1366 65498 2157 35.3 14 96 29400 0 34 0 0 2951 -176
    74 ######## 879 FF55 5 100 6905 6940 25644 -175 32.2 201 0 65535 7266 7301 2354 65535 -10 43596 -500 829 1366 65498 2157 35.3 14 96 29400 0 35 0 0 2951 -177
    75 ######## 891 FF53 5 100 6905 6940 25644 -175 32.1 201 0 65535 7266 7301 2367 65535 -10 43596 -500 829 1366 65498 2157 35.3 14 96 29400 0 35 0 0 2951 -176
    76 ######## 903 FF55 5 100 6904 6940 25644 -174 32.2 201 0 65535 7265 7301 2367 65535 -10 43590 -500 828 1366 65498 2157 35.3 14 96 29400 0 36 0 0 2951 -176
    77 ######## 915 FF50 5 100 6904 6940 25644 -174 32.3 201 0 65535 7265 7301 2381 65535 -10 43590 -500 828 1366 65499 2215 35.3 14 96 29400 0 36 0 0 2951 -176
    78 ######## 927 FF52 5 100 6903 6940 25632 -174 32.3 201 0 65535 7264 7301 2380 65535 -10 43584 -500 828 1366 65499 2215 35.3 14 96 29400 0 37 0 0 2951 -174
    79 ######## 939 FF53 5 100 6903 6940 25644 -174 32.3 201 0 65535 7264 7301 2380 65535 -10 43584 -500 828 1366 65499 2215 35.3 14 96 29400 0 37 0 0 2951 -177
    80 ######## 951 FF54 5 100 6902 6940 25632 -176 32.3 201 0 65535 7263 7301 2340 65535 -10 43578 -500 828 1365 65498 2155 35.4 14 96 29400 0 38 0 0 2951 -178
    81 ######## 963 FF53 5 100 6901 6940 25632 -176 32.3 201 0 65535 7262 7301 2353 65535 -10 43572 -500 828 1365 65498 2155 35.3 14 96 29400 0 39 0 0 2951 -176
    82 ######## 975 FF55 5 100 6901 6940 25632 -175 32.3 201 0 65535 7262 7301 2366 65535 -10 43572 -500 828 1365 65499 2214 35.3 14 96 29400 0 39 0 0 2951 -178
    83 ######## 987 FF54 5 100 6900 6940 25644 -175 32.4 201 0 65535 7261 7301 2366 65535 -10 43566 -500 828 1365 65499 2214 35.4 14 96 29400 0 40 0 0 2951 -176
    84 ######## 1000 FF55 5 100 6900 6940 25644 -174 32.3 201 0 65535 7261 7301 2379 65535 -10 43566 -500 828 1365 65498 2155 35.4 14 96 29400 0 40 0 0 2951 -178
    85 ######## 1012 FF53 5 100 6899 6940 25644 -174 32.4 201 0 65535 7260 7301 2379 65535 -10 43560 -500 828 1365 65499 2214 35.4 14 96 29400 0 41 0 0 2951 -180
    86 ######## 1024 FF54 5 100 6899 6940 25644 -174 32.4 201 0 65535 7260 7301 2379 65535 -10 43560 -500 828 1365 65498 2155 35.4 14 96 29400 0 41 0 0 2951 -178
    87 ######## 1036 FF54 5 100 6898 6940 25644 -174 32.4 201 0 65535 7259 7301 2379 65535 -10 43554 -500 828 1365 65499 2214 35.4 14 96 29400 0 42 0 0 2951 -179
    88 ######## 1048 FF54 5 100 6897 6940 25632 -174 32.3 201 0 65535 7258 7301 2378 65535 -10 43548 -500 828 1364 65499 2154 35.4 14 96 29400 0 43 0 0 2951 -176
    89 ######## 1060 FF52 5 100 6897 6940 25632 -174 32.3 201 0 65535 7257 7301 2378 65535 -10 43542 -500 828 1364 65499 2212 35.4 14 96 29400 0 44 0 0 2951 -177
    90 ######## 1072 FF54 5 100 6896 6940 25632 -174 32.5 201 0 65535 7257 7301 2378 65535 -10 43542 -500 828 1364 65499 2212 35.4 14 96 29400 0 44 0 0 2951 -193
    91 ######## 1084 FF54 5 100 6895 6940 25632 -175 32.5 201 0 65535 7256 7301 2364 65535 -10 43536 -500 827 1364 65499 2154 35.4 14 96 29400 0 45 0 0 2951 -177
    92 ######## 1096 FF55 5 100 6895 6940 25632 -175 32.5 201 0 65535 7256 7301 2364 65535 -10 43536 -500 827 1364 65499 2212 35.4 14 96 29400 0 45 0 0 2951 -175
    93 ######## 1108 FF54 5 100 6894 6940 25644 -174 32.4 201 0 65535 7255 7301 2377 65535 -10 43530 -500 827 1364 65498 2098 35.4 14 96 29400 0 46 0 0 2951 -177
    94 ######## 1120 FF55 5 100 6894 6940 25632 -174 32.5 201 0 65535 7255 7301 2377 65535 -10 43530 -500 827 1364 65499 2212 35.4 14 96 29400 0 46 0 0 2951 -180
    95 ######## 1132 FF51 5 100 6893 6940 25632 -174 32.4 201 0 65535 7254 7301 2377 65535 -10 43524 -500 827 1363 65498 2152 35.4 14 96 29400 0 47 0 0 2951 -177
    96 ######## 1144 FF54 5 100 6892 6940 25644 -174 32.4 201 0 65535 7253 7301 2377 65535 -10 43518 -500 827 1363 65499 2210 35.4 14 96 29400 0 48 0 0 2951 -176
    97 ######## 1156 FF52 5 100 6892 6940 25632 -174 32.4 201 0 65535 7253 7301 2377 65535 -10 43518 -500 827 1363 65498 2152 35.4 14 96 29400 0 48 0 0 2951 -175
    98 ######## 1168 FF53 5 100 6891 6940 25632 -174 32.4 201 0 65535 7252 7301 2376 65535 -10 43512 -500 827 1363 65499 2210 35.4 14 96 29400 0 49 0 0 2951 -175
    99 ######## 1180 FF53 5 100 6891 6940 25632 -174 32.4 201 0 65535 7252 7301 2376 65535 -10 43512 -500 827 1363 65499 2210 35.4 14 96 29400 0 49 0 0 2951 -176
    100 ######## 1192 FF53 5 100 6890 6940 25632 -174 32.4 201 0 65535 7251 7301 2376 65535 -10 43506 -500 827 1363 65498 2152 35.4 14 96 29400 0 50 0 0 2951 -176
    101 ######## 1204 FE5B 5 100 6890 6940 25416 -229 32.4 201 0 65535 7251 7301 1805 65535 -10 43506 -500 827 1363 65445 899 35.4 14 96 29400 0 51 0 0 2951 -432
    102 ######## 1216 FE67 5 100 6888 6940 25332 -321 32.5 201 0 65535 7249 7301 1287 65535 -10 43494 -500 827 1362 65451 961 35.5 14 96 29400 0 52 0 0 2951 -411
    103 ######## 1228 FE3E 5 100 6886 6940 25284 -397 32.7 201 0 65535 7247 7301 1030 65535 -10 43482 -500 826 1362 65440 851 35.7 14 96 29400 0 54 0 0 2951 -460
    104 ######## 1240 FE38 5 100 6885 6940 25272 -429 32.8 201 0 65535 7246 7301 958 65535 -10 43470 -500 826 1362 65439 842 35.7 14 96 29400 0 56 0 0 2951 -461
    105 ######## 1252 FE38 5 100 6883 6940 25272 -444 33.2 201 0 65535 7244 7301 930 65535 -10 43464 -500 826 1361 65440 851 36 14 96 29400 0 57 0 0 2951 -461
    106 ######## 1265 FE39 5 100 6882 6940 25272 -451 33.6 201 0 65535 7243 7301 914 65535 -10 43458 -500 826 1361 65439 842 36.2 14 96 29400 0 58 0 0 2951 -463
    107 ######## 1277 FE34 5 100 6880 6940 25260 -456 34 201 0 65535 7241 7301 905 65535 -10 43446 -500 826 1361 65439 842 36.5 14 96 29400 0 60 0 0 2951 -463
    108 ######## 1289 FE35 5 100 6879 6940 25260 -458 34.3 201 0 65535 7240 7301 901 65535 -10 43440 -500 825 1360 65439 841 36.6 14 96 29400 0 61 0 0 2951 -462
    109 ######## 1301 FE33 5 100 6878 6940 25260 -459 34.7 201 0 65535 7239 7301 899 65535 -10 43434 -500 825 1360 65439 841 36.9 14 96 29400 0 62 0 0 2951 -464
    110 ######## 1313 FE33 5 100 6877 6940 25260 -460 35 201 0 65535 7237 7301 897 65535 -10 43422 -500 825 1360 65439 841 37.2 14 96 29400 0 64 0 0 2951 -464
    111 ######## 1325 FE34 5 100 6874 6940 25260 -460 35.6 201 0 65535 7235 7301 897 65535 -10 43410 -500 825 1359 65439 841 37.6 14 96 29400 0 66 0 0 2951 -460
    112 ######## 1337 FE36 5 100 6872 6940 25260 -460 36 201 0 65535 7233 7301 896 65535 -10 43398 -500 825 1359 65439 841 37.8 14 96 29400 0 68 0 0 2951 -464
    113 ######## 1349 FE35 5 100 6871 6940 25260 -461 36.3 201 0 65535 7232 7301 894 65535 -10 43392 -500 825 1359 65439 841 38 14 96 29400 0 69 0 0 2951 -463
    114 ######## 1361 FE36 5 99 6870 6940 25260 -461 36.8 201 0 65535 7231 7301 894 65535 -10 43386 -500 824 1359 65439 841 38.3 14 96 29400 0 71 0 0 2951 -465
    115 ######## 1373 FE33 5 99 6868 6940 25260 -461 36.9 201 0 65535 7229 7301 894 65535 -10 43374 -500 824 1358 65439 840 38.5 14 96 29400 0 72 0 0 2951 -465
    116 ######## 1385 FE33 5 99 6867 6940 25260 -462 37.4 201 0 65535 7228 7301 892 65535 -10 43368 -500 824 1358 65438 831 38.7 14 96 29400 0 73 0 0 2951 -462
    117 ######## 1397 FE35 5 99 6866 6940 25260 -462 37.5 201 0 65535 7227 7301 892 65535 -10 43362 -500 824 1358 65439 840 38.8 14 96 29400 0 75 0 0 2951 -463
    118 ######## 1409 FE32 5 99 6863 6940 25248 -462 37.7 201 0 65535 7224 7301 891 65535 -10 43344 -500 824 1357 65439 839 39.1 14 96 29400 0 77 0 0 2951 -461
    119 ######## 1421 FE33 5 99 6862 6940 25248 -462 37.9 201 0 65535 7222 7301 891 65535 -10 43332 -500 823 1357 65439 839 39.2 14 96 29400 0 79 0 0 2951 -462
    120 ######## 1433 FE30 5 99 6860 6940 25248 -462 38.2 201 0 65535 7221 7301 891 65535 -10 43326 -500 823 1356 65439 830 39.4 14 96 29400 0 80 0 0 2951 -464
    121 ######## 1445 FE36 5 99 6859 6940 25248 -462 38 201 0 65535 7220 7301 891 65535 -10 43320 -500 823 1356 65439 839 39.4 14 96 29400 0 81 0 0 2951 -466
    122 ######## 1458 FE0E 5 99 6857 6940 25236 -464 38.3 201 0 65535 7218 7301 887 65535 -10 43308 -500 823 1356 65439 839 39.5 14 96 29400 0 83 0 0 2951 -462
    123 ######## 1470 FE35 5 99 6856 6940 25236 -463 38.6 201 0 65535 7217 7301 888 65535 -10 43302 -500 823 1356 65439 839 39.8 14 96 29400 0 84 0 0 2951 -466
    124 ######## 1482 FE33 5 99 6855 6940 25236 -463 38.6 201 0 65535 7216 7301 888 65535 -10 43296 -500 823 1355 65438 830 39.9 14 96 29400 0 85 0 0 2951 -464
    125 ######## 1494 FE36 5 99 6853 6940 25236 -462 38.9 201 0 65535 7214 7301 890 65535 -10 43284 -500 822 1355 65439 838 40 14 96 29400 0 87 0 0 2951 -463
    126 ######## 1506 FE36 5 99 6851 6940 25236 -461 39.2 201 0 65535 7212 7301 892 65535 -10 43272 -500 822 1355 65439 838 40.2 14 96 29400 0 90 0 0 2951 -463
    127 ######## 1518 FE36 5 99 6849 6940 25236 -461 39.2 201 0 65535 7210 7301 891 65535 -10 43260 -500 822 1354 65439 838 40.3 14 96 29400 0 91 0 0 2951 -466
    128 ######## 1530 FE35 5 99 6848 6940 25236 -463 39.3 201 0 65535 7209 7301 887 65535 -10 43254 -500 822 1354 65439 838 40.3 14 96 29400 0 92 0 0 2951 -467
    129 ######## 1542 FE35 5 99 6847 6940 25236 -463 39.3 201 0 65535 7208 7301 887 65535 -10 43248 -500 822 1354 65438 829 40.3 14 96 29400 0 94 0 0 2951 -466
    130 ######## 1554 FE32 5 99 6845 6940 25236 -463 39.3 201 0 65535 7206 7301 887 65535 -10 43236 -500 821 1353 65438 828 40.5 14 96 29400 0 95 0 0 2951 -464
    131 ######## 1566 FE31 5 99 6844 6940 25236 -463 39.6 201 0 65535 7205 7301 887 65535 -10 43230 -500 821 1353 65439 837 40.5 14 96 29400 0 96 0 0 2951 -465
    132 ######## 1578 FE33 5 99 6843 6940 25236 -463 39.8 201 0 65535 7203 7301 889 65535 -10 43218 -500 821 1353 65439 837 40.6 14 96 29400 0 98 0 0 2951 -464
    133 ######## 1590 FE33 5 99 6840 6940 25224 -463 39.9 201 0 65535 7201 7301 886 65535 -10 43206 -500 821 1352 65439 836 40.7 14 96 29400 0 100 0 0 2951 -464
    134 ######## 1602 FE34 5 99 6838 6940 25224 -463 40 201 0 65535 7199 7301 886 65535 -10 43194 -500 821 1352 65438 828 40.8 14 96 29400 0 102 0 0 2951 -464
    135 ######## 1614 FE33 5 99 6837 6940 25224 -463 39.8 201 0 65535 7198 7301 888 65535 -10 43188 -500 820 1352 65439 836 40.7 14 96 29400 0 103 0 0 2951 -465
    136 ######## 1626 FE34 5 99 6836 6940 25224 -463 39.9 201 0 65535 7197 7301 886 65535 -10 43182 -500 820 1351 65438 827 40.8 14 96 29400 0 104 0 0 2951 -467
    137 ######## 1638 FE33 5 99 6834 6940 25212 -463 39.6 201 0 65535 7195 7301 886 65535 -10 43170 -500 820 1351 65439 836 40.8 14 96 29400 0 106 0 0 2951 -467
    138 ######## 1650 FE31 5 99 6833 6940 25212 -463 39.9 201 0 65535 7194 7301 885 65535 -10 43164 -500 820 1351 65438 827 40.8 14 96 29400 0 107 0 0 2951 -465
    139 ######## 1662 FE32 5 99 6832 6940 25212 -463 39.9 201 0 65535 7193 7301 885 65535 -10 43158 -500 820 1351 65438 827 40.8 14 96 29400 0 109 0 0 2951 -465
    140 ######## 1674 FE31 5 99 6830 6940 25212 -463 40.1 201 0 65535 7191 7301 885 65535 -10 43146 -500 820 1350 65439 835 40.9 14 96 29400 0 110 0 0 2951 -464
    141 ######## 1686 FE32 5 99 6828 6940 25212 -464 40.4 201 0 65535 7188 7301 883 65535 -10 43128 -500 819 1350 65438 827 41.2 14 96 29400 0 113 0 0 2951 -464
    142 ######## 1698 FE2F 5 99 6826 6940 25212 -464 40.4 201 0 65535 7187 7301 883 65535 -10 43122 -500 819 1349 65439 834 41.3 14 96 29400 0 114 0 0 2951 -465
    143 ######## 1710 FE34 5 99 6825 6940 25212 -463 40.2 201 0 65535 7186 7301 884 65535 -10 43116 -500 819 1349 65439 834 41.2 14 96 29400 0 115 0 0 2951 -464
    144 ######## 1722 FE31 5 99 6823 6940 25212 -464 40.4 201 0 65535 7184 7301 884 65535 -10 43104 -500 819 1349 65439 834 41.3 14 96 29400 0 117 0 0 2951 -466
    145 ######## 1735 FE34 5 99 6822 6940 25212 -463 40.4 201 0 65535 7183 7301 884 65535 -10 43098 -500 819 1349 65438 826 41.3 14 96 29400 0 118 0 0 2951 -466
    146 ######## 1747 FE34 5 99 6821 6940 25212 -464 40.7 201 0 65535 7182 7301 882 65535 -10 43092 -500 819 1348 65439 834 41.5 14 96 29400 0 120 0 0 2951 -468
    147 ######## 1759 FE32 5 99 6819 6940 25212 -463 41 201 0 65535 7180 7301 884 65535 -10 43080 -500 818 1348 65438 825 41.5 14 96 29400 0 121 0 0 2951 -466
    148 ######## 1771 FE32 5 99 6817 6940 25200 -463 40.5 201 0 65535 7178 7301 883 65535 -10 43068 -500 818 1347 65438 825 41.2 14 96 29400 0 124 0 0 2951 -472
    149 ######## 1783 FE35 5 99 6815 6940 25200 -463 40.3 201 0 65535 7176 7301 883 65535 -10 43056 -500 818 1347 65439 825 41.2 14 96 29400 0 125 0 0 2951 -469
    150 ######## 1795 FE32 5 99 6814 6940 25200 -463 40.3 201 0 65535 7175 7301 883 65535 -10 43050 -500 818 1347 65438 825 41.2 14 96 29400 0 126 0 0 2951 -466
    151 ######## 1807 FE34 5 99 6813 6940 25188 -463 40.5 201 0 65535 7174 7301 883 65535 -10 43044 -500 818 1347 65438 824 41.3 14 96 29400 0 128 0 0 2951 -463
    152 ######## 1819 FE2F 5 99 6811 6940 25188 -463 40.6 201 0 65535 7172 7301 883 65535 -10 43032 -500 817 1346 65439 833 41.4 14 96 29400 0 129 0 0 2951 -463
    153 ######## 1831 FE31 5 99 6810 6940 25188 -463 40.7 201 0 65535 7171 7301 883 65535 -10 43026 -500 817 1346 65438 824 41.4 14 96 29400 0 130 0 0 2951 -464
    154 ######## 1843 FE31 5 99 6808 6940 25188 -463 40.8 201 0 65535 7169 7301 882 65535 -10 43014 -500 817 1346 65439 833 41.4 14 96 29400 0 132 0 0 2951 -464
    155 ######## 1855 FE34 5 99 6807 6940 25188 -463 40.8 201 0 65535 7168 7301 882 65535 -10 43008 -500 817 1345 65439 832 41.5 14 96 29400 0 133 0 0 2951 -465
    156 ######## 1867 FE34 5 99 6804 6940 25188 -463 40.4 201 0 65535 7165 7301 882 65535 -10 42990 -500 816 1345 65439 832 41.4 14 96 29400 0 136 0 0 2951 -464
    157 ######## 1879 FE2D 5 99 6803 6940 25188 -463 40.6 201 0 65535 7164 7301 882 65535 -10 42984 -500 816 1345 65439 832 41.4 14 96 29400 0 137 0 0 2951 -467
    158 ######## 1891 FE34 5 99 6802 6940 25188 -463 40.6 201 0 65535 7163 7301 881 65535 -10 42978 -500 816 1344 65439 806 41.5 14 96 29400 0 139 0 0 2951 -476
    159 ######## 1903 FE32 5 98 6800 6940 25188 -464 40.9 1 0 65535 7161 7301 879 65535 -10 42966 -500 816 1344 65438 823 41.5 14 96 29400 0 140 0 0 2951 -467
    160 ######## 1915 FE30 5 98 6799 6940 25188 -464 40.8 1 0 65535 7160 7301 879 65535 -10 42960 -500 816 1344 65438 823 41.5 14 96 29400 0 141 0 0 2951 -466
    161 ######## 1928 FE31 5 98 6798 6940 25188 -463 40.7 1 0 65535 7158 7301 881 65535 -10 42948 -500 816 1343 65439 831 41.5 14 96 29400 0 143 0 0 2951 -464
    162 ######## 1940 FE32 5 98 6796 6940 25176 -463 40.8 1 0 65535 7157 7301 881 65535 -10 42942 -500 816 1343 65438 822 41.4 14 96 29400 0 144 0 0 2951 -465
    163 ######## 1952 FE33 5 98 6793 6940 25176 -463 40.4 1 0 65535 7154 7301 880 65535 -10 42924 -500 815 1342 65439 830 41.3 14 96 29400 0 147 0 0 2951 -464
    164 ######## 1964 FE33 5 98 6792 6940 25176 -463 40.5 1 0 65535 7153 7301 880 65535 -10 42918 -500 815 1342 65439 830 41.4 14 96 29400 0 148 0 0 2951 -464
    165 ######## 1976 FE26 5 98 6791 6940 25164 -465 40.7 1 0 65535 7152 7301 876 65535 -10 42912 -500 815 1342 65437 813 41.5 14 96 29400 0 150 0 0 2951 -465
    166 ######## 1988 FE33 5 98 6789 6940 25164 -465 40.6 1 0 65535 7150 7301 876 65535 -10 42900 -500 815 1342 65438 822 41.4 14 96 29400 0 151 0 0 2951 -465
    167 ######## 2000 FE33 5 98 6788 6940 25164 -464 40.2 1 0 65535 7149 7301 878 65535 -10 42894 -500 815 1341 65439 829 41.2 14 96 29400 0 152 0 0 2951 -464
    168 ######## 2012 FE33 5 98 6787 6940 25164 -463 40.5 1 0 65535 7148 7301 880 65535 -10 42882 -500 814 1341 65439 829 41.3 14 96 29400 0 154 0 0 2951 -464
    169 ######## 2024 FE32 5 98 6785 6940 25164 -463 40.4 1 0 65535 7146 7301 879 65535 -10 42876 -500 814 1341 65438 821 41.2 14 96 29400 0 155 0 0 2951 -466
    170 ######## 2036 FE34 5 98 6784 6940 25164 -463 40.5 1 0 65535 7145 7301 879 65535 -10 42870 -500 814 1341 65439 829 41.2 14 96 29400 0 156 0 0 2951 -467
    171 ######## 2048 FE34 5 98 6781 6940 25164 -463 40.5 1 0 65535 7142 7301 879 65535 -10 42852 -500 814 1340 65438 820 41.2 14 96 29400 0 159 0 0 2951 -465
    172 ######## 2060 FE2A 5 98 6780 6940 25152 -465 40.4 1 0 65535 7141 7301 875 65535 -10 42846 -500 814 1340 65438 820 41.2 14 96 29400 0 160 0 0 2951 -514
    173 ######## 2072 FE26 5 98 6778 6940 25140 -474 40.3 1 0 65535 7139 7301 856 65535 -10 42834 -527 772 1339 65434 788 41.1 14 96 29400 0 162 0 0 2951 -496
    174 ######## 2084 FE1A 5 98 6777 6940 25140 -476 40.5 1 0 65535 7138 7301 854 65535 -10 42828 -527 772 1339 65437 812 41.2 14 96 29400 0 163 0 0 2951 -472
    175 ######## 2096 FE2D 5 98 6776 6940 25152 -473 40.3 1 0 65535 7137 7301 860 65535 -10 42822 -527 771 1339 65438 820 41.1 14 96 29400 0 164 0 0 2951 -464
    176 ######## 2108 FE07 5 98 6774 6940 25104 -483 40.4 1 0 65535 7135 7301 836 65535 -10 42810 -527 771 1338 65427 737 41.2 14 96 29400 0 166 0 0 2951 -517
    177 ######## 2120 FE29 5 98 6772 6940 25140 -480 40.4 1 0 65535 7133 7301 847 65535 -10 42798 -527 771 1338 65437 811 41.2 14 96 29400 0 169 0 0 2951 -475
    178 ######## 2132 FE2C 5 98 6770 6940 25140 -475 40.5 1 0 65535 7131 7301 855 65535 -10 42786 -527 771 1338 65438 819 41.2 14 96 29400 0 170 0 0 2951 -467
    179 ######## 2144 FE2B 5 98 6769 6940 25128 -471 40.4 1 0 65535 7130 7301 864 65535 -10 42780 -527 771 1337 65437 810 41.2 14 96 29400 0 171 0 0 2951 -471
    180 ######## 2156 FE2A 5 98 6767 6940 25128 -469 40.6 1 0 65535 7128 7301 866 65535 -10 42768 -527 770 1337 65439 827 41.2 14 96 29400 0 173 0 0 2951 -465
    181 ######## 2168 FE2C 5 98 6766 6940 25128 -468 40.2 1 0 65535 7127 7301 867 65535 -10 42762 -527 770 1337 65437 810 41.1 14 96 29400 0 174 0 0 2951 -467
    182 ######## 2180 FE2E 5 98 6765 6940 25128 -467 40.3 1 0 65535 7126 7301 869 65535 -10 42756 -527 770 1337 65438 819 41.1 14 96 29400 0 175 0 0 2951 -467
    183 ######## 2192 FE2E 5 98 6763 6940 25128 -467 40.4 1 0 65535 7124 7301 869 65535 -10 42744 -527 770 1336 65438 818 41.1 14 96 29400 0 177 0 0 2951 -465
    184 ######## 2204 FE2E 5 98 6761 6940 25128 -467 40.3 1 0 65535 7122 7301 869 65535 -10 42732 -527 770 1336 65438 818 41.1 14 96 29400 0 179 0 0 2951 -466
    185 ######## 2216 FE2F 5 98 6759 6940 25128 -467 40.3 1 0 65535 7120 7301 868 65535 -10 42720 -527 770 1335 65439 826 41.3 14 96 29400 0 181 0 0 2951 -465
    186 ######## 2228 FE30 5 98 6758 6940 25128 -466 40.6 1 0 65535 7119 7301 870 65535 -10 42714 -527 769 1335 65439 826 41.4 14 96 29400 0 182 0 0 2951 -467
    187 ######## 2240 FE2E 5 98 6757 6940 25128 -466 40.5 1 0 65535 7118 7301 870 65535 -10 42708 -527 769 1335 65438 817 41.4 14 96 29400 0 183 0 0 2951 -465
    188 ######## 2252 FE2E 5 98 6755 6940 25128 -466 40.7 1 0 65535 7116 7301 870 65535 -10 42696 -527 769 1334 65439 825 41.5 14 96 29400 0 185 0 0 2951 -467
    189 ######## 2264 FE30 5 98 6754 6940 25128 -466 40.6 1 0 65535 7115 7301 870 65535 -10 42690 -527 769 1334 65438 817 41.4 14 96 29400 0 186 0 0 2951 -467
    190 ######## 2276 FE2F 5 98 6751 6940 25116 -467 40.7 1 0 65535 7112 7301 867 65535 -10 42672 -527 769 1334 65438 817 41.6 14 96 29400 0 189 0 0 2951 -467
    191 ######## 2288 FE2D 5 98 6750 6940 25116 -467 40.6 1 0 65535 7111 7301 867 65535 -10 42666 -527 769 1333 65439 825 41.4 14 96 29400 0 190 0 0 2951 -465
    192 ######## 2300 FE2E 5 98 6749 6940 25104 -466 40.5 1 0 65535 7110 7301 869 65535 -10 42660 -527 768 1333 65438 816 41.3 14 96 29400 0 191 0 0 2951 -468
    193 ######## 2312 FE2E 5 98 6747 6940 25116 -466 40.6 1 0 65535 7108 7301 869 65535 -10 42648 -527 768 1333 65439 825 41.3 14 96 29400 0 193 0 0 2951 -468
    194 ######## 2324 FE23 5 98 6746 6940 25092 -468 40.8 1 0 65535 7107 7301 865 65535 -10 42642 -527 768 1333 65434 784 41.5 14 96 29400 0 194 0 0 2951 -490
    195 ######## 2336 FE25 5 98 6745 6940 25104 -476 40.7 1 0 65535 7106 7301 848 65535 -10 42630 -527 768 1332 65435 791 41.5 14 96 29400 0 196 0 0 2951 -477
    196 ######## 2348 FE2C 5 98 6742 6940 25104 -472 40.8 1 0 65535 7103 7301 857 65535 -10 42618 -527 768 1332 65438 816 41.6 14 96 29400 0 198 0 0 2951 -473
    197 ######## 2360 FE29 5 98 6741 6940 25104 -472 40.6 1 0 65535 7101 7301 857 65535 -10 42606 -527 767 1331 65437 807 41.6 14 96 29400 0 200 0 0 2951 -470
    198 ######## 2372 FE2C 5 98 6739 6940 25104 -470 40.6 1 0 65535 7100 7301 858 65535 -10 42600 -527 767 1331 65437 807 41.5 14 96 29400 0 201 0 0 2951 -471
    199 ######## 2385 FE2A 5 98 6738 6940 25104 -470 41 1 0 65535 7099 7301 860 65535 -10 42594 -527 767 1331 65438 815 41.6 14 96 29400 0 202 0 0 2951 -470
    200 ######## 2397 FE29 5 98 6737 6940 25104 -470 41 1 0 65535 7098 7301 860 65535 -10 42588 -527 767 1330 65437 806 41.7 14 96 29400 0 204 0 0 2951 -469
    201 ######## 2409 FE29 5 98 6735 6940 25104 -471 41 1 0 65535 7096 7301 858 65535 -10 42576 -527 767 1330 65437 806 41.8 14 96 29400 0 205 0 0 2951 -472
    202 ######## 2421 FE29 5 98 6734 6940 25092 -470 41.1 1 0 65535 7095 7301 860 65535 -10 42570 -527 767 1330 65438 814 41.9 14 96 29400 0 206 0 0 2951 -470
    203 ######## 2433 FE28 5 97 6728 6937 25092 -471 41.5 1 0 65535 7087 7296 857 65535 -10 42522 -527 766 1327 65437 804 41.9 14 96 29400 0 209 0 0 2951 -479
    204 ######## 2445 FE21 5 97 6727 6937 25080 -477 41.2 1 0 65535 7086 7296 846 65535 -10 42516 -527 766 1327 65437 804 41.8 14 96 29400 0 210 0 0 2951 -474
    205 ######## 2457 FE29 5 97 6725 6937 25080 -474 41.2 1 0 65535 7084 7296 851 65535 -10 42504 -527 766 1327 65438 812 41.9 14 96 29400 0 212 0 0 2951 -468
    206 ######## 2469 FE26 5 97 6724 6937 25080 -474 41.3 1 0 65535 7083 7296 851 65535 -10 42498 -527 766 1327 65438 812 42.1 14 96 29400 0 213 0 0 2951 -475
    207 ######## 2481 FE23 5 97 6723 6937 25080 -474 41.5 1 0 65535 7082 7296 853 65535 -10 42492 -527 765 1326 65437 804 42.1 14 96 29400 0 215 0 0 2951 -473
    208 ######## 2493 FE03 5 97 6721 6937 25056 -484 41.5 1 0 65535 7080 7296 833 65535 -10 42480 -527 765 1326 65431 758 42.2 14 96 29400 0 216 0 0 2951 -502
    209 ######## 2505 FE2B 5 97 6719 6937 25080 -483 41.4 1 0 65535 7078 7296 835 65535 -10 42462 -527 765 1325 65438 811 42.3 14 96 29400 0 219 0 0 2951 -469
    210 ######## 2517 FE2C 5 97 6717 6937 25080 -476 42 1 0 65535 7076 7296 847 65535 -10 42456 -527 765 1325 65438 811 42.4 14 96 29400 0 220 0 0 2951 -470
    211 ######## 2529 FE29 5 97 6716 6937 25080 -474 41.9 1 0 65535 7075 7296 850 65535 -10 42450 -527 765 1325 65438 811 42.4 14 96 29400 0 221 0 0 2951 -469
    212 ######## 2541 FE29 5 97 6714 6937 25080 -472 41.8 1 0 65535 7073 7296 853 65535 -10 42438 -527 764 1325 65438 811 42.2 14 96 29400 0 223 0 0 2951 -474
    213 ######## 2553 FE2C 5 97 6713 6937 25080 -471 41.6 1 0 65535 7072 7296 855 65535 -10 42432 -527 764 1324 65438 811 42.1 14 96 29400 0 224 0 0 2951 -470
    214 ######## 2565 FE2A 5 97 6712 6937 25080 -471 41.2 1 0 65535 7071 7296 855 65535 -10 42426 -527 764 1324 65438 811 41.9 14 96 29400 0 225 0 0 2951 -471
    215 ######## 2577 FE2B 5 97 6709 6937 25080 -471 41 1 0 65535 7068 7296 855 65535 -10 42408 -527 764 1323 65438 810 41.8 14 96 29400 0 228 0 0 2951 -507
    216 ######## 2589 FE0A 5 97 6708 6937 25044 -483 41 1 0 65535 7067 7296 833 65535 -10 42402 -527 764 1323 65432 763 41.8 14 96 29400 0 230 0 0 2951 -502
    217 ######## 2601 FE28 5 97 6706 6937 25056 -483 40.8 1 0 65535 7065 7296 833 65535 -10 42390 -527 763 1323 65437 802 41.7 14 96 29400 0 231 0 0 2951 -471
    218 ######## 2613 FE2B 5 97 6705 6937 25068 -477 41 1 0 65535 7064 7296 843 65535 -10 42384 -527 763 1323 65437 802 41.7 14 96 29400 0 232 0 0 2951 -481
    219 ######## 2625 FE29 5 97 6704 6937 25068 -475 40.9 1 0 65535 7063 7296 847 65535 -10 42378 -527 763 1322 65438 809 41.7 14 96 29400 0 234 0 0 2951 -471
    220 ######## 2637 FE28 5 97 6702 6937 25068 -473 40.9 1 0 65535 7061 7296 850 65535 -10 42366 -527 763 1322 65437 801 41.6 14 96 29400 0 235 0 0 2951 -471
    221 ######## 2649 FE27 5 97 6699 6937 25056 -471 40.8 1 0 65535 7058 7296 853 65535 -10 42348 -527 763 1321 65431 755 41.6 14 96 29400 0 238 0 0 2951 -505
    222 ######## 2661 FDFD 5 97 6698 6937 25020 -485 40.9 1 0 65535 7057 7296 825 65535 -10 42342 -527 763 1321 65429 741 41.7 14 96 29400 0 239 0 0 2951 -522
    223 ######## 2673 FE29 5 97 6697 6937 25056 -487 40.9 1 0 65535 7056 7296 827 65535 -10 42336 -527 762 1321 65438 809 41.7 14 96 29400 0 241 0 0 2951 -470
    224 ######## 2685 FE29 5 97 6695 6937 25056 -479 41.1 1 0 65535 7054 7296 839 65535 -10 42324 -527 762 1321 65436 793 41.9 14 96 29400 0 242 0 0 2951 -479
    225 ######## 2697 FE1E 5 97 6694 6937 25032 -479 41.1 1 0 65535 7053 7296 838 65535 -10 42318 -527 762 1320 65437 800 41.7 14 96 29400 0 243 0 0 2951 -475
    226 ######## 2709 FE2C 5 97 6693 6937 25056 -475 41 1 0 65535 7051 7296 845 65535 -10 42306 -527 762 1320 65436 792 41.8 14 96 29400 0 245 0 0 2951 -480
    227 ######## 2721 FE27 5 97 6691 6937 25056 -480 41 1 0 65535 7050 7296 836 65535 -10 42300 -527 762 1320 65438 808 41.8 14 96 29400 0 246 0 0 2951 -474
    228 ######## 2733 FE2C 5 97 6688 6937 25056 -474 40.8 1 0 65535 7047 7296 847 65535 -10 42282 -527 761 1319 65438 808 41.7 14 96 29400 0 249 0 0 2951 -468
    229 ######## 2745 FE13 5 97 6687 6937 25008 -480 40.9 1 0 65535 7046 7296 834 65535 -10 42276 -527 761 1319 65432 761 41.7 14 96 29400 0 250 0 0 2951 -496
    230 ######## 2758 FE19 5 97 6686 6937 25032 -483 40.9 1 0 65535 7045 7296 831 65535 -10 42270 -527 761 1318 65435 783 41.7 14 96 29400 0 252 0 0 2951 -483
    231 ######## 2770 FE2B 5 97 6684 6937 25044 -478 40.7 1 0 65535 7043 7296 841 65535 -10 42258 -527 761 1318 65439 815 41.6 14 96 29400 0 253 0 0 2951 -467
    232 ######## 2782 FE2D 5 97 6683 6937 25044 -472 40.8 1 0 65535 7042 7296 850 65535 -10 42252 -527 761 1318 65439 815 41.7 14 96 29400 0 254 0 0 2951 -466
    233 ######## 2794 FE2F 5 97 6682 6937 25044 -470 41 1 0 65535 7041 7296 853 65535 -10 42240 -527 761 1318 65439 815 41.7 14 96 29400 0 256 0 0 2951 -467
    234 ######## 2806 FE2C 5 97 6679 6937 25044 -468 40.8 1 0 65535 7038 7296 856 65535 -10 42228 -527 760 1317 65439 815 41.5 14 96 29400 0 258 0 0 2951 -467
    235 ######## 2818 FE2C 5 97 6677 6937 25032 -471 40.8 1 0 65535 7036 7296 851 65535 -10 42216 -527 760 1317 65439 815 41.6 14 96 29400 0 260 0 0 2951 -466
    236 ######## 2830 FE2C 5 97 6676 6937 25032 -469 40.8 1 0 65535 7035 7296 854 65535 -10 42210 -527 760 1317 65439 815 41.5 14 96 29400 0 261 0 0 2951 -466
    237 ######## 2842 FE2D 5 97 6675 6937 25032 -468 40.9 1 0 65535 7034 7296 856 65535 -10 42204 -527 760 1316 65439 814 41.6 14 96 29400 0 262 0 0 2951 -466
    238 ######## 2854 FE2C 5 97 6673 6937 25032 -468 40.9 1 0 65535 7032 7296 856 65535 -10 42192 -527 760 1316 65438 806 41.6 14 96 29400 0 264 0 0 2951 -466
    239 ######## 2866 FE2F 5 97 6672 6937 25032 -467 40.5 1 0 65535 7031 7296 857 65535 -10 42186 -527 760 1316 65438 806 41.6 14 96 29400 0 265 0 0 2951 -470
    240 ######## 2878 FE2C 5 97 6669 6937 25032 -468 40.6 1 0 65535 7028 7296 855 65535 -10 42168 -527 759 1315 65439 813 41.4 14 96 29400 0 268 0 0 2951 -468
    241 ######## 2890 FE2B 5 97 6668 6937 25032 -468 40.7 1 0 65535 7027 7296 855 65535 -10 42162 -527 759 1315 65439 813 41.5 14 96 29400 0 269 0 0 2951 -466
    242 ######## 2902 FE2E 5 97 6667 6937 25032 -468 40.8 1 0 65535 7026 7296 857 65535 -10 42156 -527 759 1315 65439 813 41.5 14 96 29400 0 271 0 0 2951 -467
    243 ######## 2914 FE28 5 97 6665 6937 25032 -467 40.6 1 0 65535 7024 7296 856 65535 -10 42144 -527 759 1314 65439 813 41.5 14 96 29400 0 272 0 0 2951 -466
    244 ######## 2926 FE2D 5 97 6664 6937 25032 -467 40.6 1 0 65535 7023 7296 856 65535 -10 42138 -527 759 1314 65439 813 41.4 14 96 29400 0 273 0 0 2951 -467
    245 ######## 2939 FE2C 5 97 6663 6937 25020 -467 40.4 1 0 65535 7022 7296 856 65535 -10 42132 -527 759 1314 65439 813 41.3 14 96 29400 0 275 0 0 2951 -466
    246 ######## 2953 FE2F 5 97 6660 6937 25020 -467 40.4 1 0 65535 7019 7296 856 65535 -10 42114 -527 758 1313 65439 812 41.3 14 96 29400 0 277 0 0 2951 -466
    247 ######## 2965 FE2E 5 96 6659 6937 25020 -467 40.7 1 0 65535 7018 7296 856 65535 -10 42108 -527 758 1313 65439 812 41.3 14 96 29400 0 279 0 0 2951 -468
    248 ######## 2977 FE2C 5 96 6657 6937 25020 -467 40.3 1 0 65535 7016 7296 855 65535 -10 42096 -527 758 1313 65438 804 41.2 14 96 29400 0 280 0 0 2951 -465
    249 ######## 2989 FE2B 5 96 6656 6937 25020 -467 40.2 1 0 65535 7015 7296 855 65535 -10 42090 -527 758 1312 65438 803 41.1 14 96 29400 0 281 0 0 2951 -467
    250 ######## 3001 FE2E 5 96 6654 6937 25008 -467 40.2 1 0 65535 7013 7296 855 65535 -10 42078 -527 758 1312 65439 812 41.1 14 96 29400 0 283 0 0 2951 -468
    251 ######## 3016 FE2B 5 96 6652 6937 25008 -470 40.2 1 0 65535 7011 7296 849 65535 -10 42066 -527 757 1312 65439 812 41.1 14 96 29400 0 285 0 0 2951 -467
    252 ######## 3028 FE2C 5 96 6650 6937 25008 -469 40.1 1 0 65535 7009 7296 851 65535 -10 42054 -527 757 1311 65439 811 41.1 14 96 29400 0 287 0 0 2951 -466
    253 ######## 3040 FE2E 5 96 6649 6937 25008 -468 40.1 1 0 65535 7008 7296 852 65535 -10 42048 -527 757 1311 65439 811 41.1 14 96 29400 0 288 0 0 2951 -467
    254 ######## 3052 FE2C 5 96 6648 6937 25008 -467 40.2 1 0 65535 7007 7296 854 65535 -10 42042 -527 757 1311 65439 811 41.2 14 96 29400 0 289 0 0 2951 -466
    255 ######## 3064 FE2F 5 96 6646 6937 25008 -467 40 1 0 65535 7005 7296 854 65535 -10 42030 -527 757 1310 65439 810 41.1 14 96 29400 0 291 0 0 2951 -470
    256 ######## 3078 FE1A 5 96 6644 6937 24984 -481 40.4 1 0 65535 7003 7296 829 65535 -10 42012 -542 735 1310 65436 786 41.1 14 96 29400 0 294 0 0 2951 -474
    257 ######## 3090 FE27 5 96 6642 6937 24984 -480 40.2 1 0 65535 7001 7296 827 65535 -10 42006 -542 735 1309 65431 748 41.1 14 96 29400 0 295 0 0 2951 -477
    258 ######## 3102 FE1A 5 96 6641 6937 24984 -481 40.4 1 0 65535 7000 7296 828 65535 -10 42000 -542 735 1309 65438 801 41.1 14 96 29400 0 296 0 0 2951 -472
    259 ######## 3114 FE28 5 96 6639 6937 24996 -477 40.3 1 0 65535 6998 7296 835 65535 -10 41988 -542 735 1309 65437 793 41.2 14 96 29400 0 298 0 0 2951 -476
    260 ######## 3126 FE25 5 96 6638 6937 24996 -474 40.6 1 0 65535 6997 7296 840 65535 -10 41982 -542 735 1309 65437 793 41.3 14 96 29400 0 299 0 0 2951 -476
    261 ######## 3141 FE22 5 96 6635 6937 24984 -475 40.5 1 0 65535 6994 7296 836 65535 -10 41964 -542 735 1308 65436 785 41.4 14 96 29400 0 302 0 0 2951 -477
    262 ######## 3153 FE28 5 96 6634 6937 24972 -476 41 1 0 65535 6993 7296 836 65535 -10 41958 -542 734 1308 65435 777 41.6 14 96 29400 0 303 0 0 2951 -472
    263 ######## 3165 FE28 5 96 6633 6937 24984 -474 41.2 1 0 65535 6992 7296 840 65535 -10 41946 -542 734 1307 65437 792 41.8 14 96 29400 0 305 0 0 2951 -471
    264 ######## 3177 FE15 5 96 6631 6937 24984 -475 41.1 1 0 65535 6990 7296 838 65535 -10 41940 -542 734 1307 65435 776 41.8 14 96 29400 0 306 0 0 2951 -491
    265 ######## 3189 FE21 5 96 6630 6937 24984 -478 41 1 0 65535 6989 7296 832 65535 -10 41934 -542 734 1307 65436 784 41.8 14 96 29400 0 307 0 0 2951 -478
    266 ######## 3203 FE2A 5 96 6627 6937 24984 -472 41.2 1 0 65535 6986 7296 842 65535 -10 41916 -542 734 1306 65438 800 41.9 14 96 29400 0 310 0 0 2951 -471
    267 ######## 3215 FE13 5 96 6626 6937 24960 -473 41.2 1 0 65535 6985 7296 841 65535 -10 41910 -542 734 1306 65436 784 42.1 14 96 29400 0 311 0 0 2951 -481
    268 ######## 3227 FE26 5 96 6624 6937 24972 -476 41.6 1 0 65535 6983 7296 833 65535 -10 41898 -542 733 1306 65433 761 42.2 14 96 29400 0 313 0 0 2951 -507
    269 ######## 3239 FE26 5 96 6623 6937 24972 -478 41.8 1 0 65535 6982 7296 831 65535 -10 41892 -542 733 1306 65435 776 42.3 14 96 29400 0 314 0 0 2951 -484
    270 ######## 3252 FE16 5 96 6622 6937 24960 -479 41.7 1 0 65535 6981 7296 829 65535 -10 41886 -542 733 1305 65431 739 42.2 14 96 29400 0 316 0 0 2951 -509
    271 ######## 3264 FE28 5 96 6620 6937 24972 -480 41.7 1 0 65535 6979 7296 826 65535 -10 41874 -542 733 1305 65434 768 42.3 14 96 29400 0 317 0 0 2951 -486
    272 ######## 3276 FE24 5 96 6617 6937 24972 -485 41.7 1 0 65535 6976 7296 817 65535 -10 41856 -542 733 1304 65431 745 42.4 14 96 29400 0 320 0 0 2951 -481
    273 ######## 3288 FE20 5 96 6616 6937 24960 -483 41.6 1 0 65535 6975 7296 822 65535 -10 41850 -542 732 1304 65437 790 42.4 14 96 29400 0 321 0 0 2951 -484
    274 ######## 3300 FE18 5 96 6615 6937 24948 -483 41.7 1 0 65535 6974 7296 822 65535 -10 41844 -542 732 1304 65434 760 42.4 14 96 29400 0 323 0 0 2951 -495
    275 ######## 3312 FE14 5 96 6613 6937 24948 -484 41.9 1 0 65535 6972 7296 820 65535 -10 41832 -542 732 1303 65434 752 42.4 14 96 29400 0 324 0 0 2951 -477
    276 ######## 3324 FE26 5 96 6612 6937 24960 -482 41.7 1 0 65535 6971 7296 825 65535 -10 41826 -542 732 1303 65437 790 42.3 14 96 29400 0 325 0 0 2951 -474
    277 ######## 3336 FE29 5 96 6611 6937 24960 -477 41.8 1 0 65535 6970 7296 832 65535 -10 41820 -542 732 1303 65437 790 42.3 14 96 29400 0 327 0 0 2951 -478
    278 ######## 3348 FE2A 5 96 6608 6937 24960 -475 41.2 1 0 65535 6967 7296 835 65535 -10 41802 -542 732 1302 65438 797 42 14 96 29400 0 329 0 0 2951 -468
    279 ######## 3360 FE1F 5 96 6607 6937 24960 -477 41.2 1 0 65535 6965 7296 829 65535 -10 41790 -542 731 1302 65435 773 41.9 14 96 29400 0 331 0 0 2951 -486
    280 ######## 3372 FE0E 5 96 6605 6937 24948 -483 41.3 1 0 65535 6964 7296 820 65535 -10 41784 -542 731 1302 65435 773 42.1 14 96 29400 0 332 0 0 2951 -512
    281 ######## 3384 FE05 5 96 6604 6937 24924 -499 41.5 1 0 65535 6963 7296 794 65535 -10 41778 -542 731 1302 65431 744 42.2 14 96 29400 0 333 0 0 2951 -525
    282 ######## 3396 FE1A 5 96 6601 6937 24936 -491 41.8 1 0 65535 6960 7296 807 65535 -10 41760 -543 729 1301 65436 781 42.3 14 96 29400 0 336 0 0 2951 -483
    283 ######## 3408 FE26 5 96 6600 6937 24948 -484 41.7 1 0 65535 6959 7296 818 65535 -10 41754 -543 729 1301 65438 797 42.3 14 96 29400 0 337 0 0 2951 -470
    284 ######## 3420 FE24 5 96 6599 6937 24948 -479 41.8 1 0 65535 6958 7296 827 65535 -10 41748 -543 729 1301 65437 788 42.3 14 96 29400 0 339 0 0 2951 -474
    285 ######## 3432 FE24 5 96 6597 6937 24948 -477 41.8 1 0 65535 6956 7296 830 65535 -10 41736 -543 729 1300 65436 780 42.3 14 96 29400 0 340 0 0 2951 -479
    286 ######## 3444 FE28 5 96 6595 6937 24948 -476 41.9 1 0 65535 6954 7296 831 65535 -10 41724 -543 729 1300 65437 788 42.3 14 96 29400 0 342 0 0 2951 -474
    287 ######## 3456 FE25 5 96 6593 6937 24948 -475 41.8 1 0 65535 6952 7296 833 65535 -10 41712 -543 729 1299 65437 787 42.3 14 96 29400 0 344 0 0 2951 -475
    288 ######## 3468 FE28 5 96 6592 6937 24948 -475 41.9 1 0 65535 6951 7296 833 65535 -10 41706 -543 728 1299 65438 795 42.4 14 96 29400 0 345 0 0 2951 -476
    289 ######## 3480 FE26 5 96 6591 6937 24948 -476 41.8 1 0 65535 6950 7296 831 65535 -10 41700 -543 728 1299 65438 795 42.4 14 96 29400 0 346 0 0 2951 -473
    290 ######## 3492 FE26 5 95 6590 6937 24936 -475 41.8 101 0 65535 6949 7296 832 65535 -10 41694 -543 728 1299 65437 787 42.4 14 96 29400 3750 347 0 0 2951 -472
    291 ######## 3504 FE26 5 95 6587 6937 24936 -474 41.6 101 0 65535 6946 7296 834 65535 -10 41676 -543 728 1298 65438 795 42.4 14 96 29400 3750 350 0 0 2951 -473
    292 ######## 3516 FE22 5 95 6586 6937 24936 -474 41.8 101 0 65535 6945 7296 834 65535 -10 41670 -543 728 1298 65437 787 42.4 14 96 29400 3750 351 0 0 2951 -476
    293 ######## 3528 FE26 5 95 6585 6937 24936 -474 41.7 101 0 65535 6944 7296 834 65535 -10 41658 -543 728 1297 65437 786 42.3 14 96 29400 3750 353 0 0 2951 -475
    294 ######## 3540 FE24 5 95 6583 6937 24924 -474 41.6 101 0 65535 6942 7296 833 65535 -10 41652 -543 727 1297 65438 794 42.2 14 96 29400 3750 354 0 0 2951 -474
    295 ######## 3552 FE25 5 95 6581 6937 24936 -475 41 101 0 65535 6940 7296 831 65535 -10 41640 -543 727 1297 65435 770 41.9 14 96 29400 3750 356 0 0 2951 -483
    296 ######## 3564 FE27 5 95 6580 6937 24924 -476 40.9 101 0 65535 6939 7296 831 65535 -10 41628 -543 727 1296 65438 793 41.8 14 96 29400 3750 358 0 0 2951 -475
    297 ######## 3576 FE26 5 95 6578 6937 24924 -475 40.7 101 0 65535 6937 7296 831 65535 -10 41622 -543 727 1296 65436 778 41.6 14 96 29400 3750 359 0 0 2951 -482
    298 ######## 3588 FE11 5 95 6577 6937 24912 -479 39.9 101 0 65535 6936 7296 824 65535 -10 41616 -543 727 1296 65433 755 41.3 14 96 29400 3750 360 0 0 2951 -485
    299 ######## 3600 FE1F 5 95 6574 6937 24924 -490 39.9 101 0 65535 6933 7296 805 65535 -10 41598 -546 722 1295 65437 785 41 14 96 29400 3750 363 0 0 2951 -498
    300 ######## 3612 FE1F 5 95 6573 6937 24924 -490 39.7 101 0 65535 6932 7296 807 65535 -10 41592 -546 722 1295 65437 785 40.8 14 96 29400 3750 364 0 0 2951 -476
    301 ######## 3624 FE26 5 95 6571 6937 24924 -482 39.7 101 0 65535 6930 7296 818 65535 -10 41580 -546 722 1295 65438 793 40.8 14 96 29400 3750 366 0 0 2951 -473
    302 ######## 3636 FE22 5 95 6570 6937 24924 -478 39.8 101 0 65535 6929 7296 825 65535 -10 41574 -546 722 1295 65437 785 40.8 14 96 29400 3750 367 0 0 2951 -478
    303 ######## 3648 FE28 5 95 6569 6937 24924 -476 39.7 101 0 65535 6928 7296 828 65535 -10 41568 -546 722 1294 65437 784 40.7 14 96 29400 3750 368 0 0 2951 -472
    304 ######## 3660 FE27 5 95 6567 6937 24924 -474 39.8 101 0 65535 6926 7296 831 65535 -10 41556 -546 722 1294 65437 784 40.7 14 96 29400 3750 370 0 0 2951 -473
    305 ######## 3672 FE27 5 95 6565 6937 24924 -475 39.8 101 0 65535 6924 7296 829 65535 -10 41544 -546 721 1293 65438 792 40.7 14 96 29400 3750 372 0 0 2951 -480
    306 ######## 3684 FE1C 5 95 6563 6937 24900 -482 40 101 0 65535 6922 7296 817 65535 -10 41532 -546 721 1293 65437 784 40.8 14 96 29400 3750 374 0 0 2951 -477
    307 ######## 3696 FE20 5 95 6562 6937 24912 -479 39.9 101 0 65535 6921 7296 822 65535 -10 41526 -546 721 1293 65436 776 40.7 14 96 29400 3750 375 0 0 2951 -482
    308 ######## 3708 FE1D 5 95 6561 6937 24900 -481 39.7 101 0 65535 6920 7296 818 65535 -10 41520 -546 721 1293 65437 784 40.6 14 96 29400 3750 376 0 0 2951 -500
    309 ######## 3721 FE28 5 95 6559 6937 24912 -483 39.8 101 0 65535 6918 7296 815 65535 -10 41508 -546 721 1292 65438 791 40.6 14 96 29400 3750 378 0 0 2951 -471
    310 ######## 3733 FE1D 5 95 6557 6937 24888 -492 39.8 101 0 65535 6916 7296 800 65535 -10 41496 -546 720 1292 65432 745 40.6 14 96 29400 3750 381 0 0 2951 -500
    311 ######## 3745 FE1F 5 95 6555 6937 24900 -490 40 101 0 65535 6914 7296 803 65535 -10 41484 -546 720 1291 65434 759 40.8 14 96 29400 3750 382 0 0 2951 -486
    312 ######## 3757 FE1C 5 95 6554 6937 24900 -486 40.1 101 0 65535 6913 7296 809 65535 -10 41478 -546 720 1291 65437 782 40.8 14 96 29400 3750 383 0 0 2951 -475
    313 ######## 3769 FE2B 5 95 6553 6937 24912 -480 40.3 101 0 65535 6911 7296 819 65535 -10 41466 -546 720 1291 65437 782 41 14 96 29400 3750 385 0 0 2951 -481
    314 ######## 3781 FE24 5 95 6551 6937 24900 -480 40.4 101 0 65535 6910 7296 819 65535 -10 41460 -546 720 1291 65437 782 41.2 14 96 29400 3750 386 0 0 2951 -487
    315 ######## 3793 FE24 5 95 6550 6937 24900 -478 40.6 101 0 65535 6909 7296 822 65535 -10 41454 -546 720 1290 65437 782 41.2 14 96 29400 3750 387 0 0 2951 -475
    316 ######## 3805 FE29 5 95 6547 6937 24900 -477 41 101 0 65535 6906 7296 824 65535 -10 41436 -546 719 1290 65437 782 41.5 14 96 29400 3750 390 0 0 2951 -486
    317 ######## 3817 FE27 5 95 6546 6937 24900 -477 41 101 0 65535 6905 7296 823 65535 -10 41430 -546 719 1290 65438 790 41.5 14 96 29400 3750 392 0 0 2951 -474
    318 ######## 3829 FE26 5 95 6544 6937 24900 -476 41.1 101 0 65535 6903 7296 827 65535 -10 41418 -546 719 1289 65438 789 41.6 14 96 29400 3750 393 0 0 2951 -484
    319 ######## 3841 FE25 5 95 6543 6937 24900 -476 41.3 101 0 65535 6902 7296 825 65535 -10 41412 -546 719 1289 65437 781 41.7 14 96 29400 3750 394 0 0 2951 -477
    320 ######## 3853 FE21 5 95 6542 6937 24900 -475 41.3 101 0 65535 6901 7296 824 65535 -10 41400 -546 719 1289 65437 781 41.8 14 96 29400 3750 396 0 0 2951 -475
    321 ######## 3865 FE22 5 95 6540 6937 24900 -474 41.4 101 0 65535 6899 7296 828 65535 -10 41394 -546 719 1288 65436 773 41.8 14 96 29400 3750 397 0 0 2951 -482
    322 ######## 3877 FE28 5 95 6539 6937 24900 -474 41.5 101 0 65535 6898 7296 828 65535 -10 41388 -546 719 1288 65439 797 41.9 14 96 29400 3750 398 0 0 2951 -469
    323 ######## 3889 FE25 5 95 6536 6937 24888 -476 41.5 101 0 65535 6895 7296 824 65535 -10 41370 -546 718 1287 65437 780 42 14 96 29400 3750 401 0 0 2951 -476
    324 ######## 3901 FE1D 5 95 6535 6937 24876 -476 41.7 101 0 65535 6894 7296 824 65535 -10 41364 -546 718 1287 65439 796 42 14 96 29400 3750 402 0 0 2951 -471
    325 ######## 3913 FE1F 5 95 6533 6937 24876 -479 41.3 101 0 65535 6892 7296 818 65535 -10 41352 -546 718 1287 65436 772 41.9 14 96 29400 3750 404 0 0 2951 -478
    326 ######## 3925 FE1F 5 95 6532 6937 24876 -479 41.1 101 0 65535 6891 7296 818 65535 -10 41346 -546 718 1287 65437 780 41.9 14 96 29400 3750 405 0 0 2951 -478
    327 ######## 3937 FE22 5 95 6531 6937 24876 -479 41.4 101 0 65535 6890 7296 818 65535 -10 41334 -546 718 1286 65438 787 41.8 14 96 29400 3750 407 0 0 2951 -469
    328 ######## 3949 FE1D 5 95 6529 6937 24888 -475 41.5 101 0 65535 6888 7296 823 65535 -10 41328 -546 717 1286 65436 772 41.9 14 96 29400 3750 408 0 0 2951 -480
    329 ######## 3961 FE27 5 95 6526 6937 24888 -475 41.1 101 0 65535 6885 7296 824 65535 -10 41310 -546 717 1285 65438 787 41.8 14 96 29400 3750 411 0 0 2951 -470
    330 ######## 3973 FE1C 5 95 6525 6937 24876 -476 41.3 101 0 65535 6884 7296 822 65535 -10 41304 -546 717 1285 65437 779 41.9 14 96 29400 3750 412 0 0 2951 -484
    331 ######## 3985 FE2C 5 95 6524 6937 24876 -475 41.7 101 0 65535 6883 7296 824 65535 -10 41298 -546 717 1285 65438 787 42 14 96 29400 3750 413 0 0 2951 -473
    332 ######## 3997 FE2C 5 95 6522 6937 24876 -473 41.5 101 0 65535 6881 7296 827 65535 -10 41286 -546 717 1285 65437 779 42 14 96 29400 3750 415 0 0 2951 -469
    333 ######## 4009 FE2A 5 95 6521 6937 24876 -472 41.5 101 0 65535 6880 7296 829 65535 -10 41280 -546 717 1284 65438 786 42.1 14 96 29400 3750 416 0 0 2951 -479
    334 ######## 4021 FE28 5 94 6520 6937 24876 -473 41.7 101 0 65535 6879 7296 827 65535 -10 41274 -546 716 1284 65438 786 42.1 14 96 29400 3750 417 0 0 2951 -473
    335 ######## 4033 FE23 5 94 6517 6937 24876 -474 41.2 101 0 65535 6876 7296 825 65535 -10 41256 -546 716 1284 65438 786 41.8 14 96 29400 3750 420 0 0 2951 -470
    336 ######## 4045 FE28 5 94 6516 6937 24876 -473 40.9 101 0 65535 6875 7296 828 65535 -10 41250 -546 716 1283 65439 794 41.8 14 96 29400 3750 422 0 0 2951 -469
    337 ######## 4057 FE28 5 94 6514 6937 24876 -471 41.2 101 0 65535 6873 7296 830 65535 -10 41238 -546 716 1283 65439 794 41.9 14 96 29400 3750 423 0 0 2951 -472
    338 ######## 4069 FE20 5 94 6513 6937 24876 -472 41.3 101 0 65535 6872 7296 828 65535 -10 41232 -546 716 1283 65438 786 41.8 14 96 29400 3750 424 0 0 2951 -469
    339 ######## 4081 FE28 5 94 6512 6937 24864 -474 41.4 101 0 65535 6871 7296 824 65535 -10 41226 -546 716 1282 65439 785 41.8 14 96 29400 3750 426 0 0 2951 -471
    340 ######## 4093 FE29 5 94 6510 6937 24876 -472 41.3 101 0 65535 6869 7296 828 65535 -10 41214 -546 715 1282 65438 785 41.9 14 96 29400 3750 427 0 0 2951 -471
    341 ######## 4105 FE2B 5 94 6509 6937 24876 -472 41.2 101 0 65535 6868 7296 827 65535 -10 41208 -546 715 1282 65437 777 41.8 14 96 29400 3750 428 0 0 2951 -478
    342 ######## 4118 FE2C 5 94 6506 6937 24876 -472 41.4 101 0 65535 6865 7296 827 65535 -10 41190 -546 715 1281 65439 792 41.9 14 96 29400 3750 431 0 0 2951 -470
    343 ######## 4130 FE2C 5 94 6505 6937 24876 -471 41.2 101 0 65535 6864 7296 829 65535 -10 41184 -546 715 1281 65439 792 41.9 14 96 29400 3750 432 0 0 2951 -469
    344 ######## 4142 FE2A 5 94 6503 6937 24864 -471 41.3 101 0 65535 6862 7296 828 65535 -10 41172 -546 715 1281 65438 784 41.9 14 96 29400 3750 434 0 0 2951 -471
    345 ######## 4154 FE1F 5 94 6502 6937 24852 -473 40.9 101 0 65535 6861 7296 825 65535 -10 41166 -546 715 1280 65437 776 41.7 14 96 29400 3750 435 0 0 2951 -476
    346 ######## 4166 FE20 5 94 6501 6937 24852 -476 40.5 101 0 65535 6860 7296 819 65535 -10 41160 -546 714 1280 65437 776 41.5 14 96 29400 3750 437 0 0 2951 -480
    347 ######## 4180 FE20 5 94 6498 6937 24852 -484 40.7 101 0 65535 6857 7296 806 65535 -10 41142 -546 714 1280 65435 760 41.5 14 96 29400 3750 439 0 0 2951 -478
    348 ######## 4192 FDED 5 94 6497 6937 24840 -493 41 101 0 65535 6855 7296 787 65535 -10 41130 -546 714 1279 65429 717 41.6 14 96 29400 3750 441 0 0 2951 -520
    349 ######## 4204 FE29 5 94 6495 6937 24852 -489 41 101 0 65535 6854 7296 797 65535 -10 41124 -546 714 1279 65437 767 41.7 14 96 29400 3750 442 0 0 2951 -484
    350 ######## 4216 FE1A 5 94 6494 6937 24852 -488 41 101 0 65535 6853 7296 798 65535 -10 41118 -546 714 1279 65435 760 41.8 14 96 29400 3750 443 0 0 2951 -488
    351 ######## 4228 FE27 5 94 6491 6937 24852 -485 41.2 101 0 65535 6850 7296 803 65535 -10 41100 -546 713 1278 65438 782 42 14 96 29400 3750 446 0 0 2951 -473
    352 ######## 4240 FE28 5 94 6490 6937 24852 -481 41.6 101 0 65535 6849 7296 810 65535 -10 41094 -546 713 1278 65437 775 42.1 14 96 29400 3750 447 0 0 2951 -470
    353 ######## 4252 FE26 5 94 6489 6937 24852 -476 41 101 0 65535 6847 7296 818 65535 -10 41082 -546 713 1278 65439 791 41.9 14 96 29400 3750 449 0 0 2951 -470
    354 ######## 4264 FE28 5 94 6487 6937 24852 -474 41.5 101 0 65535 6846 7296 821 65535 -10 41076 -546 713 1277 65438 782 42 14 96 29400 3750 450 0 0 2951 -471
    355 ######## 4276 FE27 5 94 6486 6937 24852 -473 41.7 101 0 65535 6845 7296 823 65535 -10 41070 -546 713 1277 65439 790 42 14 96 29400 3750 451 0 0 2951 -470
    356 ######## 4288 FE29 5 94 6485 6937 24840 -473 41.4 101 0 65535 6843 7296 822 65535 -10 41058 -546 713 1277 65439 790 42 14 96 29400 3750 453 0 0 2951 -474
    357 ######## 4300 FE26 5 94 6482 6937 24840 -472 41.6 101 0 65535 6841 7296 824 65535 -10 41046 -546 712 1276 65439 789 42 14 96 29400 3750 455 0 0 2951 -470
    358 ######## 4312 FE1E 5 94 6480 6937 24828 -475 41.3 101 0 65535 6839 7296 819 65535 -10 41034 -546 712 1276 65436 766 41.9 14 96 29400 3750 457 0 0 2951 -484
    359 ######## 4324 FE19 5 94 6479 6937 24828 -481 41 101 0 65535 6838 7296 808 65535 -10 41028 -546 712 1276 65435 758 41.7 14 96 29400 3750 458 0 0 2951 -487
    360 ######## 4336 FDFB 5 94 6478 6937 24804 -490 40.7 101 0 65535 6837 7296 793 65535 -10 41022 -546 712 1275 65426 695 41.5 14 96 29400 3750 460 0 0 2951 -534
    361 ######## 4348 FD35 5 94 6476 6937 24660 -566 40.2 101 0 65535 6835 7296 675 65535 -10 41010 -721 539 1275 65388 517 41.3 14 96 29400 3750 461 0 0 2951 -736
    362 ######## 4360 FD09 5 94 6474 6937 24612 -664 40.5 101 0 65535 6833 7296 585 65535 -10 40992 -765 508 1274 65379 487 41.4 14 96 29400 3750 464 0 0 2951 -763
    363 ######## 4372 FD0D 5 94 6471 6937 24624 -711 40.9 101 0 65535 6830 7296 544 65535 -10 40980 -765 508 1274 65381 493 41.5 14 96 29400 3750 466 0 0 2951 -757
    364 ######## 4384 FD09 5 94 6467 6937 24612 -751 40.7 101 0 65535 6826 7296 517 65535 -10 40956 -790 491 1273 65380 490 41.5 14 96 29400 3750 470 0 0 2951 -760
    365 ######## 4396 FD0C 5 94 6465 6937 24612 -756 41 101 0 65535 6824 7296 513 65535 -10 40944 -790 491 1273 65381 493 41.7 14 96 29400 3750 473 0 0 2951 -762
    366 ######## 4408 FD0E 5 94 6463 6937 24612 -757 41.6 101 0 65535 6822 7296 512 65535 -10 40932 -790 491 1272 65381 492 42 14 96 29400 3750 474 0 0 2951 -757
    367 ######## 4420 FD09 5 94 6461 6937 24612 -759 42 101 0 65535 6820 7296 511 65535 -10 40914 -790 491 1272 65380 489 42.4 14 96 29400 3750 477 0 0 2951 -761
    368 ######## 4432 FD05 5 94 6458 6937 24612 -762 42.9 101 0 65535 6817 7296 509 65535 -10 40902 -790 490 1271 65379 486 42.9 14 96 29400 3750 479 0 0 2951 -766
    369 ######## 4444 FD05 5 94 6456 6937 24612 -763 43.6 101 0 65535 6815 7296 508 65535 -10 40890 -790 490 1271 65378 483 43.4 14 96 29400 3750 481 0 0 2951 -768
    370 ######## 4457 FD00 5 94 6452 6937 24612 -766 45.5 801 0 65535 6811 7296 505 65535 -10 40866 -790 490 1270 65378 482 44.4 14 96 28200 2250 486 0 0 2951 -769
    371 ######## 4469 FD03 5 93 6449 6937 24588 -766 46.5 801 0 65535 6808 7296 505 65535 -10 40848 -790 490 1269 65379 485 45 14 96 28200 2250 488 0 0 2951 -772
    372 ######## 4481 FD03 5 93 6447 6937 24588 -767 47.1 801 0 65535 6806 7296 504 65535 -10 40836 -790 490 1269 65379 485 45.5 14 96 28200 2250 490 0 0 2951 -765
    373 ######## 4493 FD02 5 93 6445 6937 24588 -766 47.7 801 0 65535 6804 7296 505 65535 -10 40824 -790 489 1269 65378 482 45.9 14 96 28200 2250 492 0 0 2951 -773
    374 ######## 4505 FD01 5 93 6443 6937 24588 -767 48.4 801 0 65535 6802 7296 504 65535 -10 40812 -790 489 1268 65378 482 46.4 14 96 28200 2250 494 0 0 2951 -770
    375 ######## 4517 FD01 5 93 6441 6937 24576 -768 49.1 801 0 65535 6800 7296 503 65535 -10 40800 -790 489 1268 65378 482 46.9 14 96 28200 2250 497 0 0 2951 -772
    376 ######## 4529 FCFB 5 93 6436 6937 24576 -770 50 801 0 65535 6795 7296 502 65535 -10 40770 -790 489 1267 65378 481 47.7 14 96 28200 2250 501 0 0 2951 -771
    377 ######## 4541 FCFF 5 93 6434 6937 24576 -770 50.8 801 0 65535 6793 7296 501 65535 -10 40758 -790 489 1266 65378 481 48.1 14 96 28200 2250 503 0 0 2951 -771
    378 ######## 4553 FCFC 5 93 6432 6937 24576 -770 51.6 801 0 65535 6791 7298 501 65535 -10 40746 -790 489 1266 65379 484 48.5 14 96 28200 2250 506 0 0 2951 -771
    379 ######## 4565 FD01 5 93 6379 6887 24576 -770 51.7 801 0 65535 6790 7298 497 65535 -10 40740 -790 484 1253 65378 476 48.8 14 96 28200 2250 508 0 0 2951 -770
    380 ######## 4577 FCFC 5 93 6377 6887 24564 -771 52.1 801 0 65535 6788 7298 496 65535 -10 40728 -790 484 1253 65378 476 49.2 14 96 28200 2250 510 0 0 2951 -770
    381 ######## 4589 FD01 5 93 6375 6887 24564 -771 52.6 801 0 65535 6786 7298 496 65535 -10 40716 -790 484 1253 65378 476 49.5 14 96 28200 2250 512 0 0 2951 -774
    382 ######## 4601 FCFF 5 93 6373 6887 24564 -771 52.7 801 0 65535 6784 7298 496 65535 -10 40704 -790 484 1252 65378 475 49.8 14 96 28200 2250 514 0 0 2951 -772
    383 ######## 4613 FCFE 5 93 6368 6887 24564 -772 54 801 0 65535 6779 7298 495 65535 -10 40674 -792 482 1251 65378 475 50.4 14 96 28200 2250 519 0 0 2951 -776
    384 ######## 4625 FCDF 5 93 6366 6887 24540 -779 54.2 801 0 65535 6777 7298 490 65535 -10 40662 -811 471 1251 65375 466 50.7 14 96 28200 2250 521 0 0 2951 -785
    385 ######## 4637 FCFB 5 93 6364 6887 24552 -778 54.5 801 0 65535 6775 7298 491 65535 -10 40650 -811 471 1250 65377 472 51 14 96 28200 2250 523 0 0 2951 -784
    386 ######## 4649 FCFB 5 93 6361 6887 24552 -777 53.9 801 0 65535 6772 7298 491 65535 -10 40632 -811 471 1250 65378 475 50.9 14 96 28200 2250 526 0 0 2951 -785
    387 ######## 4661 FCF8 5 93 6359 6887 24552 -777 54.1 801 0 65535 6770 7298 491 65535 -10 40620 -811 470 1249 65377 471 51.1 14 96 28200 2250 528 0 0 2951 -777
    388 ######## 4673 FCFC 5 93 6357 6887 24552 -776 55.4 801 0 65535 6768 7298 492 65535 -10 40608 -811 470 1249 65377 471 51.5 14 96 0 0 530 0 0 2951 -779
    389 ######## 4685 FCF8 5 93 6355 6887 24552 -777 54.7 801 0 65535 6766 7298 491 65535 -10 40596 -811 470 1248 65377 471 51.6 14 96 28200 2250 532 0 0 2951 -778
    390 ######## 4697 FCFE 5 93 6350 6887 24552 -776 55.7 801 0 65535 6761 7298 491 65535 -10 40566 -811 470 1247 65378 474 51.9 14 96 0 0 537 0 0 2951 -772
    391 ######## 4709 FCF9 5 93 6348 6887 24540 -776 55.5 801 0 65535 6759 7298 491 65535 -10 40554 -811 470 1247 65378 474 52 14 96 0 0 539 0 0 2951 -781
    392 ######## 4721 FCF3 5 93 6346 6887 24528 -780 55.7 801 0 65535 6757 7298 488 65535 -10 40542 -811 469 1247 65376 468 52.1 14 96 0 0 541 0 0 2951 -785
    393 ######## 4733 FCF1 5 93 6344 6887 24540 -781 55.4 801 0 65535 6754 7298 487 65535 -10 40524 -811 469 1246 65376 467 52.1 14 96 0 0 544 0 0 2951 -779
    394 ######## 4745 FCF6 5 93 6341 6887 24528 -781 55.8 801 0 65535 6752 7298 487 65535 -10 40512 -811 469 1246 65376 467 52.3 14 96 0 0 546 0 0 2951 -781
    395 ######## 4757 FCF5 5 93 6339 6887 24516 -780 56.1 801 0 65535 6750 7298 488 65535 -10 40500 -811 469 1245 65376 467 52.4 14 96 0 0 548 0 0 2951 -782
    396 ######## 4769 FCF4 5 92 6335 6887 24516 -780 56.5 801 0 65535 6745 7298 487 65535 -10 40470 -811 469 1244 65377 469 52.7 14 96 0 0 553 0 0 2951 -781
    397 ######## 4782 FCF6 5 92 6332 6887 24516 -780 56.6 801 0 65535 6743 7298 487 65535 -10 40458 -811 468 1244 65377 469 52.9 14 96 0 0 555 0 0 2951 -780
    398 ######## 4794 FCF6 5 92 6330 6887 24516 -780 57.1 801 0 65535 6741 7298 487 65535 -10 40446 -811 468 1243 65377 466 53 14 96 0 0 557 0 0 2951 -783
    399 ######## 4806 FCF3 5 92 6328 6887 24516 -781 56.8 801 0 65535 6739 7298 486 65535 -10 40434 -811 468 1243 65377 469 53.1 14 96 0 0 559 0 0 2951 -784
    400 ######## 4818 FCF6 5 92 6326 6887 24516 -780 56.8 801 0 65535 6736 7298 487 65535 -10 40416 -811 468 1242 65377 469 53.1 14 96 0 0 562 0 0 2951 -784
    401 ######## 4830 FCF5 5 92 6323 6887 24504 -781 56.8 801 0 65535 6734 7298 486 65535 -10 40404 -811 468 1242 65376 466 53.2 14 96 0 0 564 0 0 2951 -788
    402 ######## 4842 FCF0 5 92 6321 6887 24504 -782 57 801 0 65535 6732 7298 485 65535 -10 40392 -811 468 1242 65376 466 53.2 14 96 0 0 566 0 0 2951 -784
    403 ######## 4854 FCF5 5 92 6317 6887 24504 -781 57.5 801 0 65535 6727 7298 485 65535 -10 40362 -811 467 1241 65377 468 53.4 14 96 0 0 571 0 0 2951 -782
    404 ######## 4866 FE15 5 92 6314 6887 24696 -720 57.6 801 0 65535 6725 7298 526 65535 -10 40350 -811 467 1240 65435 737 53.7 14 96 0 0 573 0 0 2951 -493
    405 ######## 4878 FE1B 5 92 6313 6887 24720 -605 58.2 801 0 65535 6724 7298 633 65535 -10 40344 -811 467 1240 65432 715 53.9 14 96 0 0 574 0 0 2951 -504
    406 ######## 4890 FE0C 5 92 6312 6887 24708 -550 57.6 801 0 65535 6723 7298 689 65535 -10 40338 -811 467 1239 65432 715 53.7 14 96 0 0 576 0 0 2951 -503
    407 ######## 4902 FE09 5 92 6310 6887 24696 -525 56.8 801 0 65535 6721 7298 721 65535 -10 40326 -811 467 1239 65432 715 53.3 14 96 0 0 577 0 0 2951 -505
    408 ######## 4914 FE0B 5 92 6309 6887 24696 -514 56.2 801 0 65535 6720 7298 736 65535 -10 40320 -811 467 1239 65432 715 52.9 14 96 0 0 579 0 0 2951 -506
    409 ######## 4926 FE07 5 92 6307 6887 24696 -510 56.1 801 0 65535 6718 7298 742 65535 -10 40308 -811 467 1239 65432 715 52.5 14 96 0 0 580 0 0 2951 -510
    410 ######## 4938 FD9B 5 92 6304 6887 24636 -560 54.6 801 0 65535 6715 7298 675 65535 -10 40290 -811 466 1238 65409 585 51.6 14 96 28200 2250 583 0 0 2951 -622
    411 ######## 4950 FD8C 5 92 6302 6887 24612 -594 53.7 801 0 65535 6713 7298 634 65535 -10 40278 -811 466 1238 65407 576 51.2 14 96 28200 2250 585 0 0 2951 -632
    412 ######## 4962 FD84 5 92 6300 6887 24600 -617 53.1 801 0 65535 6711 7298 613 65535 -10 40266 -811 466 1237 65405 567 50.9 14 96 28200 2250 587 0 0 2951 -640
    413 ######## 4974 FD82 5 92 6298 6887 24600 -628 53.1 801 0 65535 6709 7298 600 65535 -10 40254 -811 466 1237 65402 554 50.6 14 96 28200 2250 589 0 0 2951 -643
    414 ######## 4986 FD80 5 92 6296 6887 24588 -635 52.1 801 0 65535 6707 7298 595 65535 -10 40242 -811 466 1236 65405 566 50.3 14 96 28200 2250 591 0 0 2951 -642
    415 ######## 4998 FD85 5 92 6295 6887 24600 -637 51.9 801 0 65535 6705 7298 593 65535 -10 40230 -811 466 1236 65405 566 50.1 14 96 28200 2250 593 0 0 2951 -646
    416 ######## 5010 FD83 5 92 6293 6887 24600 -638 51.6 801 0 65535 6704 7298 592 65535 -10 40224 -811 466 1236 65405 566 49.9 14 96 28200 2250 595 0 0 2951 -643
    417 ######## 5022 FD82 5 92 6289 6887 24600 -639 51.6 801 0 65535 6700 7298 591 65535 -10 40200 -811 465 1235 65404 561 49.7 14 96 28200 2250 598 0 0 2951 -637
    418 ######## 5034 FD83 5 92 6287 6887 24600 -638 51 801 0 65535 6698 7298 590 65535 -10 40188 -811 465 1235 65404 561 49.5 14 96 28200 2250 600 0 0 2951 -639
    419 ######## 5047 FD84 5 92 6286 6887 24588 -638 50.9 801 0 65535 6696 7298 591 65535 -10 40176 -811 465 1234 65405 565 49.4 14 96 28200 2250 602 0 0 2951 -641
    420 ######## 5059 FD7D 5 92 6284 6887 24588 -639 51.2 801 0 65535 6694 7298 590 65535 -10 40164 -811 465 1234 65405 565 49.4 14 96 28200 2250 604 0 0 2951 -638
    421 ######## 5071 FD82 5 92 6282 6887 24576 -639 50.7 801 0 65535 6693 7298 590 65535 -10 40158 -811 465 1234 65406 570 49.2 14 96 28200 2250 606 0 0 2951 -642
    422 ######## 5083 FD7F 5 92 6280 6887 24588 -639 51 801 0 65535 6691 7298 590 65535 -10 40146 -811 465 1233 65405 565 49.2 14 96 28200 2250 607 0 0 2951 -638
    423 ######## 5095 FD83 5 92 6278 6887 24576 -638 50.8 801 0 65535 6689 7298 590 65535 -10 40134 -811 464 1233 65405 565 49.2 14 96 28200 2250 609 0 0 2951 -637
    424 ######## 5107 FD84 5 92 6274 6887 24576 -638 50.5 801 0 65535 6685 7298 590 65535 -10 40110 -811 464 1232 65406 560 49 14 96 28200 2250 613 0 0 2951 -643
    425 ######## 5119 FD82 5 92 6272 6887 24576 -638 50.5 801 0 65535 6683 7298 590 65535 -10 40098 -811 464 1231 65406 568 49 14 96 28200 2250 615 0 0 2951 -637
    426 ######## 5131 FD82 5 92 6271 6887 24576 -638 50.7 801 0 65535 6681 7298 590 65535 -10 40086 -811 464 1231 65405 564 49 14 96 28200 2250 617 0 0 2951 -638
    427 ######## 5143 FD84 5 92 6269 6887 24576 -638 50.9 801 0 65535 6680 7298 590 65535 -10 40080 -811 464 1231 65406 568 49 14 96 28200 2250 618 0 0 2951 -637
    428 ######## 5155 FD81 5 91 6267 6887 24576 -638 51 801 0 65535 6678 7298 589 65535 -10 40068 -811 464 1230 65406 568 49 14 96 28200 2250 620 0 0 2951 -637
    429 ######## 5167 FD86 5 91 6265 6887 24576 -638 51.1 801 0 65535 6676 7298 589 65535 -10 40056 -811 464 1230 65404 559 49.1 14 96 28200 2250 622 0 0 2951 -640
    430 ######## 5179 FD85 5 91 6263 6887 24576 -638 50.9 801 0 65535 6674 7298 589 65535 -10 40044 -811 463 1230 65405 563 49 14 96 28200 2250 624 0 0 2951 -642
    431 ######## 5191 FD88 5 91 6259 6887 24576 -637 50.6 801 0 65535 6670 7298 590 65535 -10 40020 -811 463 1229 65405 563 49 14 96 28200 2250 628 0 0 2951 -642
    432 ######## 5203 FD81 5 91 6258 6887 24576 -638 51.2 801 0 65535 6669 7298 589 65535 -10 40008 -811 463 1228 65405 562 49.1 14 96 28200 2250 630 0 0 2951 -637
    433 ######## 5215 FD84 5 91 6256 6887 24576 -637 51.5 801 0 65535 6667 7298 589 65535 -10 40002 -811 463 1228 65406 567 49.2 14 96 28200 2250 632 0 0 2951 -641
    434 ######## 5227 FD80 5 91 6254 6887 24564 -638 51.2 801 0 65535 6665 7298 588 65535 -10 39990 -811 463 1228 65405 562 49.2 14 96 28200 2250 633 0 0 2951 -639
    435 ######## 5239 FD82 5 91 6252 6887 24564 -638 51.1 801 0 65535 6663 7298 588 65535 -10 39978 -811 463 1227 65405 562 49.1 14 96 28200 2250 635 0 0 2951 -640
    436 ######## 5251 FD83 5 91 6250 6887 24564 -637 51 801 0 65535 6661 7298 589 65535 -10 39966 -811 462 1227 65405 562 49.1 14 96 28200 2250 637 0 0 2951 -636
    437 ######## 5263 FD85 5 91 6247 6887 24564 -637 50.6 801 0 65535 6658 7298 588 65535 -10 39948 -811 462 1226 65406 566 49 14 96 28200 2250 641 0 0 2951 -638
    438 ######## 5275 FD82 5 91 6245 6887 24564 -637 51.1 801 0 65535 6656 7298 588 65535 -10 39936 -811 462 1226 65406 566 49.1 14 96 28200 2250 643 0 0 2951 -634
    439 ######## 5287 FD6C 5 91 6243 6887 24552 -636 51.1 801 0 65535 6654 7298 589 65535 -10 39924 -811 462 1226 65408 575 49.1 14 96 28200 2250 644 0 0 2951 -624
    440 ######## 5299 FD8A 5 91 6241 6887 24552 -631 50.9 801 0 65535 6652 7298 593 65535 -10 39912 -811 462 1225 65408 574 49.1 14 96 28200 2250 646 0 0 2951 -628
    441 ######## 5311 FD93 5 91 6239 6887 24576 -629 51.2 801 0 65535 6650 7298 595 65535 -10 39900 -811 462 1225 65408 574 49.2 14 96 28200 2250 648 0 0 2951 -630
    442 ######## 5323 FD8F 5 91 6237 6887 24576 -627 51.1 801 0 65535 6648 7298 597 65535 -10 39888 -811 461 1224 65408 574 49.2 14 96 28200 2250 650 0 0 2951 -622
    443 ######## 5335 FD94 5 91 6236 6887 24564 -626 51.3 801 0 65535 6647 7298 598 65535 -10 39882 -811 461 1224 65409 578 49.2 14 96 28200 2250 652 0 0 2951 -629
    444 ######## 5347 FD94 5 91 6232 6887 24564 -624 51.1 801 0 65535 6643 7298 599 65535 -10 39858 -811 461 1223 65409 578 49.2 14 96 28200 2250 655 0 0 2951 -623
    445 ######## 5359 FD91 5 91 6230 6887 24564 -624 50.6 801 0 65535 6641 7298 599 65535 -10 39846 -811 461 1223 65409 578 49 14 96 28200 2250 657 0 0 2951 -623
    446 ######## 5371 FD90 5 91 6228 6887 24564 -624 50.5 801 0 65535 6639 7298 599 65535 -10 39834 -811 461 1222 65408 573 49 14 96 28200 2250 659 0 0 2951 -623
    447 ######## 5383 FD8F 5 91 6227 6887 24552 -624 50.5 801 0 65535 6638 7298 599 65535 -10 39828 -811 461 1222 65409 577 49 14 96 28200 2250 661 0 0 2951 -622
    448 ######## 5395 FD92 5 91 6225 6887 24552 -624 50.7 801 0 65535 6636 7298 599 65535 -10 39816 -811 461 1222 65409 577 49 14 96 28200 2250 662 0 0 2951 -627
    449 ######## 5407 FD94 5 91 6223 6887 24552 -623 50.6 801 0 65535 6634 7298 599 65535 -10 39804 -811 460 1221 65409 577 48.9 14 96 28200 2250 664 0 0 2951 -623
    450 ######## 5419 FD93 5 91 6219 6887 24552 -624 50.6 801 0 65535 6630 7298 598 65535 -10 39780 -811 460 1221 65407 568 48.9 14 96 28200 2250 668 0 0 2951 -630
    451 ######## 5431 FD8F 5 91 6218 6887 24540 -627 50.7 801 0 65535 6628 7298 596 65535 -10 39768 -811 460 1220 65409 576 48.9 14 96 28200 2250 670 0 0 2951 -623
    452 ######## 5443 FD93 5 91 6216 6887 24552 -625 50.7 801 0 65535 6627 7298 597 65535 -10 39762 -811 460 1220 65408 572 48.9 14 96 28200 2250 671 0 0 2951 -624
    453 ######## 5455 FD94 5 91 6214 6887 24552 -623 50.7 801 0 65535 6625 7298 598 65535 -10 39750 -811 460 1220 65409 576 48.9 14 96 28200 2250 673 0 0 2951 -627
    454 ######## 5467 FD91 5 91 6212 6887 24552 -624 50.4 801 0 65535 6623 7298 597 65535 -10 39738 -811 460 1219 65409 576 48.9 14 96 28200 2250 675 0 0 2951 -628
    455 ######## 5479 FD91 5 91 6210 6887 24552 -624 50.7 801 0 65535 6621 7298 597 65535 -10 39726 -811 459 1219 65408 571 48.9 14 96 28200 2250 677 0 0 2951 -626
    456 ######## 5492 FD94 5 91 6209 6887 24552 -624 50.6 801 0 65535 6620 7298 597 65535 -10 39714 -811 459 1218 65408 571 48.9 14 96 28200 2250 679 0 0 2951 -622
    457 ######## 5504 FD93 5 91 6205 6887 24540 -624 50.4 801 0 65535 6616 7298 597 65535 -10 39696 -811 459 1218 65409 575 48.8 14 96 28200 2250 682 0 0 2951 -622
    458 ######## 5516 FD91 5 91 6203 6887 24540 -623 50.4 801 0 65535 6614 7298 597 65535 -10 39684 -811 459 1217 65409 575 48.8 14 96 28200 2250 684 0 0 2951 -622
    459 ######## 5528 FD91 5 91 6201 6887 24540 -623 50.2 801 0 65535 6612 7298 597 65535 -10 39672 -811 459 1217 65409 575 48.7 14 96 28200 2250 686 0 0 2951 -622
    460 ######## 5540 FD8A 5 91 6199 6887 24540 -625 50.4 801 0 65535 6610 7298 595 65535 -10 39660 -811 459 1217 65408 570 48.7 14 96 28200 2250 688 0 0 2951 -626
    461 ######## 5552 FD93 5 90 6198 6887 24528 -626 50.4 801 0 65535 6609 7298 594 65535 -10 39654 -811 459 1216 65409 574 48.7 14 96 28200 2250 689 0 0 2951 -621
    462 ######## 5564 FD95 5 90 6196 6887 24540 -624 50.1 801 0 65535 6607 7298 596 65535 -10 39642 -811 458 1216 65408 570 48.6 14 96 28200 2250 691 0 0 2951 -625
    463 ######## 5576 FD94 5 90 6194 6887 24528 -623 50.4 801 0 65535 6605 7298 597 65535 -10 39630 -811 458 1216 65408 570 48.7 14 96 28200 2250 693 0 0 2951 -627
    464 ######## 5588 FD93 5 90 6191 6887 24528 -625 50.2 801 0 65535 6601 7298 594 65535 -10 39606 -811 458 1215 65409 574 48.7 14 96 28200 2250 697 0 0 2951 -623
    465 ######## 5600 FD92 5 90 6189 6887 24528 -626 50.3 801 0 65535 6600 7298 593 65535 -10 39600 -811 458 1215 65408 570 48.7 14 96 28200 2250 698 0 0 2951 -625
    466 ######## 5612 FD8F 5 90 6187 6887 24528 -625 50.2 801 0 65535 6598 7298 594 65535 -10 39588 -811 458 1214 65409 574 48.7 14 96 28200 2250 700 0 0 2951 -622
    467 ######## 5624 FD95 5 90 6185 6887 24528 -624 50.1 801 0 65535 6596 7298 595 65535 -10 39576 -811 458 1214 65409 574 48.6 14 96 28200 2250 702 0 0 2951 -623
    468 ######## 5636 FD91 5 90 6183 6887 24528 -625 50 801 0 65535 6594 7298 594 65535 -10 39564 -811 457 1213 65409 569 48.6 14 96 28200 2250 704 0 0 2951 -625
    469 ######## 5648 FD91 5 90 6181 6887 24528 -624 50.1 801 0 65535 6592 7298 594 65535 -10 39552 -811 457 1213 65407 564 48.6 14 96 28200 2250 706 0 0 2951 -624
    470 ######## 5660 FD95 5 90 6180 6887 24528 -624 49.8 801 0 65535 6591 7298 594 65535 -10 39546 -811 457 1213 65409 573 48.6 14 96 28200 2250 708 0 0 2951 -622
    471 ######## 5672 FD92 5 90 6176 6887 24516 -624 49.9 801 0 65535 6587 7298 594 65535 -10 39522 -811 457 1212 65409 573 48.5 14 96 28200 2250 711 0 0 2951 -624
    472 ######## 5684 FD93 5 90 6174 6887 24516 -623 50 801 0 65535 6585 7298 595 65535 -10 39510 -811 457 1211 65409 572 48.6 14 96 28200 2250 713 0 0 2951 -622
    473 ######## 5696 FD91 5 90 6172 6887 24516 -625 50 801 0 65535 6583 7298 593 65535 -10 39498 -811 457 1211 65409 572 48.5 14 96 28200 2250 715 0 0 2951 -622
    474 ######## 5708 FD90 5 90 6170 6887 24516 -624 50 801 0 65535 6581 7298 593 65535 -10 39486 -811 456 1211 65409 572 48.5 14 96 28200 2250 717 0 0 2951 -624
    475 ######## 5720 FD92 5 90 6168 6887 24516 -623 50.1 801 0 65535 6579 7298 594 65535 -10 39474 -811 456 1210 65409 572 48.5 14 96 28200 2250 719 0 0 2951 -629
    476 ######## 5732 FD92 5 90 6167 6887 24504 -623 50.1 801 0 65535 6578 7298 594 65535 -10 39468 -811 456 1210 65409 572 48.5 14 96 28200 2250 721 0 0 2951 -629
    477 ######## 5744 FD93 5 90 6165 6887 24516 -623 50 801 0 65535 6576 7298 594 65535 -10 39456 -811 456 1210 65408 567 48.5 14 96 28200 2250 722 0 0 2951 -623
    478 ######## 5756 FD95 5 90 6163 6887 24516 -623 50 801 0 65535 6574 7298 594 65535 -10 39444 -811 456 1209 65408 571 48.5 14 96 28200 2250 724 0 0 2951 -624
    479 ######## 5768 FD89 5 90 6159 6887 24504 -625 50 801 0 65535 6570 7298 591 65535 -10 39420 -811 456 1208 65408 566 48.5 14 96 28200 2250 728 0 0 2951 -626
    480 ######## 5780 FD8F 5 90 6157 6887 24504 -626 49.9 801 0 65535 6568 7298 590 65535 -10 39408 -811 456 1208 65408 566 48.5 14 96 28200 2250 730 0 0 2951 -625
    481 ######## 5792 FD88 5 90 6156 6887 24504 -627 50 801 0 65535 6567 7298 589 65535 -10 39402 -811 455 1208 65408 566 48.5 14 96 28200 2250 732 0 0 2951 -625
    482 ######## 5804 FD92 5 90 6154 6887 24504 -626 50.4 801 0 65535 6565 7298 590 65535 -10 39390 -811 455 1207 65409 570 48.7 14 96 28200 2250 734 0 0 2951 -627
    483 ######## 5816 FD91 5 90 6152 6887 24504 -626 50.2 801 0 65535 6563 7298 590 65535 -10 39378 -811 455 1207 65408 566 48.7 14 96 28200 2250 735 0 0 2951 -626
    484 ######## 5828 FD86 5 90 6150 6887 24492 -626 50.2 801 0 65535 6561 7298 589 65535 -10 39366 -811 455 1207 65408 566 48.6 14 96 28200 2250 737 0 0 2951 -628
    485 ######## 5840 FD91 5 90 6148 6887 24504 -625 49.8 801 0 65535 6559 7298 590 65535 -10 39354 -811 455 1206 65408 565 48.5 14 96 28200 2250 739 0 0 2951 -625
    486 ######## 5852 FD91 5 90 6145 6887 24492 -625 49.7 801 0 65535 6556 7298 590 65535 -10 39336 -811 455 1206 65408 565 48.4 14 96 28200 2250 743 0 0 2951 -628
    487 ######## 5864 FD93 5 90 6143 6887 24492 -625 49.8 801 0 65535 6554 7298 590 65535 -10 39324 -811 454 1205 65408 565 48.4 14 96 28200 2250 744 0 0 2951 -628
    488 ######## 5876 FD90 5 90 6141 6887 24492 -627 49.8 801 0 65535 6552 7298 588 65535 -10 39312 -811 454 1205 65408 565 48.3 14 96 28200 2250 746 0 0 2951 -627
    489 ######## 5888 FD90 5 90 6139 6887 24492 -628 49.8 801 0 65535 6550 7298 587 65535 -10 39300 -811 454 1204 65408 564 48.3 14 96 28200 2250 748 0 0 2951 -628
    490 ######## 5900 FD8E 5 90 6137 6887 24492 -627 49.7 801 0 65535 6548 7298 588 65535 -10 39288 -811 454 1204 65409 569 48.3 14 96 28200 2250 750 0 0 2951 -627
    491 ######## 5912 FD8F 5 90 6136 6887 24492 -626 49.6 801 0 65535 6546 7298 588 65535 -10 39276 -811 454 1203 65409 568 48.3 14 96 28200 2250 752 0 0 2951 -628
    492 ######## 5924 FD8F 5 90 6134 6887 24480 -626 49.4 801 0 65535 6545 7298 588 65535 -10 39264 -811 454 1203 65408 564 48.2 14 96 28200 2250 754 0 0 2951 -628
    493 ######## 5936 FD91 5 90 6130 6887 24480 -626 49.1 801 0 65535 6541 7298 588 65535 -10 39246 -811 454 1202 65408 563 48 14 96 28200 2250 757 0 0 2951 -623
    494 ######## 5949 FD94 5 89 6128 6887 24480 -626 49.1 801 0 65535 6539 7298 587 65535 -10 39234 -811 453 1202 65409 568 48 14 96 28200 2250 759 0 0 2951 -624
    495 ######## 5961 FD8E 5 89 6126 6887 24480 -626 49.2 801 0 65535 6537 7298 588 65535 -10 39222 -811 453 1202 65409 568 48 14 96 28200 2250 761 0 0 2951 -624
    496 ######## 5973 FD91 5 89 6125 6887 24480 -626 48.9 801 0 65535 6536 7298 587 65535 -10 39210 -811 453 1201 65409 567 48 14 96 28200 2250 763 0 0 2951 -628
    497 ######## 5985 FD92 5 89 6123 6887 24480 -626 49 801 0 65535 6534 7298 587 65535 -10 39204 -811 453 1201 65408 563 47.9 14 96 28200 2250 764 0 0 2951 -633
    498 ######## 5997 FD90 5 89 6121 6887 24480 -627 49.1 801 0 65535 6532 7298 587 65535 -10 39192 -811 453 1201 65409 567 47.9 14 96 28200 2250 766 0 0 2951 -626
    499 ######## 6009 FD8F 5 89 6119 6887 24480 -626 49 801 0 65535 6530 7298 586 65535 -10 39180 -811 453 1200 65407 558 47.9 14 96 28200 2250 768 0 0 2951 -631
    500 ######## 6021 FD92 5 89 6116 6887 24480 -627 49 801 0 65535 6527 7298 585 65535 -10 39156 -811 452 1199 65408 562 47.9 14 96 28200 2250 772 0 0 2951 -625
    501 ######## 6033 FD91 5 89 6114 6887 24480 -627 49.1 801 0 65535 6525 7298 585 65535 -10 39144 -811 452 1199 65408 562 47.9 14 96 28200 2250 774 0 0 2951 -628
    502 ######## 6045 FD92 5 89 6112 6887 24480 -626 49.5 801 0 65535 6523 7298 586 65535 -10 39138 -811 452 1199 65408 562 48 14 96 28200 2250 775 0 0 2951 -626
    503 ######## 6057 FD91 5 89 6110 6887 24468 -626 49.5 801 0 65535 6521 7298 586 65535 -10 39126 -811 452 1198 65408 562 48.1 14 96 28200 2250 777 0 0 2951 -630
    504 ######## 6069 FD90 5 89 6108 6887 24468 -626 49.4 801 0 65535 6519 7298 585 65535 -10 39114 -811 452 1198 65408 562 48.1 14 96 28200 2250 779 0 0 2951 -628
    505 ######## 6081 FD91 5 89 6107 6887 24468 -625 49.8 801 0 65535 6517 7298 586 65535 -10 39102 -811 452 1198 65408 562 48.2 14 96 28200 2250 781 0 0 2951 -627
    506 ######## 6093 FD92 5 89 6105 6887 24468 -625 49.9 801 0 65535 6515 7298 586 65535 -10 39090 -811 452 1197 65409 566 48.3 14 96 28200 2250 783 0 0 2951 -625
    507 ######## 6105 FD90 5 89 6101 6887 24468 -626 50.1 801 0 65535 6512 7298 585 65535 -10 39072 -811 451 1197 65408 561 48.4 14 96 28200 2250 786 0 0 2951 -627
    508 ######## 6117 FD92 5 89 6099 6887 24468 -626 50 801 0 65535 6510 7298 585 65535 -10 39060 -811 451 1196 65409 565 48.4 14 96 28200 2250 788 0 0 2951 -625
    509 ######## 6129 FD8F 5 89 6097 6887 24468 -626 49.9 801 0 65535 6508 7298 584 65535 -10 39048 -811 451 1196 65409 565 48.4 14 96 28200 2250 790 0 0 2951 -632
    510 ######## 6141 FD8F 5 89 6096 6887 24456 -626 50 801 0 65535 6506 7298 584 65535 -10 39036 -811 451 1195 65408 560 48.4 14 96 28200 2250 792 0 0 2951 -625
    511 ######## 6153 FD8E 5 89 6094 6887 24456 -626 50 801 0 65535 6505 7298 583 65535 -10 39030 -811 451 1195 65404 543 48.5 14 96 28200 2250 793 0 0 2951 -640
    512 ######## 6165 FD92 5 89 6092 6887 24456 -626 50.1 801 0 65535 6503 7298 584 65535 -10 39018 -811 451 1195 65407 556 48.5 14 96 28200 2250 795 0 0 2951 -634
    513 ######## 6177 FD8F 5 89 6090 6887 24456 -626 50.3 801 0 65535 6501 7298 584 65535 -10 39006 -811 451 1194 65408 560 48.5 14 96 28200 2250 797 0 0 2951 -626
    514 ######## 6189 FD8E 5 89 6086 6887 24444 -629 50.1 801 0 65535 6497 7298 581 65535 -10 38982 -811 450 1193 65408 559 48.5 14 96 28200 2250 801 0 0 2951 -627
    515 ######## 6201 FD8D 5 89 6085 6887 24456 -629 50.2 801 0 65535 6496 7298 580 65535 -10 38976 -811 450 1193 65408 559 48.6 14 96 28200 2250 802 0 0 2951 -633
    516 ######## 6213 FD8C 5 89 6083 6887 24444 -628 50.3 801 0 65535 6494 7298 581 65535 -10 38964 -811 450 1193 65408 559 48.6 14 96 28200 2250 804 0 0 2951 -626
    517 ######## 6225 FD8D 5 89 6081 6887 24456 -628 50.2 801 0 65535 6492 7298 581 65535 -10 38952 -811 450 1192 65407 554 48.6 14 96 28200 2250 806 0 0 2951 -631
    518 ######## 6237 FD8B 5 89 6079 6887 24444 -628 50.3 801 0 65535 6490 7298 581 65535 -10 38940 -811 450 1192 65408 559 48.6 14 96 28200 2250 808 0 0 2951 -625
    519 ######## 6250 FD8D 5 89 6077 6887 24444 -628 50.3 801 0 65535 6488 7298 581 65535 -10 38928 -811 450 1192 65408 559 48.7 14 96 28200 2250 810 0 0 2951 -629
    520 ######## 6262 FD8C 5 89 6074 6887 24432 -628 50.2 801 0 65535 6485 7298 580 65535 -10 38910 -811 449 1191 65405 545 48.7 14 96 28200 2250 813 0 0 2951 -644
    521 ######## 6274 FD8A 5 89 6072 6887 24432 -629 50.3 801 0 65535 6483 7298 579 65535 -10 38898 -811 449 1191 65408 558 48.6 14 96 28200 2250 815 0 0 2951 -629
    522 ######## 6286 FD8D 5 89 6070 6887 24432 -629 50.3 801 0 65535 6481 7298 579 65535 -10 38886 -811 449 1190 65409 562 48.6 14 96 28200 2250 817 0 0 2951 -626
    523 ######## 6298 FD8D 5 89 6068 6887 24432 -628 50.2 801 0 65535 6479 7298 580 65535 -10 38874 -811 449 1190 65408 558 48.6 14 96 28200 2250 819 0 0 2951 -628
    524 ######## 6310 FD8B 5 89 6066 6887 24432 -628 50.3 801 0 65535 6477 7298 580 65535 -10 38862 -811 449 1189 65408 557 48.6 14 96 28200 2250 821 0 0 2951 -627
    525 ######## 6322 FD8C 5 89 6065 6887 24432 -628 50.3 801 0 65535 6476 7298 579 65535 -10 38850 -811 449 1189 65408 557 48.7 14 96 28200 2250 823 0 0 2951 -629
    526 ######## 6334 FD8F 5 89 6063 6887 24420 -628 50.2 801 0 65535 6474 7298 579 65535 -10 38844 -811 449 1189 65409 562 48.7 14 96 28200 2250 824 0 0 2951 -633
    527 ######## 6346 FD91 5 88 6059 6887 24432 -627 50.2 801 0 65535 6470 7298 580 65535 -10 38820 -811 448 1188 65409 561 48.7 14 96 28200 2250 828 0 0 2951 -627
    528 ######## 6358 FD91 5 88 6058 6887 24432 -628 50.1 801 0 65535 6468 7298 579 65535 -10 38808 -811 448 1188 65408 561 48.6 14 96 28200 2250 830 0 0 2951 -626
    529 ######## 6370 FD8F 5 88 6056 6887 24420 -628 50 801 0 65535 6466 7298 579 65535 -10 38796 -811 448 1187 65409 561 48.5 14 96 28200 2250 832 0 0 2951 -628
    530 ######## 6382 FD8F 5 88 6054 6887 24420 -628 50.1 801 0 65535 6465 7298 578 65535 -10 38790 -811 448 1187 65408 556 48.5 14 96 28200 2250 834 0 0 2951 -634
    531 ######## 6394 FD90 5 88 5902 6737 24420 -628 50.3 801 0 65535 6421 7256 564 65535 -10 38526 -811 437 1154 65408 541 48.6 14 96 28200 2250 835 0 0 2951 -630
    532 ######## 6406 FD82 5 88 5900 6737 24420 -629 50.1 801 0 65535 6419 7256 563 65535 -10 38514 -811 436 1153 65407 536 48.6 14 96 28200 2250 837 0 0 2951 -635
    533 ######## 6418 FD8E 5 88 5898 6737 24420 -628 50.3 801 0 65535 6417 7256 564 65535 -10 38502 -811 436 1153 65408 540 48.6 14 96 28200 2250 839 0 0 2951 -631
    534 ######## 6430 FD8D 5 88 5895 6737 24420 -628 50.1 801 0 65535 6414 7256 563 65535 -10 38484 -811 436 1152 65408 540 48.6 14 96 28200 2250 843 0 0 2951 -632
    535 ######## 6442 FD8E 5 88 5893 6737 24420 -627 49.8 801 0 65535 6412 7256 564 65535 -10 38472 -811 436 1152 65408 540 48.5 14 96 28200 2250 844 0 0 2951 -629
    536 ######## 6454 FD8A 5 88 5891 6737 24408 -628 50.2 801 0 65535 6410 7256 563 65535 -10 38460 -811 436 1151 65408 540 48.6 14 96 28200 2250 846 0 0 2951 -627
    537 ######## 6466 FD8A 5 88 5889 6737 24408 -628 50.2 801 0 65535 6408 7256 563 65535 -10 38448 -811 436 1151 65408 540 48.7 14 96 28200 2250 848 0 0 2951 -628
    538 ######## 6478 FD8E 5 88 5887 6737 24408 -628 50.1 801 0 65535 6406 7256 562 65535 -10 38436 -811 436 1151 65408 540 48.6 14 96 28200 2250 850 0 0 2951 -630
    539 ######## 6490 FD81 5 88 5886 6737 24420 -629 50.2 801 0 65535 6404 7256 560 65535 -10 38424 -811 435 1150 65405 527 48.6 14 96 28200 2250 852 0 0 2951 -644
    540 ######## 6503 FD8D 5 88 5882 6737 24408 -630 50.2 801 0 65535 6401 7256 560 65535 -10 38406 -811 435 1149 65406 530 48.6 14 96 28200 2250 855 0 0 2951 -625
    541 ######## 6515 FD8E 5 88 5880 6737 24396 -629 50.2 801 0 65535 6399 7256 561 65535 -10 38394 -811 435 1149 65409 543 48.6 14 96 28200 2250 857 0 0 2951 -626
    542 ######## 6527 FD8D 5 88 5878 6737 24408 -630 50 801 0 65535 6397 7256 560 65535 -10 38382 -811 435 1149 65408 539 48.6 14 96 28200 2250 859 0 0 2951 -626
    543 ######## 6539 FD8D 5 88 5876 6737 24396 -632 49.9 801 0 65535 6395 7256 558 65535 -10 38370 -811 435 1148 65408 538 48.5 14 96 28200 2250 861 0 0 2951 -629
    544 ######## 6551 FD90 5 88 5874 6737 24396 -631 49.9 801 0 65535 6393 7256 559 65535 -10 38358 -811 435 1148 65409 542 48.5 14 96 28200 2250 863 0 0 2951 -625
    545 ######## 6563 FD8B 5 88 5873 6737 24396 -629 50 801 0 65535 6392 7256 560 65535 -10 38352 -811 435 1148 65408 538 48.5 14 96 28200 2250 865 0 0 2951 -633
    546 ######## 6577 FD8F 5 88 5869 6737 24396 -628 49.8 801 0 65535 6388 7256 561 65535 -10 38328 -811 434 1147 65409 542 48.5 14 96 28200 2250 868 0 0 2951 -626
    547 ######## 6589 FD91 5 88 5867 6737 24396 -627 49.9 801 0 65535 6386 7256 561 65535 -10 38316 -811 434 1146 65409 541 48.5 14 96 28200 2250 870 0 0 2951 -629
    548 ######## 6601 FD8F 5 88 5865 6737 24396 -627 50 801 0 65535 6384 7256 561 65535 -10 38304 -811 434 1146 65409 541 48.4 14 96 28200 2250 872 0 0 2951 -628
    549 ######## 6613 FD90 5 88 5864 6737 24396 -627 50.1 801 0 65535 6383 7256 561 65535 -10 38298 -811 434 1146 65409 541 48.5 14 96 28200 2250 874 0 0 2951 -627
    550 ######## 6625 FD90 5 88 5862 6737 24396 -627 49.9 801 0 65535 6381 7256 561 65535 -10 38286 -811 434 1145 65409 541 48.4 14 96 28200 2250 875 0 0 2951 -632
    551 ######## 6638 FD8C 5 87 5860 6737 24396 -628 49.9 801 0 65535 6379 7256 560 65535 -10 38274 -811 434 1145 65409 541 48.4 14 96 28200 2250 877 0 0 2951 -632
    552 ######## 6650 FD8C 5 87 5856 6737 24396 -628 49.3 801 0 65535 6375 7256 559 65535 -10 38250 -811 433 1144 65409 540 48.1 14 96 28200 2250 881 0 0 2951 -630
    553 ######## 6662 FD8D 5 87 5854 6737 24396 -628 49.2 801 0 65535 6373 7256 559 65535 -10 38238 -811 433 1144 65409 540 48.1 14 96 28200 2250 883 0 0 2951 -627
    554 ######## 6674 FD8B 5 87 5853 6737 24396 -628 49.4 801 0 65535 6372 7256 559 65535 -10 38232 -811 433 1144 65408 536 48.2 14 96 28200 2250 884 0 0 2951 -626
    555 ######## 6686 FD8B 5 87 5851 6737 24384 -628 49.5 801 0 65535 6370 7256 559 65535 -10 38220 -811 433 1143 65408 536 48.1 14 96 28200 2250 886 0 0 2951 -627
    556 ######## 6698 FD85 5 87 5849 6737 24384 -628 49.6 801 0 65535 6368 7256 559 65535 -10 38208 -811 433 1143 65409 540 48.1 14 96 28200 2250 888 0 0 2951 -625
    557 ######## 6710 FD8C 5 87 5847 6737 24384 -628 49.5 801 0 65535 6366 7256 559 65535 -10 38196 -811 433 1142 65408 535 48.1 14 96 28200 2250 890 0 0 2951 -626
    558 ######## 6722 FD8E 5 87 5845 6737 24384 -628 49.2 801 0 65535 6364 7256 558 65535 -10 38184 -811 432 1142 65409 540 48.1 14 96 28200 2250 892 0 0 2951 -626
    559 ######## 6734 FD8D 5 87 5843 6737 24372 -628 49.3 801 0 65535 6362 7256 558 65535 -10 38172 -811 432 1142 65409 540 48.1 14 96 28200 2250 894 0 0 2951 -626
    560 ######## 6746 FD87 5 87 5840 6737 24360 -631 48.9 801 0 65535 6359 7256 556 65535 -10 38154 -811 432 1141 65409 539 47.9 14 96 28200 2250 897 0 0 2951 -628
    561 ######## 6758 FD8D 5 87 5838 6737 24384 -629 48.9 801 0 65535 6357 7256 557 65535 -10 38142 -811 432 1141 65408 535 47.9 14 96 28200 2250 899 0 0 2951 -630
    562 ######## 6770 FD8F 5 87 5836 6737 24372 -628 48.5 801 0 65535 6355 7256 558 65535 -10 38130 -811 432 1140 65409 539 47.7 15 96 28200 2250 901 0 0 2951 -628
    563 ######## 6782 FD8D 5 87 5834 6737 24372 -629 49 801 0 65535 6353 7256 557 65535 -10 38118 -811 432 1140 65406 526 47.8 15 96 28200 2250 903 0 0 2951 -642
    564 ######## 6794 FD8C 5 87 5832 6737 24372 -629 48.4 801 0 65535 6351 7256 556 65535 -10 38106 -811 431 1139 65408 534 47.7 15 96 28200 2250 905 0 0 2951 -626
    565 ######## 6806 FD8A 5 87 5831 6737 24372 -628 48.3 801 0 65535 6350 7256 557 65535 -10 38100 -811 431 1139 65408 534 47.6 15 96 28200 2250 907 0 0 2951 -630
    566 ######## 6818 FD8C 5 87 5829 6737 24372 -627 48.6 801 0 65535 6348 7256 557 65535 -10 38088 -811 431 1139 65408 538 47.6 15 96 28200 2250 909 0 0 2951 -627
    567 ######## 6830 FD70 5 87 5825 6737 24348 -642 48.4 801 0 65535 6344 7256 544 65535 -10 38064 -811 431 1138 65403 513 47.5 15 96 28200 2250 912 0 0 2951 -644
    568 ######## 6842 FD7C 5 87 5823 6737 24348 -646 48.4 801 0 65535 6342 7256 541 65535 -10 38052 -811 431 1138 65404 517 47.5 15 96 28200 2250 914 0 0 2951 -653
    569 ######## 6854 FD82 5 87 5821 6737 24348 -645 48.5 801 0 65535 6340 7256 541 65535 -10 38040 -811 431 1137 65406 525 47.5 15 96 28200 2250 916 0 0 2951 -636
    570 ######## 6866 FD8A 5 87 5819 6737 24360 -639 48.6 801 0 65535 6338 7256 546 65535 -10 38028 -811 431 1137 65409 537 47.5 15 96 28200 2250 918 0 0 2951 -634
    571 ######## 6878 FD8A 5 87 5818 6737 24360 -635 48.9 801 0 65535 6337 7256 550 65535 -10 38016 -811 430 1136 65406 524 47.7 15 96 28200 2250 920 0 0 2951 -636
    572 ######## 6890 FD8C 5 87 5816 6737 24360 -633 48.8 801 0 65535 6335 7256 551 65535 -10 38010 -811 430 1136 65407 528 47.7 15 96 28200 2250 922 0 0 2951 -633
    573 ######## 6902 FD8D 5 87 5814 6737 24360 -632 49.2 801 0 65535 6333 7256 553 65535 -10 37998 -811 430 1136 65409 537 47.8 15 96 28200 2250 923 0 0 2951 -629
    574 ######## 6914 FD88 5 87 5810 6737 24348 -631 49.2 801 0 65535 6329 7256 552 65535 -10 37974 -811 430 1135 65409 536 47.8 15 96 28200 2250 927 0 0 2951 -628
    575 ######## 6926 FD89 5 87 5808 6737 24348 -630 49.4 801 0 65535 6327 7256 553 65535 -10 37962 -811 430 1134 65408 532 47.9 15 96 28200 2250 929 0 0 2951 -628
    576 ######## 6939 FD89 5 87 5807 6737 24348 -630 49 801 0 65535 6326 7256 553 65535 -10 37956 -811 430 1134 65409 536 47.9 15 96 28200 2250 931 0 0 2951 -628
    577 ######## 6951 FD8D 5 87 5805 6737 24348 -630 49.2 801 0 65535 6324 7256 553 65535 -10 37944 -811 429 1134 65409 536 47.9 15 96 28200 2250 933 0 0 2951 -630
    578 ######## 6963 FD8D 5 87 5803 6737 24348 -629 49.3 801 0 65535 6322 7256 553 65535 -10 37932 -811 429 1133 65408 531 48 15 96 28200 2250 935 0 0 2951 -633
    579 ######## 6975 FD8C 5 87 5801 6737 24348 -629 49.3 801 0 65535 6320 7256 553 65535 -10 37920 -811 429 1133 65408 531 47.9 15 96 28200 2250 936 0 0 2951 -632
    580 ######## 6987 FD8B 5 87 5799 6737 24348 -629 49.2 801 0 65535 6318 7256 553 65535 -10 37908 -811 429 1133 65408 531 47.9 15 96 28200 2250 938 0 0 2951 -632
    581 ######## 6999 FD8B 5 87 5795 6737 24348 -630 49.2 801 0 65535 6314 7256 552 65535 -10 37884 -811 429 1132 65408 527 47.9 15 96 28200 2250 942 0 0 2951 -638
    582 ######## 7011 FD7E 5 87 5794 6737 24336 -632 49.3 801 0 65535 6313 7256 550 65535 -10 37872 -811 429 1131 65407 526 48 15 96 28200 2250 944 0 0 2951 -632
    583 ######## 7023 FD8D 5 86 5792 6737 24348 -634 49.3 801 0 65535 6311 7256 548 65535 -10 37866 -811 429 1131 65408 530 47.9 15 96 28200 2250 946 0 0 2951 -651
    584 ######## 7035 FD88 5 86 5790 6737 24336 -636 49.2 801 0 65535 6309 7256 546 65535 -10 37854 -811 428 1131 65407 526 48 15 96 28200 2250 947 0 0 2951 -631
    585 ######## 7047 FD85 5 86 5788 6737 24336 -634 49.5 801 0 65535 6307 7256 548 65535 -10 37842 -811 428 1130 65408 530 48.1 15 96 28200 2250 949 0 0 2951 -633
    586 ######## 7059 FD8B 5 86 5786 6737 24336 -633 49.7 801 0 65535 6305 7256 548 65535 -10 37830 -811 428 1130 65408 530 48.2 15 96 28200 2250 951 0 0 2951 -633
    587 ######## 7071 FD84 5 86 5784 6737 24324 -633 49.7 801 0 65535 6303 7256 548 65535 -10 37818 -811 428 1130 65408 530 48.2 15 96 28200 2250 953 0 0 2951 -636
    588 ######## 7083 FD85 5 86 5781 6737 24324 -635 49.7 801 0 65535 6300 7256 546 65535 -10 37794 -811 428 1129 65408 529 48.3 15 96 28200 2250 957 0 0 2951 -630
    589 ######## 7095 FD8A 5 86 5779 6737 24324 -635 50 801 0 65535 6298 7256 546 65535 -10 37788 -811 428 1129 65405 517 48.3 15 96 28200 2250 958 0 0 2951 -647
    590 ######## 7107 FD87 5 86 5777 6737 24324 -634 50 801 0 65535 6296 7256 547 65535 -10 37776 -811 427 1128 65408 529 48.4 15 96 28200 2250 960 0 0 2951 -630
    591 ######## 7119 FD8B 5 86 5775 6737 24324 -633 50.4 801 0 65535 6294 7256 547 65535 -10 37764 -811 427 1128 65408 529 48.5 15 96 28200 2250 962 0 0 2951 -634
    592 ######## 7131 FD8A 5 86 5773 6737 24324 -632 50.4 801 0 65535 6292 7256 548 65535 -10 37752 -811 427 1127 65408 528 48.5 15 96 28200 2250 964 0 0 2951 -631
    593 ######## 7143 FD8A 5 86 5772 6737 24324 -634 50.6 801 0 65535 6290 7256 546 65535 -10 37740 -811 427 1127 65408 528 48.7 15 96 28200 2250 966 0 0 2951 -631
    594 ######## 7155 FD8A 5 86 5770 6737 24324 -633 50.6 801 0 65535 6288 7256 547 65535 -10 37728 -811 427 1127 65409 532 48.7 15 96 28200 2250 968 0 0 2951 -637
    595 ######## 7167 FD84 5 86 5766 6737 24324 -633 50.4 801 0 65535 6285 7256 547 65535 -10 37710 -811 427 1126 65407 524 48.7 15 96 28200 2250 971 0 0 2951 -633
    596 ######## 7179 FD8D 5 86 5764 6737 24324 -633 50.6 801 0 65535 6283 7256 546 65535 -10 37698 -811 426 1126 65409 532 48.7 15 96 28200 2250 973 0 0 2951 -632
    597 ######## 7191 FD84 5 86 5762 6737 24324 -633 50.8 801 0 65535 6281 7256 546 65535 -10 37686 -811 426 1125 65408 527 48.8 15 96 28200 2250 975 0 0 2951 -631
    598 ######## 7203 FD88 5 86 5760 6737 24312 -633 51 801 0 65535 6279 7256 546 65535 -10 37674 -811 426 1125 65408 527 48.9 15 96 28200 2250 977 0 0 2951 -629
    599 ######## 7215 FD88 5 86 5758 6737 24312 -633 51 801 0 65535 6277 7256 546 65535 -10 37662 -811 426 1124 65408 527 49 15 96 28200 2250 979 0 0 2951 -631
    600 ######## 7227 FD8B 5 86 5757 6737 24312 -633 51.1 801 0 65535 6275 7256 546 65535 -10 37650 -811 426 1124 65407 523 49 15 96 28200 2250 981 0 0 2951 -636
    601 ######## 7239 FD87 5 86 5755 6737 24312 -634 51.1 801 0 65535 6274 7256 545 65535 -10 37644 -811 426 1124 65408 527 49.1 15 96 28200 2250 982 0 0 2951 -634
    602 ######## 7251 FD88 5 86 5753 6737 24312 -634 51 801 0 65535 6272 7256 544 65535 -10 37632 -811 426 1123 65408 526 49 15 96 28200 2250 984 0 0 2951 -636
    603 ######## 7263 FD8B 5 86 5749 6737 24312 -634 50.9 801 0 65535 6268 7256 544 65535 -10 37608 -811 425 1123 65408 526 49 15 96 28200 2250 988 0 0 2951 -632
    604 ######## 7275 FD80 5 86 5747 6737 24300 -636 50.7 801 0 65535 6266 7256 542 65535 -10 37596 -811 425 1122 65407 522 49 15 96 28200 2250 990 0 0 2951 -639
    605 ######## 7287 FD8C 5 86 5746 6737 24300 -635 50.7 801 0 65535 6265 7256 543 65535 -10 37584 -811 425 1122 65408 526 49 15 96 28200 2250 992 0 0 2951 -633
    606 ######## 7299 FD88 5 86 5744 6737 24300 -634 50.7 801 0 65535 6263 7256 544 65535 -10 37578 -811 425 1121 65408 525 49 15 96 28200 2250 993 0 0 2951 -633
    607 ######## 7311 FD87 5 86 5742 6737 24300 -633 50.7 801 0 65535 6261 7256 544 65535 -10 37566 -811 425 1121 65408 525 49 15 96 28200 2250 995 0 0 2951 -630
    608 ######## 7323 FD84 5 86 5738 6737 24300 -633 50.9 801 0 65535 6257 7256 544 65535 -10 37542 -811 425 1120 65408 525 48.9 15 96 28200 2250 999 0 0 2951 -630
    609 ######## 7335 FD8C 5 86 5737 6737 24300 -633 50.7 801 0 65535 6255 7256 544 65535 -10 37530 -811 424 1120 65408 525 48.9 15 96 28200 2250 1001 0 0 2951 -634
    610 ######## 7347 FD88 5 86 5735 6737 24300 -634 50.7 801 0 65535 6254 7256 543 65535 -10 37524 -811 424 1120 65408 525 49 15 96 28200 2250 1002 0 0 2951 -631
    611 ######## 7360 FD89 5 86 5733 6737 24300 -633 50.7 801 0 65535 6252 7256 543 65535 -10 37512 -811 424 1119 65408 525 48.9 15 96 28200 2250 1004 0 0 2951 -635
    612 ######## 7372 FD89 5 86 5731 6737 24288 -637 50.7 801 0 65535 6250 7256 541 65535 -10 37500 -811 424 1119 65408 525 49 15 96 28200 2250 1006 0 0 2951 -633
    613 ######## 7384 FD85 5 86 5729 6737 24300 -638 50.8 801 0 65535 6248 7256 539 65535 -10 37488 -811 424 1118 65408 524 49 15 96 28200 2250 1008 0 0 2951 -634
    614 ######## 7396 FD8A 5 86 5727 6737 24288 -636 50.7 801 0 65535 6246 7256 540 65535 -10 37476 -811 424 1118 65407 520 49 15 96 28200 2250 1010 0 0 2951 -633
    615 ######## 7408 FD87 5 85 5725 6737 24288 -634 50.9 801 0 65535 6244 7256 541 65535 -10 37464 -811 424 1118 65407 520 49 15 96 28200 2250 1012 0 0 2951 -637
    616 ######## 7420 FD8B 5 85 5722 6737 24288 -633 51 801 0 65535 6240 7256 542 65535 -10 37440 -811 423 1117 65408 524 49 15 96 28200 2250 1016 0 0 2951 -635
    617 ######## 7432 FD88 5 85 5720 6737 24288 -633 50.9 801 0 65535 6239 7256 542 65535 -10 37434 -811 423 1117 65408 524 49 15 96 28200 2250 1018 0 0 2951 -632
    618 ######## 7444 FD8C 5 85 5718 6737 24288 -633 50.7 801 0 65535 6237 7256 542 65535 -10 37422 -811 423 1116 65408 523 49 15 96 28200 2250 1019 0 0 2951 -632
    619 ######## 7456 FD8C 5 85 5716 6737 24288 -633 50.7 801 0 65535 6235 7256 543 65535 -10 37410 -811 423 1116 65408 523 49 15 96 28200 2250 1021 0 0 2951 -634
    620 ######## 7468 FD88 5 85 5714 6737 24276 -633 50.7 801 0 65535 6233 7256 542 65535 -10 37398 -811 423 1115 65408 523 49 15 96 28200 2250 1023 0 0 2951 -633
    621 ######## 7480 FD8B 5 85 5713 6737 24288 -633 51 801 0 65535 6232 7256 541 65535 -10 37386 -811 423 1115 65408 523 49 15 96 28200 2250 1025 0 0 2951 -634
    622 ######## 7493 FD8C 5 85 5709 6737 24276 -633 50.7 801 0 65535 6228 7256 541 65535 -10 37368 -811 422 1114 65407 514 49 15 96 28200 2250 1029 0 0 2951 -631
    623 ######## 7505 FD87 5 85 5707 6737 24276 -635 50.6 801 0 65535 6226 7256 539 65535 -10 37356 -811 422 1114 65408 522 48.9 15 96 28200 2250 1030 0 0 2951 -635
    624 ######## 7517 FD8B 5 85 5705 6737 24276 -635 50.7 801 0 65535 6224 7256 539 65535 -10 37344 -811 422 1114 65409 526 48.9 15 96 28200 2250 1032 0 0 2951 -633
    625 ######## 7529 FD89 5 85 5703 6737 24276 -634 50.8 801 0 65535 6222 7256 540 65535 -10 37332 -811 422 1113 65407 518 49 15 96 28200 2250 1034 0 0 2951 -631
    626 ######## 7541 FD89 5 85 5701 6737 24276 -634 51 801 0 65535 6220 7256 540 65535 -10 37320 -811 422 1113 65408 522 49.1 15 96 28200 2250 1036 0 0 2951 -635
    627 ######## 7553 FD8B 5 85 5699 6737 24276 -636 50.8 801 0 65535 6218 7256 538 65535 -10 37308 -811 422 1112 65406 513 49 15 96 28200 2250 1038 0 0 2951 -630
    628 ######## 7565 FD86 5 85 5698 6737 24276 -635 50.8 801 0 65535 6217 7256 538 65535 -10 37302 -811 422 1112 65408 521 49.1 15 96 28200 2250 1040 0 0 2951 -634
    629 ######## 7577 FD8A 5 85 5696 6737 24276 -633 50.8 801 0 65535 6215 7256 540 65535 -10 37290 -811 421 1112 65408 521 49 15 96 28200 2250 1042 0 0 2951 -634
    630 ######## 7589 FD89 5 85 5692 6737 24264 -633 50.8 801 0 65535 6211 7256 540 65535 -10 37266 -811 421 1111 65409 525 49.1 15 96 28200 2250 1045 0 0 2951 -630
    631 ######## 7601 FD86 5 85 5690 6737 24264 -633 50.8 801 0 65535 6209 7256 539 65535 -10 37254 -811 421 1111 65408 521 49 15 96 28200 2250 1047 0 0 2951 -631
    632 ######## 7613 FD88 5 85 5688 6737 24264 -632 50.7 801 0 65535 6207 7256 540 65535 -10 37242 -811 421 1110 65408 520 49 15 96 28200 2250 1049 0 0 2951 -632
    633 ######## 7625 FD89 5 85 5687 6737 24264 -633 50.8 801 0 65535 6205 7256 539 65535 -10 37230 -811 421 1110 65408 520 49 15 96 28200 2250 1051 0 0 2951 -632
    634 ######## 7637 FD84 5 85 5685 6737 24252 -633 50.7 801 0 65535 6204 7256 539 65535 -10 37224 -811 421 1110 65408 520 49 15 96 28200 2250 1052 0 0 2951 -632
    635 ######## 7649 FD84 5 85 5683 6737 24252 -634 50.5 801 0 65535 6202 7256 538 65535 -10 37212 -811 420 1109 65407 524 49 15 96 28200 2250 1054 0 0 2951 -630
    636 ######## 7661 FD8B 5 85 5681 6737 24252 -633 50 801 0 65535 6200 7256 538 65535 -10 37200 -811 420 1109 65409 524 48.9 15 96 28200 2250 1056 0 0 2951 -635
    637 ######## 7673 FD7A 5 85 5677 6737 24252 -634 50.3 801 0 65535 6196 7256 537 65535 -10 37176 -811 420 1108 65408 519 48.8 15 96 28200 2250 1060 0 0 2951 -635
    638 ######## 7685 FD88 5 85 5676 6737 24252 -634 50.3 801 0 65535 6194 7256 537 65535 -10 37164 -811 420 1108 65408 519 48.7 15 96 28200 2250 1062 0 0 2951 -634
    639 ######## 7697 FD8B 5 85 5674 6737 24252 -633 50.3 801 0 65535 6192 7256 538 65535 -10 37152 -811 420 1107 65408 519 48.8 15 96 28200 2250 1064 0 0 2951 -630
    640 ######## 7709 FD87 5 85 5672 6737 24240 -634 50.2 801 0 65535 6190 7256 537 65535 -10 37140 -811 420 1107 65408 519 48.7 15 96 28200 2250 1066 0 0 2951 -631
    641 ######## 7721 FD82 5 85 5670 6737 24240 -633 50.2 801 0 65535 6189 7256 537 65535 -10 37134 -811 419 1107 65409 523 48.7 15 96 28200 2250 1067 0 0 2951 -630
    642 ######## 7733 FD8A 5 85 5668 6737 24240 -632 50.2 801 0 65535 6187 7256 538 65535 -10 37122 -811 419 1106 65409 523 48.7 15 96 28200 2250 1069 0 0 2951 -631
    643 ######## 7745 FD88 5 85 5666 6737 24240 -632 50.1 801 0 65535 6185 7256 538 65535 -10 37110 -811 419 1106 65408 518 48.7 15 96 28200 2250 1071 0 0 2951 -642
    644 ######## 7757 FD86 5 85 5663 6737 24240 -634 50.3 801 0 65535 6181 7256 536 65535 -10 37086 -811 419 1105 65408 518 48.6 15 96 28200 2250 1075 0 0 2951 -632
    645 ######## 7769 FD88 5 85 5661 6737 24240 -632 49.8 801 0 65535 6180 7256 537 65535 -10 37080 -811 419 1105 65408 518 48.6 15 96 28200 2250 1077 0 0 2951 -632
    646 ######## 7781 FD88 5 84 5659 6737 24240 -633 50 801 0 65535 6178 7256 536 65535 -10 37068 -811 419 1104 65408 518 48.6 15 96 28200 2250 1079 0 0 2951 -631
    647 ######## 7793 FD72 5 84 5657 6737 24216 -639 50 801 0 65535 6176 7256 531 65535 -10 37056 -811 419 1104 65404 502 48.5 15 96 28200 2250 1080 0 0 2951 -656
    648 ######## 7805 FD7A 5 84 5655 6737 24228 -648 49.8 801 0 65535 6174 7256 524 65535 -10 37044 -811 418 1103 65403 498 48.5 15 96 28200 2250 1082 0 0 2951 -655
    649 ######## 7817 FD7C 5 84 5653 6737 24228 -650 50 801 0 65535 6172 7256 522 65535 -10 37032 -811 418 1103 65403 498 48.5 15 96 28200 2250 1084 0 0 2951 -648
    650 ######## 7830 FD72 5 84 5651 6737 24216 -649 50.1 801 0 65535 6170 7256 522 65535 -10 37020 -811 418 1103 65401 487 48.5 15 96 28200 2250 1086 0 0 2951 -675
    651 ######## 7842 FD87 5 84 5649 6737 24228 -645 50 801 0 65535 6168 7256 525 65535 -10 37008 -811 418 1102 65407 513 48.5 15 96 28200 2250 1088 0 0 2951 -637
    652 ######## 7854 FD87 5 84 5645 6737 24228 -637 50 801 0 65535 6164 7256 532 65535 -10 36984 -811 418 1101 65408 516 48.5 15 96 28200 2250 1092 0 0 2951 -636
    653 ######## 7866 FD82 5 84 5644 6737 24216 -636 49.7 801 0 65535 6162 7256 532 65535 -10 36972 -811 417 1101 65407 512 48.5 15 96 28200 2250 1094 0 0 2951 -639
    654 ######## 7878 FD86 5 84 5642 6737 24216 -636 50.1 801 0 65535 6161 7256 532 65535 -10 36966 -811 417 1101 65408 516 48.5 15 96 28200 2250 1096 0 0 2951 -634
    655 ######## 7890 FD85 5 84 5640 6737 24216 -636 49.7 801 0 65535 6159 7256 532 65535 -10 36954 -811 417 1100 65408 516 48.5 15 96 28200 2250 1097 0 0 2951 -633
    656 ######## 7902 FD7B 5 84 5638 6737 24216 -636 49.8 801 0 65535 6157 7256 532 65535 -10 36942 -811 417 1100 65408 516 48.4 15 96 28200 2250 1099 0 0 2951 -638
    657 ######## 7914 FD81 5 84 5636 6737 24216 -637 49.7 801 0 65535 6155 7256 531 65535 -10 36930 -811 417 1100 65407 512 48.4 15 96 28200 2250 1101 0 0 2951 -639
    658 ######## 7926 FD82 5 84 5634 6737 24216 -639 49.7 801 0 65535 6153 7256 529 65535 -10 36918 -811 417 1099 65406 507 48.4 15 96 28200 2250 1103 0 0 2951 -637
    659 ######## 7938 FD85 5 84 5631 6737 24216 -637 49.9 801 0 65535 6149 7256 530 65535 -10 36894 -811 417 1098 65408 515 48.4 15 96 28200 2250 1107 0 0 2951 -633
    660 ######## 7950 FD87 5 84 5629 6737 24216 -636 49.9 801 0 65535 6148 7256 531 65535 -10 36888 -811 416 1098 65408 515 48.4 15 96 28200 2250 1109 0 0 2951 -636
    661 ######## 7962 FD87 5 84 5627 6737 24216 -635 50 801 0 65535 6146 7256 532 65535 -10 36876 -811 416 1098 65408 515 48.5 15 96 28200 2250 1111 0 0 2951 -642
    662 ######## 7974 FD83 5 84 5625 6737 24204 -636 50.4 801 0 65535 6144 7256 529 65535 -10 36864 -811 416 1097 65404 499 48.6 15 96 28200 2250 1112 0 0 2951 -637
    663 ######## 7986 FD80 5 84 5623 6737 24204 -639 50.4 801 0 65535 6142 7256 528 65535 -10 36852 -811 416 1097 65407 510 48.6 15 96 28200 2250 1114 0 0 2951 -639
    664 ######## 7998 FD85 5 84 5621 6737 24192 -638 50.4 801 0 65535 6140 7256 529 65535 -10 36840 -811 416 1097 65408 514 48.7 15 96 28200 2250 1116 0 0 2951 -637
    665 ######## 8010 FD89 5 84 5619 6737 24204 -637 50.5 801 0 65535 6138 7256 529 65535 -10 36828 -811 416 1096 65408 514 48.8 15 96 28200 2250 1118 0 0 2951 -642
    666 ######## 8022 FD81 5 84 5617 6737 24192 -641 50.6 801 0 65535 6136 7256 525 65535 -10 36816 -811 416 1096 65402 491 48.8 15 96 28200 2250 1120 0 0 2951 -642
    667 ######## 8034 FD80 5 84 5613 6737 24192 -644 50.8 801 0 65535 6132 7256 523 65535 -10 36792 -811 415 1095 65406 505 49 15 96 28200 2250 1124 0 0 2951 -644
    668 ######## 8046 FD7E 5 84 5612 6737 24192 -643 50.5 801 0 65535 6131 7256 524 65535 -10 36786 -811 415 1095 65407 509 49 15 96 28200 2250 1126 0 0 2951 -640
    669 ######## 8058 FD83 5 84 5610 6737 24192 -642 50.7 801 0 65535 6129 7256 524 65535 -10 36774 -811 415 1094 65407 509 49 15 96 28200 2250 1127 0 0 2951 -640
    670 ######## 8070 FD7F 5 84 5608 6737 24192 -642 50.7 801 0 65535 6127 7256 524 65535 -10 36762 -811 415 1094 65407 509 49 15 96 28200 2250 1129 0 0 2951 -641
    671 ######## 8082 FD85 5 84 5606 6737 24192 -643 51.1 801 0 65535 6125 7256 523 65535 -10 36750 -811 415 1094 65408 513 49.1 15 96 28200 2250 1131 0 0 2951 -660
    672 ######## 8094 FD81 5 84 5604 6737 24192 -643 51.4 801 0 65535 6123 7256 523 65535 -10 36738 -811 415 1093 65407 508 49.2 15 96 28200 2250 1133 0 0 2951 -639
    673 ######## 8106 FD82 5 84 5602 6737 24192 -642 51.3 801 0 65535 6121 7256 524 65535 -10 36726 -811 414 1093 65406 504 49.2 15 96 28200 2250 1135 0 0 2951 -643
    674 ######## 8118 FD76 5 84 5599 6737 24180 -643 51.6 801 0 65535 6117 7256 522 65535 -10 36702 -811 414 1092 65407 508 49.4 15 96 28200 2250 1139 0 0 2951 -642
    675 ######## 8130 FD82 5 84 5597 6737 24180 -642 51.7 801 0 65535 6116 7256 523 65535 -10 36696 -811 414 1092 65407 508 49.5 15 96 28200 2250 1140 0 0 2951 -641
    676 ######## 8142 FD82 5 84 5595 6737 24180 -642 51.6 801 0 65535 6114 7256 523 65535 -10 36684 -811 414 1091 65407 507 49.4 15 96 28200 2250 1142 0 0 2951 -644
    677 ######## 8154 FD83 5 84 5593 6737 24180 -643 51.2 801 0 65535 6112 7256 522 65535 -10 36672 -811 414 1091 65406 504 49.4 15 96 28200 2250 1144 0 0 2951 -644
    678 ######## 8166 FD7F 5 83 5591 6737 24180 -642 51.5 801 0 65535 6110 7256 523 65535 -10 36660 -811 414 1091 65406 504 49.4 15 96 28200 2250 1146 0 0 2951 -640
    679 ######## 8178 FD7E 5 83 5589 6737 24180 -640 51.7 801 0 65535 6108 7256 524 65535 -10 36648 -811 413 1090 65407 507 49.5 15 96 28200 2250 1148 0 0 2951 -636
    680 ######## 8190 FD84 5 83 5587 6737 24180 -639 51.7 801 0 65535 6106 7256 525 65535 -10 36636 -811 413 1090 65407 507 49.5 15 96 28200 2250 1150 0 0 2951 -640
    681 ######## 8203 FD86 5 83 5584 6737 24180 -639 51.3 801 0 65535 6103 7256 524 65535 -10 36612 -811 413 1089 65407 507 49.4 15 96 28200 2250 1154 0 0 2951 -637
    682 ######## 8215 FD87 5 83 5582 6737 24168 -638 51.5 801 0 65535 6101 7256 525 65535 -10 36606 -811 413 1089 65407 507 49.4 15 96 28200 2250 1156 0 0 2951 -640
    683 ######## 8227 FD86 5 83 5580 6737 24168 -640 51.5 801 0 65535 6099 7256 523 65535 -10 36594 -811 413 1088 65408 510 49.5 15 96 28200 2250 1158 0 0 2951 -637
    684 ######## 8239 FD83 5 83 5578 6737 24168 -639 51.5 801 0 65535 6097 7256 524 65535 -10 36582 -811 413 1088 65407 506 49.5 15 96 28200 2250 1160 0 0 2951 -641
    685 ######## 8251 FD86 5 83 5576 6737 24168 -640 51.6 801 0 65535 6095 7256 523 65535 -10 36570 -811 413 1088 65407 506 49.5 15 96 28200 2250 1161 0 0 2951 -640
    686 ######## 8263 FD84 5 83 5574 6737 24168 -639 51.6 801 0 65535 6093 7256 523 65535 -10 36558 -811 412 1087 65408 510 49.5 15 96 28200 2250 1163 0 0 2951 -638
    687 ######## 8275 FD85 5 83 5572 6737 24168 -638 51.4 801 0 65535 6091 7256 524 65535 -10 36546 -811 412 1087 65408 510 49.5 15 96 28200 2250 1165 0 0 2951 -645
    688 ######## 8287 FD80 5 83 5570 6737 24168 -639 51.2 801 0 65535 6089 7256 523 65535 -10 36534 -811 412 1086 65407 505 49.4 15 96 28200 2250 1167 0 0 2951 -635
    689 ######## 8299 FD80 5 83 5566 6737 24168 -639 50.8 801 0 65535 6085 7256 523 65535 -10 36510 -811 412 1086 65408 509 49.2 15 96 28200 2250 1171 0 0 2951 -635
    690 ######## 8311 FD83 5 83 5565 6737 24156 -638 50.7 801 0 65535 6084 7256 523 65535 -10 36504 -811 412 1085 65408 509 49.2 15 96 28200 2250 1173 0 0 2951 -635
    691 ######## 8323 FD87 5 83 5563 6737 24168 -638 50.8 801 0 65535 6082 7256 523 65535 -10 36492 -811 412 1085 65408 509 49.1 15 96 28200 2250 1174 0 0 2951 -640
    692 ######## 8335 FD85 5 83 5561 6737 24168 -637 50.8 801 0 65535 6080 7256 524 65535 -10 36480 -811 411 1085 65407 505 49.1 15 96 28200 2250 1176 0 0 2951 -639
    693 ######## 8348 FD85 5 83 5559 6737 24156 -637 50.8 801 0 65535 6078 7256 524 65535 -10 36468 -811 411 1084 65408 508 49.1 15 96 28200 2250 1178 0 0 2951 -641
    694 ######## 8360 FD85 5 83 5557 6737 24156 -638 50.6 801 0 65535 6076 7256 523 65535 -10 36456 -811 411 1084 65407 504 49 15 96 28200 2250 1180 0 0 2951 -637
    695 ######## 8372 FD86 5 83 5555 6737 24156 -638 50.7 801 0 65535 6074 7256 522 65535 -10 36444 -811 411 1083 65407 504 49 15 96 28200 2250 1182 0 0 2951 -641
    696 ######## 8384 FD83 5 83 5552 6737 24156 -637 50.4 801 0 65535 6071 7256 523 65535 -10 36426 -811 411 1083 65408 508 48.9 15 96 28200 2250 1186 0 0 2951 -639
    697 ######## 8396 FD87 5 83 5550 6737 24156 -637 50.5 801 0 65535 6069 7256 523 65535 -10 36414 -811 411 1082 65407 503 48.9 15 96 28200 2250 1188 0 0 2951 -637
    698 ######## 8408 FD80 5 83 5548 6737 24144 -639 50.3 801 0 65535 6067 7256 521 65535 -10 36402 -811 410 1082 65408 507 48.8 15 96 28200 2250 1189 0 0 2951 -636
    699 ######## 8420 FD83 5 83 5546 6737 24144 -639 50.3 801 0 65535 6065 7256 521 65535 -10 36390 -811 410 1082 65405 496 48.8 15 96 28200 2250 1191 0 0 2951 -638
    700 ######## 8432 FD84 5 83 5544 6737 24144 -638 50.5 801 0 65535 6063 7256 521 65535 -10 36378 -811 410 1081 65408 507 48.8 15 96 28200 2250 1193 0 0 2951 -639
    701 ######## 8444 FD79 5 83 5542 6737 24144 -638 50.5 801 0 65535 6061 7256 521 65535 -10 36366 -811 410 1081 65408 507 48.9 15 96 28200 2250 1195 0 0 2951 -636
    702 ######## 8456 FD85 5 83 5540 6737 24144 -638 50.4 801 0 65535 6059 7256 521 65535 -10 36354 -811 410 1080 65408 506 48.8 15 96 28200 2250 1197 0 0 2951 -637
    703 ######## 8468 FD85 5 83 5537 6737 24144 -639 49.9 801 0 65535 6056 7256 520 65535 -10 36336 -811 410 1080 65407 502 48.6 15 96 28200 2250 1200 0 0 2951 -639
    704 ######## 8480 FD84 5 83 5535 6737 24144 -639 50 801 0 65535 6054 7256 520 65535 -10 36324 -811 409 1079 65408 506 48.6 15 96 28200 2250 1202 0 0 2951 -642
    705 ######## 8492 FD81 5 83 5533 6737 24144 -639 49.9 801 0 65535 6052 7256 520 65535 -10 36312 -811 409 1079 65407 502 48.6 15 96 28200 2250 1204 0 0 2951 -637
    706 ######## 8504 FD87 5 83 5531 6737 24144 -638 49.9 801 0 65535 6050 7256 520 65535 -10 36300 -811 409 1079 65408 506 48.5 15 96 28200 2250 1206 0 0 2951 -638
    707 ######## 8516 FD84 5 83 5529 6737 24132 -638 50.2 801 0 65535 6048 7256 520 65535 -10 36288 -811 409 1078 65408 505 48.6 15 96 28200 2250 1208 0 0 2951 -639
    708 ######## 8528 FD83 5 83 5528 6737 24144 -638 49.8 801 0 65535 6046 7256 521 65535 -10 36276 -811 409 1078 65408 505 48.5 15 96 28200 2250 1210 0 0 2951 -640
    709 ######## 8540 FD85 5 82 5524 6737 24120 -638 49.9 801 0 65535 6043 7256 519 65535 -10 36258 -811 409 1077 65408 505 48.5 15 96 28200 2250 1213 0 0 2951 -646
    710 ######## 8552 FD87 5 82 5522 6737 24132 -638 50.1 801 0 65535 6041 7256 519 65535 -10 36246 -811 409 1077 65408 505 48.5 15 96 28200 2250 1215 0 0 2951 -639
    711 ######## 8564 FD85 5 82 5520 6737 24132 -638 50.2 801 0 65535 6039 7256 519 65535 -10 36234 -811 408 1076 65406 500 48.5 15 96 28200 2250 1217 0 0 2951 -644
    712 ######## 8576 FD84 5 82 5518 6737 24120 -640 50.2 801 0 65535 6037 7256 518 65535 -10 36222 -811 408 1076 65408 504 48.6 15 96 28200 2250 1219 0 0 2951 -638
    713 ######## 8588 FD85 5 82 5516 6737 24120 -639 50.1 801 0 65535 6035 7256 518 65535 -10 36210 -811 408 1075 65408 504 48.6 15 96 28200 2250 1221 0 0 2951 -639
    714 ######## 8600 FD81 5 82 5515 6737 24120 -638 50.2 801 0 65535 6033 7256 519 65535 -10 36198 -811 408 1075 65408 504 48.5 15 96 28200 2250 1223 0 0 2951 -638
    715 ######## 8612 FD86 5 82 5513 6737 24120 -638 50 801 0 65535 6032 7256 518 65535 -10 36192 -811 408 1075 65408 504 48.5 15 96 28200 2250 1225 0 0 2951 -639
    716 ######## 8624 FD84 5 82 5509 6737 24120 -640 50.3 801 0 65535 6028 7256 516 65535 -10 36168 -811 408 1074 65408 503 48.6 15 96 28200 2250 1228 0 0 2951 -644
    717 ######## 8636 FD83 5 82 5507 6737 24120 -639 50 801 0 65535 6026 7256 517 65535 -10 36156 -811 407 1074 65407 500 48.6 15 96 28200 2250 1230 0 0 2951 -636
    718 ######## 8649 FD7D 5 82 5505 6737 24120 -640 50.2 801 0 65535 6024 7256 516 65535 -10 36144 -811 407 1073 65408 503 48.6 15 96 28200 2250 1232 0 0 2951 -635
    719 ######## 8661 FD81 5 82 5504 6737 24120 -639 50 801 0 65535 6022 7256 517 65535 -10 36132 -811 407 1073 65408 503 48.6 15 96 28200 2250 1234 0 0 2951 -637
    720 ######## 8673 FD7E 5 82 5502 6737 24120 -639 50.2 801 0 65535 6021 7256 517 65535 -10 36126 -811 407 1072 65408 503 48.7 15 96 28200 2250 1236 0 0 2951 -638
    721 ######## 8685 FD82 5 82 5500 6737 24108 -639 50 801 0 65535 6019 7256 516 65535 -10 36114 -811 407 1072 65408 503 48.6 15 96 28200 2250 1237 0 0 2951 -636
    722 ######## 8697 FD81 5 82 5498 6737 24108 -638 50.3 801 0 65535 6017 7256 517 65535 -10 36102 -811 407 1072 65408 503 48.6 15 96 28200 2250 1239 0 0 2951 -639
    723 ######## 8709 FD7F 5 82 5494 6737 24108 -638 49.8 801 0 65535 6013 7256 517 65535 -10 36078 -811 406 1071 65408 502 48.5 15 96 28200 2250 1243 0 0 2951 -637
    724 ######## 8721 FD86 5 82 5492 6737 24108 -637 50 801 0 65535 6011 7256 516 65535 -10 36066 -811 406 1071 65408 502 48.5 15 96 28200 2250 1245 0 0 2951 -639
    725 ######## 8733 FD7C 5 82 5490 6737 24108 -638 50.2 801 0 65535 6009 7256 516 65535 -10 36054 -811 406 1070 65408 502 48.5 15 96 28200 2250 1247 0 0 2951 -638
    726 ######## 8745 FD7F 5 82 5488 6737 24096 -638 50.2 801 0 65535 6007 7256 516 65535 -10 36042 -811 406 1070 65408 502 48.6 15 96 28200 2250 1249 0 0 2951 -644
    727 ######## 8757 FD85 5 82 5487 6737 24108 -638 49.9 801 0 65535 6006 7256 516 65535 -10 36036 -811 406 1070 65408 502 48.5 15 96 28200 2250 1250 0 0 2951 -639
    728 ######## 8769 FD83 5 82 5485 6737 24096 -638 50 801 0 65535 6004 7256 516 65535 -10 36024 -811 406 1069 65407 497 48.5 15 96 28200 2250 1252 0 0 2951 -640
    729 ######## 8781 FD86 5 82 5483 6737 24096 -638 49.8 801 0 65535 6002 7256 516 65535 -10 36012 -811 406 1069 65407 497 48.4 15 96 28200 2250 1254 0 0 2951 -640
    730 ######## 8793 FD82 5 82 5481 6737 24096 -637 49.8 801 0 65535 6000 7256 516 65535 -10 36000 -811 405 1068 65408 501 48.4 15 96 28200 2250 1256 0 0 2951 -637
    731 ######## 8805 FD81 5 82 5477 6737 24084 -639 49.5 801 0 65535 5996 7256 514 65535 -10 35976 -811 405 1068 65408 501 48.3 15 96 28200 2250 1260 0 0 2951 -638
    732 ######## 8817 FD85 5 82 5476 6737 24084 -638 49.9 801 0 65535 5994 7256 514 65535 -10 35964 -811 405 1067 65406 492 48.3 15 96 28200 2250 1262 0 0 2951 -639
    733 ######## 8829 FD85 5 82 5474 6737 24084 -638 49.7 801 0 65535 5993 7256 515 65535 -10 35952 -811 405 1067 65408 500 48.3 15 96 28200 2250 1264 0 0 2951 -636
    734 ######## 8841 FD6D 5 82 5472 6737 24084 -641 49.7 801 0 65535 5991 7256 512 65535 -10 35946 -811 405 1067 65408 500 48.3 15 96 28200 2250 1266 0 0 2951 -641
    735 ######## 8853 FD7D 5 82 5470 6737 24084 -643 49.8 801 0 65535 5989 7256 510 65535 -10 35934 -811 405 1066 65407 496 48.3 15 96 28200 2250 1267 0 0 2951 -641
    736 ######## 8865 FD80 5 82 5468 6737 24084 -642 49.8 801 0 65535 5987 7256 511 65535 -10 35922 -811 405 1066 65407 496 48.3 15 96 28200 2250 1269 0 0 2951 -641
    737 ######## 8877 FD7E 5 82 5466 6737 24084 -642 49.7 801 0 65535 5985 7256 511 65535 -10 35910 -811 404 1065 65407 495 48.3 15 96 28200 2250 1271 0 0 2951 -646
    738 ######## 8889 FD79 5 82 5462 6737 24084 -643 49.8 801 0 65535 5981 7256 510 65535 -10 35886 -811 404 1065 65408 499 48.3 15 96 28200 2250 1275 0 0 2951 -639
    739 ######## 8901 FD88 5 82 5460 6737 24084 -641 50.1 801 0 65535 5979 7256 511 65535 -10 35874 -811 404 1064 65408 499 48.4 15 96 28200 2250 1277 0 0 2951 -639
    740 ######## 8913 FD85 5 82 5459 6737 24084 -639 50.2 801 0 65535 5977 7256 512 65535 -10 35862 -811 404 1064 65408 499 48.4 15 96 28200 2250 1279 0 0 2951 -638
    741 ######## 8925 FD82 5 82 5457 6737 24072 -639 50.1 801 0 65535 5976 7256 512 65535 -10 35856 -811 404 1064 65406 491 48.5 15 96 28200 2250 1281 0 0 2951 -646
    742 ######## 8937 FD86 5 81 5455 6737 24084 -639 49.9 801 0 65535 5974 7256 512 65535 -10 35844 -811 404 1063 65408 498 48.5 15 96 28200 2250 1282 0 0 2951 -638
    743 ######## 8949 FD85 5 81 5453 6737 24072 -638 50 801 0 65535 5972 7256 513 65535 -10 35832 -811 403 1063 65407 494 48.4 15 96 28200 2250 1284 0 0 2951 -644
    744 ######## 8962 FD86 5 81 5451 6737 24072 -638 49.8 801 0 65535 5970 7256 513 65535 -10 35820 -811 403 1062 65407 494 48.4 15 96 28200 2250 1286 0 0 2951 -641
    745 ######## 8974 FD80 5 81 5447 6737 24060 -638 49.4 801 0 65535 5966 7256 512 65535 -10 35796 -811 403 1062 65408 498 48.3 15 96 28200 2250 1290 0 0 2951 -637
    746 ######## 8986 FD80 5 81 5446 6737 24060 -638 49.7 801 0 65535 5965 7256 512 65535 -10 35784 -811 403 1061 65408 497 48.3 15 96 28200 2250 1292 0 0 2951 -637
    747 ######## 8998 FD84 5 81 5444 6737 24060 -639 49.6 801 0 65535 5963 7256 511 65535 -10 35778 -811 403 1061 65408 497 48.3 15 96 28200 2250 1294 0 0 2951 -640
    748 ######## 9010 FD85 5 81 5442 6737 24060 -638 49.6 801 0 65535 5961 7256 512 65535 -10 35766 -811 403 1061 65408 497 48.3 15 96 28200 2250 1295 0 0 2951 -636
    749 ######## 9022 FD83 5 81 5440 6737 24060 -638 49.8 801 0 65535 5959 7256 512 65535 -10 35754 -811 402 1060 65406 489 48.3 15 96 28200 2250 1297 0 0 2951 -639
    750 ######## 9034 FD84 5 81 5438 6737 24060 -638 50 801 0 65535 5957 7256 511 65535 -10 35742 -811 402 1060 65408 497 48.3 15 96 28200 2250 1299 0 0 2951 -638
    751 ######## 9046 FD82 5 81 5434 6737 24060 -640 49.7 801 0 65535 5953 7256 509 65535 -10 35718 -811 402 1059 65408 496 48.2 15 96 28200 2250 1303 0 0 2951 -639
    752 ######## 9058 FD84 5 81 5433 6737 24060 -639 49.7 801 0 65535 5951 7256 510 65535 -10 35706 -811 402 1059 65408 496 48.3 15 96 28200 2250 1305 0 0 2951 -636
    753 ######## 9070 FD83 5 81 5431 6737 24060 -638 49.7 801 0 65535 5950 7256 511 65535 -10 35700 -811 402 1058 65409 492 48.3 15 96 28200 2250 1306 0 0 2951 -641
    754 ######## 9082 FD83 5 81 5429 6737 24060 -639 49.8 801 0 65535 5948 7256 510 65535 -10 35688 -811 402 1058 65408 496 48.3 15 96 28200 2250 1308 0 0 2951 -635
    755 ######## 9094 FD81 5 81 5427 6737 24048 -639 50 801 0 65535 5946 7256 510 65535 -10 35676 -811 402 1058 65409 500 48.4 15 96 28200 2250 1310 0 0 2951 -636
    756 ######## 9106 FD83 5 81 5425 6737 24048 -638 49.7 801 0 65535 5944 7256 510 65535 -10 35664 -811 401 1057 65408 495 48.3 15 96 28200 2250 1312 0 0 2951 -639
    757 ######## 9118 FD75 5 81 5423 6737 24048 -639 50 801 0 65535 5942 7256 509 65535 -10 35652 -811 401 1057 65408 495 48.3 15 96 28200 2250 1314 0 0 2951 -639
    758 ######## 9131 FD84 5 81 5420 6737 24048 -639 49.8 801 0 65535 5939 7256 509 65535 -10 35634 -811 401 1056 65409 499 48.3 15 96 28200 2250 1318 0 0 2951 -636
    759 ######## 9143 FD86 5 81 5418 6737 24048 -638 50 801 0 65535 5937 7256 510 65535 -10 35622 -811 401 1056 65408 495 48.3 15 96 28200 2250 1319 0 0 2951 -640
    760 ######## 9155 FD83 5 81 5416 6737 24048 -638 49.6 801 0 65535 5935 7256 509 65535 -10 35610 -811 401 1055 65408 495 48.3 15 96 28200 2250 1321 0 0 2951 -639
    761 ######## 9167 FD87 5 81 5414 6737 24036 -637 49.5 801 0 65535 5933 7256 510 65535 -10 35598 -811 401 1055 65408 495 48.3 15 96 28200 2250 1323 0 0 2951 -641
    762 ######## 9179 FD7B 5 81 5412 6737 24036 -641 49.7 801 0 65535 5931 7256 507 65535 -10 35586 -811 400 1055 65407 491 48.3 15 96 28200 2250 1325 0 0 2951 -644
    763 ######## 9191 FD7D 5 81 5410 6737 24036 -641 49.6 801 0 65535 5929 7256 506 65535 -10 35574 -811 400 1054 65404 479 48.3 15 96 28200 2250 1327 0 0 2951 -640
    764 ######## 9203 FD84 5 81 5408 6737 24036 -642 49.8 801 0 65535 5927 7256 505 65535 -10 35562 -811 400 1054 65409 498 48.3 15 96 28200 2250 1329 0 0 2951 -644
    765 ######## 9215 FD80 5 81 5407 6737 24036 -641 49.9 801 0 65535 5925 7256 506 65535 -10 35550 -811 400 1053 65407 490 48.3 15 96 28200 2250 1331 0 0 2951 -639
    766 ######## 9227 FD80 5 81 5403 6737 24024 -643 50.1 801 0 65535 5922 7256 504 65535 -10 35532 -811 400 1053 65408 494 48.5 15 96 28200 2250 1334 0 0 2951 -640
    767 ######## 9239 FD7F 5 81 5401 6737 24024 -641 50.1 801 0 65535 5920 7256 506 65535 -10 35520 -811 400 1052 65408 493 48.5 15 96 28200 2250 1336 0 0 2951 -637
    768 ######## 9251 FD83 5 81 5399 6737 24024 -642 50.1 801 0 65535 5918 7256 505 65535 -10 35508 -811 399 1052 65408 493 48.5 15 96 28200 2250 1338 0 0 2951 -641
    769 ######## 9263 FD7E 5 81 5397 6737 24024 -641 50.2 801 0 65535 5916 7256 505 65535 -10 35496 -811 399 1052 65408 493 48.5 15 96 28200 2250 1340 0 0 2951 -639
    770 ######## 9275 FD80 5 81 5395 6737 24012 -642 50 801 0 65535 5914 7256 503 65535 -10 35484 -811 399 1051 65407 489 48.5 15 96 28200 2250 1342 0 0 2951 -643
    771 ######## 9287 FD81 5 81 5394 6737 24024 -643 50.1 801 0 65535 5913 7256 503 65535 -10 35478 -811 399 1051 65408 493 48.5 15 96 28200 2250 1344 0 0 2951 -638
    772 ######## 9299 FD83 5 81 5390 6737 24012 -641 50.3 801 0 65535 5909 7256 505 65535 -10 35454 -811 399 1050 65408 492 48.6 15 96 28200 2250 1347 0 0 2951 -641
    773 ######## 9311 FD80 5 80 5388 6737 24012 -641 50.2 801 0 65535 5907 7256 504 65535 -10 35442 -811 399 1050 65408 492 48.7 15 96 28200 2250 1349 0 0 2951 -643
    774 ######## 9323 FD84 5 80 5386 6737 24012 -641 50.4 801 0 65535 5905 7256 504 65535 -10 35430 -811 398 1049 65408 492 48.7 15 96 28200 2250 1351 0 0 2951 -641
    775 ######## 9335 FD81 5 80 5384 6737 24012 -641 50 801 0 65535 5903 7256 504 65535 -10 35418 -811 398 1049 65407 488 48.6 15 96 28200 2250 1353 0 0 2951 -643
    776 ######## 9347 FD81 5 80 5382 6737 24012 -641 49.9 801 0 65535 5901 7256 504 65535 -10 35406 -811 398 1049 65408 492 48.6 15 96 28200 2250 1355 0 0 2951 -644
    777 ######## 9359 FD83 5 80 5381 6737 24012 -641 50 801 0 65535 5900 7256 504 65535 -10 35400 -811 398 1048 65408 491 48.6 15 96 28200 2250 1356 0 0 2951 -641
    778 ######## 9371 FD84 5 80 5377 6737 24012 -641 50.1 801 0 65535 5896 7256 503 65535 -10 35376 -811 398 1048 65408 491 48.5 15 96 28200 2250 1360 0 0 2951 -639
    779 ######## 9383 FD7C 5 80 5375 6737 24012 -641 50.1 801 0 65535 5894 7256 503 65535 -10 35364 -811 398 1047 65408 491 48.5 15 96 28200 2250 1362 0 0 2951 -639
    780 ######## 9395 FD81 5 80 5373 6737 24012 -640 50 801 0 65535 5892 7256 504 65535 -10 35352 -811 398 1047 65408 491 48.5 15 96 28200 2250 1364 0 0 2951 -639
    781 ######## 9407 FD7F 5 80 5371 6737 24012 -641 50.2 801 0 65535 5890 7256 503 65535 -10 35340 -811 397 1046 65408 490 48.5 15 96 28200 2250 1366 0 0 2951 -642
    782 ######## 9419 FD7F 5 80 5369 6737 24000 -641 50.2 801 0 65535 5888 7256 503 65535 -10 35328 -811 397 1046 65408 490 48.6 15 96 28200 2250 1368 0 0 2951 -640
    783 ######## 9431 FD81 5 80 5368 6737 24000 -640 50 801 0 65535 5887 7256 503 65535 -10 35322 -811 397 1046 65408 490 48.5 15 96 28200 2250 1370 0 0 2951 -642
    784 ######## 9443 FD84 5 80 5366 6737 24000 -640 50.1 801 0 65535 5885 7256 503 65535 -10 35310 -811 397 1045 65408 490 48.5 15 96 28200 2250 1371 0 0 2951 -642
    785 ######## 9455 FD7F 5 80 5364 6737 24000 -641 50.1 801 0 65535 5883 7256 502 65535 -10 35298 -811 397 1045 65407 486 48.5 15 96 28200 2250 1373 0 0 2951 -642
    786 ######## 9467 FD81 5 80 5360 6737 23988 -640 50 801 0 65535 5879 7256 503 65535 -10 35274 -811 397 1044 65408 489 48.5 15 96 28200 2250 1377 0 0 2951 -642
    787 ######## 9479 FD7D 5 80 5358 6737 23988 -642 49.9 801 0 65535 5877 7256 502 65535 -10 35262 -811 396 1044 65408 489 48.5 15 96 28200 2250 1379 0 0 2951 -643
    788 ######## 9491 FD80 5 80 5356 6737 23988 -641 50.2 801 0 65535 5875 7256 501 65535 -10 35250 -811 396 1043 65407 485 48.5 15 96 28200 2250 1381 0 0 2951 -644
    789 ######## 9503 FD81 5 80 5355 6737 23988 -641 50.2 801 0 65535 5873 7256 501 65535 -10 35238 -811 396 1043 65408 489 48.5 15 96 28200 2250 1383 0 0 2951 -640
    790 ######## 9515 FD7D 5 80 5353 6737 23988 -641 50.1 801 0 65535 5872 7256 501 65535 -10 35226 -811 396 1043 65408 489 48.5 15 96 28200 2250 1385 0 0 2951 -641
    791 ######## 9527 FD80 5 80 5351 6737 23988 -641 50 801 0 65535 5870 7256 501 65535 -10 35214 -811 396 1042 65408 488 48.5 15 96 28200 2250 1387 0 0 2951 -644
    792 ######## 9539 FD84 5 80 5349 6737 23988 -641 50.3 801 0 65535 5868 7256 501 65535 -10 35208 -811 396 1042 65408 488 48.5 15 96 28200 2250 1389 0 0 2951 -642
    793 ######## 9551 FD7B 5 80 5345 6737 23976 -644 50 801 0 65535 5864 7256 498 65535 -10 35184 -811 395 1041 65408 488 48.5 15 96 28200 2250 1392 0 0 2951 -641
    794 ######## 9563 FD7E 5 80 5343 6737 23976 -644 50 801 0 65535 5862 7256 498 65535 -10 35172 -811 395 1041 65408 488 48.5 15 96 28200 2250 1394 0 0 2951 -641
    795 ######## 9575 FD82 5 80 5341 6737 23976 -643 50.3 801 0 65535 5860 7256 498 65535 -10 35160 -811 395 1040 65407 484 48.5 15 96 28200 2250 1396 0 0 2951 -643
    796 ######## 9587 FD7B 5 80 5339 6737 23976 -643 50.3 801 0 65535 5858 7256 498 65535 -10 35148 -811 395 1040 65408 488 48.5 15 96 28200 2250 1398 0 0 2951 -643
    797 ######## 9599 FD7E 5 80 5338 6737 23976 -643 50.2 801 0 65535 5857 7256 498 65535 -10 35136 -811 395 1040 65407 484 48.5 15 96 28200 2250 1400 0 0 2951 -645
    798 ######## 9611 FD79 5 80 5336 6737 23976 -644 50.2 801 0 65535 5855 7256 497 65535 -10 35130 -811 395 1039 65407 483 48.6 15 96 28200 2250 1402 0 0 2951 -645
    799 ######## 9623 FD7E 5 80 5334 6737 23964 -643 50 801 0 65535 5853 7256 498 65535 -10 35118 -811 395 1039 65407 483 48.6 15 96 28200 2250 1403 0 0 2951 -640
    800 ######## 9636 FD79 5 80 5330 6737 23964 -643 50.1 801 0 65535 5849 7256 497 65535 -10 35094 -811 394 1038 65408 487 48.6 15 96 28200 2250 1407 0 0 2951 -642
    801 ######## 9648 FD7D 5 80 5328 6737 23964 -644 50.2 801 0 65535 5847 7256 496 65535 -10 35082 -811 394 1038 65408 483 48.5 15 96 28200 2250 1409 0 0 2951 -644
    802 ######## 9660 FD70 5 80 5326 6737 23964 -644 50.1 801 0 65535 5845 7256 496 65535 -10 35070 -811 394 1037 65408 486 48.6 15 96 28200 2250 1411 0 0 2951 -645
    803 ######## 9672 FD7C 5 80 5324 6737 23964 -645 50.3 801 0 65535 5843 7256 496 65535 -10 35058 -811 394 1037 65408 486 48.6 15 96 28200 2250 1413 0 0 2951 -642
    804 ######## 9684 FD7D 5 80 5323 6737 23952 -644 50.2 801 0 65535 5842 7256 496 65535 -10 35052 -811 394 1037 65408 486 48.6 15 96 28200 2250 1415 0 0 2951 -642
    805 ######## 9696 FD7D 5 79 5321 6737 23964 -643 50.2 801 0 65535 5840 7256 497 65535 -10 35040 -811 394 1036 65407 482 48.6 15 96 28200 2250 1417 0 0 2951 -642
    806 ######## 9708 FD81 5 79 5319 6737 23964 -643 50.1 801 0 65535 5838 7256 496 65535 -10 35028 -811 394 1036 65408 486 48.5 15 96 28200 2250 1418 0 0 2951 -643
    807 ######## 9720 FD82 5 79 5315 6737 23964 -643 50 801 0 65535 5834 7256 496 65535 -10 35004 -811 393 1035 65408 485 48.5 15 96 28200 2250 1422 0 0 2951 -642
    808 ######## 9732 FD80 5 79 5313 6737 23952 -644 50.1 801 0 65535 5832 7256 495 65535 -10 34992 -811 393 1035 65408 485 48.5 15 96 28200 2250 1424 0 0 2951 -644
    809 ######## 9744 FD7C 5 79 5311 6737 23952 -643 50 801 0 65535 5830 7256 496 65535 -10 34980 -811 393 1034 65407 481 48.5 15 96 28200 2250 1426 0 0 2951 -645
    810 ######## 9756 FD7F 5 79 5309 6737 23952 -643 49.8 801 0 65535 5828 7256 495 65535 -10 34968 -811 393 1034 65408 485 48.5 15 96 28200 2250 1428 0 0 2951 -643
    811 ######## 9768 FD7C 5 79 5308 6737 23952 -643 50.2 801 0 65535 5827 7256 495 65535 -10 34956 -811 393 1034 65407 481 48.5 15 96 28200 2250 1430 0 0 2951 -641
    812 ######## 9780 FD7F 5 79 5306 6737 23940 -644 50.3 801 0 65535 5825 7256 494 65535 -10 34950 -811 392 1033 65408 484 48.5 15 96 28200 2250 1432 0 0 2951 -642
    813 ######## 9792 FD76 5 79 5304 6737 23940 -644 50.4 801 0 65535 5823 7256 494 65535 -10 34938 -811 392 1033 65408 484 48.5 15 96 28200 2250 1434 0 0 2951 -643
    814 ######## 9804 FD7D 5 79 5300 6737 23940 -645 50.3 801 0 65535 5819 7256 493 65535 -10 34914 -811 392 1032 65408 484 48.5 15 96 28200 2250 1437 0 0 2951 -644
    815 ######## 9816 FD7E 5 79 5298 6737 23940 -644 50.2 801 0 65535 5817 7256 494 65535 -10 34902 -811 392 1032 65407 480 48.5 15 96 28200 2250 1439 0 0 2951 -646
    816 ######## 9828 FD7F 5 79 5296 6737 23940 -644 50.1 801 0 65535 5815 7256 494 65535 -10 34890 -811 392 1031 65409 487 48.5 15 96 28200 2250 1441 0 0 2951 -642
    817 ######## 9840 FD7D 5 79 5294 6737 23940 -643 50.3 801 0 65535 5813 7256 494 65535 -10 34878 -811 392 1031 65408 483 48.6 15 96 28200 2250 1443 0 0 2951 -642
    818 ######## 9852 FD81 5 79 5293 6737 23940 -643 49.7 801 0 65535 5812 7256 495 65535 -10 34866 -811 392 1031 65408 483 48.5 15 96 28200 2250 1445 0 0 2951 -642
    819 ######## 9864 FD7C 5 79 5291 6737 23940 -643 49.7 801 0 65535 5810 7256 494 65535 -10 34860 -811 391 1030 65408 483 48.4 15 96 28200 2250 1446 0 0 2951 -644
    820 ######## 9876 FD81 5 79 5289 6737 23940 -642 49.8 801 0 65535 5808 7256 494 65535 -10 34848 -811 391 1030 65409 487 48.4 15 96 28200 2250 1448 0 0 2951 -650
    821 ######## 9888 FD7D 5 79 5285 6737 23928 -644 50.2 801 0 65535 5804 7256 492 65535 -10 34824 -811 391 1029 65408 482 48.5 15 96 28200 2250 1452 0 0 2951 -645
    822 ######## 9900 FD80 5 79 5283 6737 23928 -643 50.2 801 0 65535 5802 7256 493 65535 -10 34812 -811 391 1029 65408 482 48.5 15 96 28200 2250 1454 0 0 2951 -644
    823 ######## 9912 FD7B 5 79 5281 6737 23928 -643 50.2 801 0 65535 5800 7256 493 65535 -10 34800 -811 391 1028 65408 482 48.5 15 96 28200 2250 1456 0 0 2951 -641
    824 ######## 9924 FD7E 5 79 5279 6737 23928 -643 50.2 801 0 65535 5798 7256 493 65535 -10 34788 -811 391 1028 65408 482 48.5 15 96 28200 2250 1458 0 0 2951 -641
    825 ######## 9936 FD81 5 79 5277 6737 23928 -643 50 801 0 65535 5796 7256 492 65535 -10 34776 -811 390 1028 65408 482 48.5 15 96 28200 2250 1460 0 0 2951 -643
    826 ######## 9948 FD7A 5 79 5276 6737 23916 -643 50.2 801 0 65535 5795 7256 492 65535 -10 34770 -811 390 1027 65408 481 48.5 15 96 28200 2250 1462 0 0 2951 -644
    827 ######## 9960 FD82 5 79 5274 6737 23916 -643 50.4 801 0 65535 5793 7256 492 65535 -10 34758 -811 390 1027 65407 478 48.6 15 96 28200 2250 1463 0 0 2951 -644
    828 ######## 9973 FD7F 5 79 5272 6737 23916 -643 50.4 801 0 65535 5791 7256 492 65535 -10 34746 -811 390 1027 65408 481 48.7 15 96 28200 2250 1465 0 0 2951 -645
    829 ######## 9985 FD81 5 79 5268 6737 23916 -643 50.3 801 0 65535 5787 7256 492 65535 -10 34722 -811 390 1026 65408 481 48.7 15 96 28200 2250 1469 0 0 2951 -645
    830 ######## 9997 FD80 5 79 5266 6737 23916 -645 50.5 801 0 65535 5785 7256 490 65535 -10 34710 -811 390 1025 65408 480 48.7 15 96 28200 2250 1471 0 0 2951 -648
    831 ######## 10009 FD7D 5 79 5264 6737 23904 -644 50.4 801 0 65535 5783 7256 490 65535 -10 34698 -811 389 1025 65408 480 48.7 15 96 28200 2250 1473 0 0 2951 -641
    832 ######## 10021 FD7D 5 79 5263 6737 23904 -644 50.5 801 0 65535 5781 7256 489 65535 -10 34686 -811 389 1025 65404 466 48.8 15 96 28200 2250 1475 0 0 2951 -648
    833 ######## 10033 FD7B 5 79 5261 6737 23904 -646 50.6 801 0 65535 5780 7256 489 65535 -10 34674 -811 389 1024 65407 476 48.8 15 96 28200 2250 1477 0 0 2951 -644
    834 ######## 10045 FD6F 5 79 5259 6737 23904 -647 50.8 801 0 65535 5778 7256 488 65535 -10 34668 -811 389 1024 65407 476 48.9 15 96 28200 2250 1479 0 0 2951 -647
    835 ######## 10057 FD7B 5 79 5255 6737 23892 -646 50.7 801 0 65535 5774 7256 488 65535 -10 34644 -811 389 1023 65408 480 48.9 15 96 28200 2250 1482 0 0 2951 -644
    836 ######## 10069 FD7B 5 78 5253 6737 23904 -645 51.1 801 0 65535 5772 7256 489 65535 -10 34632 -811 389 1023 65407 476 48.9 15 96 28200 2250 1484 0 0 2951 -649
    837 ######## 10081 FD7B 5 78 5251 6737 23892 -650 50.3 801 0 65535 5770 7256 485 65535 -10 34620 -811 388 1022 65408 479 48.8 15 96 28200 2250 1486 0 0 2951 -645
    838 ######## 10093 FD7D 5 78 5249 6737 23892 -649 50.7 801 0 65535 5768 7256 486 65535 -10 34608 -811 388 1022 65408 479 48.8 15 96 28200 2250 1488 0 0 2951 -645
    839 ######## 10105 FD76 5 78 5247 6737 23880 -648 50.7 801 0 65535 5766 7256 486 65535 -10 34596 -811 388 1022 65407 475 48.8 15 96 28200 2250 1490 0 0 2951 -648
    840 ######## 10117 FD7C 5 78 5246 6737 23892 -646 50.6 801 0 65535 5764 7256 487 65535 -10 34584 -811 388 1021 65407 475 48.9 15 96 28200 2250 1492 0 0 2951 -646
    841 ######## 10129 FD7B 5 78 5244 6737 23880 -645 50.6 801 0 65535 5763 7256 487 65535 -10 34572 -811 388 1021 65407 475 48.9 15 96 28200 2250 1494 0 0 2951 -650
    842 ######## 10141 FD7F 5 78 5240 6737 23880 -646 50.4 801 0 65535 5759 7256 487 65535 -10 34554 -811 388 1020 65407 474 48.8 15 96 28200 2250 1497 0 0 2951 -648
    843 ######## 10153 FD81 5 78 5238 6737 23880 -646 50.4 801 0 65535 5757 7256 487 65535 -10 34542 -811 388 1020 65407 474 48.8 15 96 28200 2250 1499 0 0 2951 -646
    844 ######## 10165 FD7C 5 78 5236 6737 23880 -646 50.4 801 0 65535 5755 7256 486 65535 -10 34530 -811 387 1019 65407 474 48.8 15 96 28200 2250 1501 0 0 2951 -646
    845 ######## 10177 FD7C 5 78 5234 6737 23880 -646 50.2 801 0 65535 5753 7256 486 65535 -10 34518 -811 387 1019 65406 470 48.8 15 96 28200 2250 1503 0 0 2951 -647
    846 ######## 10189 FD65 5 78 5232 6737 23868 -657 50.3 801 0 65535 5751 7256 478 65535 -10 34506 -811 387 1019 65402 456 48.8 15 96 28200 2250 1505 0 0 2951 -670
    847 ######## 10201 FD6A 5 78 5230 6737 23868 -661 50.6 801 0 65535 5749 7256 475 65535 -10 34494 -811 387 1018 65402 456 48.9 15 96 28200 2250 1507 0 0 2951 -674
    848 ######## 10213 FD5B 5 78 5229 6737 23856 -664 50.4 801 0 65535 5747 7256 473 65535 -10 34482 -811 387 1018 65407 473 48.8 15 96 28200 2250 1509 0 0 2951 -649
    849 ######## 10225 FD7B 5 78 5225 6737 23880 -653 50.7 801 0 65535 5744 7256 481 65535 -10 34464 -811 387 1017 65407 473 48.8 15 96 28200 2250 1513 0 0 2951 -646
    850 ######## 10237 FD7A 5 78 5223 6737 23868 -651 50.5 801 0 65535 5742 7256 481 65535 -10 34452 -811 386 1017 65407 473 48.9 15 96 28200 2250 1514 0 0 2951 -649
    851 ######## 10249 FD78 5 78 5221 6737 23868 -649 50.8 801 0 65535 5740 7256 483 65535 -10 34440 -811 386 1016 65407 473 48.9 15 96 28200 2250 1516 0 0 2951 -648
    852 ######## 10261 FD79 5 78 5219 6737 23868 -649 50.8 801 0 65535 5738 7256 482 65535 -10 34428 -811 386 1016 65407 473 48.9 15 96 28200 2250 1518 0 0 2951 -647
    853 ######## 10273 FD77 5 78 5217 6737 23868 -650 50.6 801 0 65535 5736 7256 482 65535 -10 34416 -811 386 1016 65407 473 48.9 15 96 28200 2250 1520 0 0 2951 -651
    854 ######## 10285 FD79 5 78 5215 6737 23856 -649 50.8 801 0 65535 5734 7256 482 65535 -10 34404 -811 386 1015 65407 472 48.9 15 96 28200 2250 1522 0 0 2951 -647
    855 ######## 10297 FD78 5 78 5214 6737 23856 -649 50.5 801 0 65535 5733 7256 482 65535 -10 34392 -811 386 1015 65407 472 48.9 15 96 28200 2250 1524 0 0 2951 -645
    856 ######## 10309 FD6C 5 78 5210 6737 23856 -649 50.8 801 0 65535 5729 7256 482 65535 -10 34374 -811 385 1014 65408 475 49 15 96 28200 2250 1528 0 0 2951 -646
    857 ######## 10321 FD79 5 78 5208 6737 23856 -649 50.8 801 0 65535 5727 7256 481 65535 -10 34362 -811 385 1014 65407 472 49 15 96 28200 2250 1529 0 0 2951 -649
    858 ######## 10333 FD7C 5 78 5206 6737 23856 -648 50.9 801 0 65535 5725 7256 482 65535 -10 34350 -811 385 1014 65408 475 49 15 96 28200 2250 1531 0 0 2951 -649
    859 ######## 10345 FD6E 5 78 5204 6737 23844 -654 51 801 0 65535 5723 7256 477 65535 -10 34338 -811 385 1013 65404 460 49 15 96 28200 2250 1533 0 0 2951 -665
    860 ######## 10357 FE10 5 78 5202 6737 23964 -601 50.8 801 0 65535 5721 7256 525 65535 -10 34326 -811 385 1013 65437 614 48.9 15 96 28200 2250 1535 0 0 2951 -504
    861 ######## 10369 FE01 5 78 5201 6737 23952 -551 50.6 801 0 65535 5720 7256 566 65535 -10 34320 -811 385 1013 65434 596 48.9 15 96 28200 2250 1536 0 0 2951 -518
    862 ######## 10381 FDFF 5 78 5199 6737 23940 -534 50.3 801 0 65535 5718 7256 585 65535 -10 34308 -811 385 1012 65432 584 48.8 15 96 28200 2250 1538 0 0 2951 -524
    863 ######## 10393 FDA9 5 78 5196 6737 23892 -540 50.1 801 0 65535 5715 7256 572 65535 -10 34290 -811 384 1012 65413 494 48.4 15 96 28200 2250 1541 0 0 2951 -645
    864 ######## 10405 FD39 5 78 5194 6737 23808 -617 49.7 801 0 65535 5713 7256 505 65535 -10 34278 -811 384 1011 65393 424 48.2 15 96 28200 2250 1543 0 0 2951 -721
    865 ######## 10417 FD1C 5 78 5192 6737 23784 -676 49.6 801 0 65535 5711 7256 461 65535 -10 34266 -811 384 1011 65389 413 48.1 15 96 28200 2250 1545 0 0 2951 -738
    866 ######## 10429 FD1F 5 78 5190 6737 23784 -708 49.4 801 0 65535 5709 7256 440 65535 -10 34254 -811 384 1010 65390 415 48 15 96 28200 2250 1547 0 0 2951 -738
    867 ######## 10441 FD21 5 78 5188 6737 23784 -722 49.4 801 0 65535 5707 7256 431 65535 -10 34242 -811 384 1010 65389 412 48.1 15 96 28200 2250 1549 0 0 2951 -738
    868 ######## 10453 FD1E 5 77 5186 6737 23784 -731 49.6 801 0 65535 5705 7256 426 65535 -10 34230 -811 384 1010 65390 415 48.2 15 96 28200 2250 1552 0 0 2951 -743
    869 ######## 10465 FD17 5 77 5184 6737 23772 -737 49.9 801 0 65535 5703 7256 421 65535 -10 34212 -811 383 1009 65388 409 48.3 15 96 28200 2250 1554 0 0 2951 -744
    870 ######## 10478 FD19 5 77 5179 6737 23772 -740 50.2 801 0 65535 5698 7256 420 65535 -10 34188 -811 383 1008 65389 411 48.7 15 96 28200 2250 1558 0 0 2951 -743
    871 ######## 10490 FD1D 5 77 5177 6737 23760 -741 50.6 801 0 65535 5696 7256 419 65535 -10 34176 -811 383 1008 65389 411 48.9 15 96 28200 2250 1560 0 0 2951 -749
    872 ######## 10502 FD19 5 77 5175 6737 23760 -742 51.1 801 0 65535 5694 7256 418 65535 -10 34164 -811 383 1007 65389 411 49.2 15 96 28200 2250 1562 0 0 2951 -742
    873 ######## 10514 FD1C 5 77 5173 6737 23760 -741 51.8 801 0 65535 5692 7256 419 65535 -10 34152 -811 383 1007 65388 408 49.5 15 96 28200 2250 1564 0 0 2951 -742
    874 ######## 10526 FD1B 5 77 5171 6737 23760 -741 52.2 801 0 65535 5690 7256 418 65535 -10 34140 -811 383 1007 65388 408 49.7 15 96 28200 2250 1566 0 0 2951 -744
    875 ######## 10538 FD16 5 77 5169 6737 23760 -742 52.5 801 0 65535 5688 7256 418 65535 -10 34128 -811 382 1006 65388 408 50 15 96 28200 2250 1568 0 0 2951 -748
    876 ######## 10550 FD1D 5 77 5164 6737 23760 -742 53.1 801 0 65535 5683 7256 418 65535 -10 34098 -811 382 1005 65389 410 50.4 15 96 28200 2250 1573 0 0 2951 -743
    877 ######## 10562 FD1D 5 77 5162 6737 23760 -742 53.3 801 0 65535 5681 7256 417 65535 -10 34086 -811 382 1005 65389 410 50.6 15 96 28200 2250 1575 0 0 2951 -745
    878 ######## 10574 FD1D 5 77 5160 6737 23760 -744 54 801 0 65535 5679 7256 416 65535 -10 34074 -811 382 1004 65389 410 50.8 15 96 28200 2250 1577 0 0 2951 -742
    879 ######## 10586 FCFD 5 77 5158 6737 23748 -751 54.4 801 0 65535 5677 7256 412 65535 -10 34062 -811 382 1004 65387 404 51.1 15 96 28200 2250 1579 0 0 2951 -754
    880 ######## 10598 FD18 5 77 5156 6737 23748 -749 54.2 801 0 65535 5675 7256 413 65535 -10 34050 -811 381 1004 65389 410 51.3 15 96 28200 2250 1582 0 0 2951 -750
    881 ######## 10610 FD14 5 77 5154 6737 23736 -748 54.8 801 0 65535 5672 7256 413 65535 -10 34032 -811 381 1003 65388 407 51.5 15 96 28200 2250 1584 0 0 2951 -743
    882 ######## 10622 FD19 5 77 5152 6737 23748 -745 55.1 801 0 65535 5670 7256 415 65535 -10 34020 -811 381 1003 65389 409 51.7 15 96 0 0 1586 0 0 2951 -744
    883 ######## 10634 FD1B 5 77 5147 6737 23736 -743 55.4 801 0 65535 5666 7256 416 65535 -10 33996 -811 381 1002 65390 412 52.1 15 96 0 0 1590 0 0 2951 -749
    884 ######## 10646 FD1B 5 77 5145 6737 23736 -743 55.5 801 0 65535 5664 7256 415 65535 -10 33984 -811 381 1001 65389 409 52.2 15 96 0 0 1592 0 0 2951 -742
    885 ######## 10658 FD1A 5 77 5143 6737 23736 -743 55.7 801 0 65535 5662 7256 415 65535 -10 33972 -811 380 1001 65390 411 52.3 15 96 0 0 1594 0 0 2951 -749
    886 ######## 10670 FD1C 5 77 5141 6737 23736 -743 55.7 801 0 65535 5660 7256 415 65535 -10 33960 -811 380 1001 65389 409 52.3 15 96 0 0 1596 0 0 2951 -744
    887 ######## 10682 FD17 5 77 5139 6737 23712 -746 55.9 801 0 65535 5658 7256 414 65535 -10 33948 -811 380 1000 65389 408 52.5 15 96 0 0 1598 0 0 2951 -746
    888 ######## 10694 FD1D 5 77 5136 6737 23712 -744 56.3 801 0 65535 5655 7256 414 65535 -10 33930 -811 380 1000 65379 382 52.6 15 96 0 0 1601 0 0 2951 -793
    889 ######## 10706 FD18 5 77 5132 6737 23712 -749 56.8 801 0 65535 5651 7256 411 65535 -10 33906 -811 380 999 65389 405 52.9 15 96 0 0 1605 0 0 2951 -749
    890 ######## 10718 FD17 5 77 5130 6737 23712 -748 56.8 801 0 65535 5649 7256 411 65535 -10 33894 -811 380 998 65388 405 53 15 96 0 0 1607 0 0 2951 -751
    891 ######## 10730 FD18 5 77 5128 6737 23712 -748 56.9 801 0 65535 5647 7256 411 65535 -10 33882 -811 379 998 65388 405 53.1 15 96 0 0 1610 0 0 2951 -753
    892 ######## 10742 FD17 5 77 5126 6737 23700 -748 57.2 801 0 65535 5645 7256 411 65535 -10 33864 -811 379 997 65385 396 53.2 15 96 0 0 1612 0 0 2951 -760
    893 ######## 10754 FD15 5 77 5124 6737 23700 -749 57.1 801 0 65535 5642 7256 410 65535 -10 33852 -811 379 997 65388 404 53.3 15 96 0 0 1614 0 0 2951 -747
    894 ######## 10766 FD16 5 77 5121 6737 23700 -748 57.5 801 0 65535 5640 7256 411 65535 -10 33840 -811 379 997 65389 407 53.5 15 96 0 0 1616 0 0 2951 -745
    895 ######## 10778 FD16 5 76 5119 6737 23688 -747 57.6 801 0 65535 5638 7256 411 65535 -10 33828 -811 379 996 65388 404 53.6 15 96 0 0 1618 0 0 2951 -749
    896 ######## 10790 FD15 5 76 5115 6737 23688 -747 57.9 801 0 65535 5634 7256 411 65535 -10 33804 -811 378 995 65389 406 53.8 15 96 0 0 1622 0 0 2951 -747
    897 ######## 10802 FD16 5 76 5113 6737 23688 -747 57.5 801 0 65535 5632 7256 411 65535 -10 33792 -811 378 995 65389 406 53.8 15 96 0 0 1624 0 0 2951 -746
    898 ######## 10814 FD0E 5 76 5111 6737 23688 -751 57.9 801 0 65535 5630 7256 408 65535 -10 33774 -811 378 995 65388 403 53.9 15 96 0 0 1627 0 0 2951 -756
    899 ######## 10826 FD15 5 76 5108 6737 23688 -752 58.1 801 0 65535 5627 7256 408 65535 -10 33762 -811 378 994 65388 403 54 15 96 0 0 1629 0 0 2951 -750
    900 ######## 10838 FD16 5 76 5106 6737 23676 -751 58.1 801 0 65535 5625 7256 408 65535 -10 33750 -811 378 994 65388 403 54 15 96 0 0 1631 0 0 2951 -756
    901 ######## 10850 FD15 5 76 5104 6737 23676 -750 58.3 801 0 65535 5623 7256 408 65535 -10 33738 -811 378 993 65389 405 54.1 15 96 0 0 1633 0 0 2951 -751
    902 ######## 10862 FD16 5 76 5102 6737 23688 -749 58.5 801 0 65535 5621 7256 409 65535 -10 33726 -811 377 993 65387 400 54.2 15 96 0 0 1636 0 0 2951 -753
    903 ######## 10874 FD17 5 76 5098 6737 23676 -748 58.6 801 0 65535 5616 7256 409 65535 -10 33696 -811 377 992 65388 402 54.3 15 96 0 0 1640 0 0 2951 -752
    904 ######## 10887 FD12 5 76 5095 6737 23676 -748 58.7 801 0 65535 5614 7256 409 65535 -10 33684 -811 377 992 65388 402 54.4 15 96 0 0 1642 0 0 2951 -744
    905 ######## 10899 FD16 5 76 5093 6737 23664 -747 58.1 801 0 65535 5612 7256 409 65535 -10 33672 -811 377 991 65388 402 54.4 15 96 0 0 1644 0 0 2951 -748
    906 ######## 10911 FD15 5 76 5091 6737 23664 -747 58.4 801 0 65535 5610 7256 409 65535 -10 33660 -811 377 991 65389 404 54.4 15 96 0 0 1646 0 0 2951 -747
    907 ######## 10923 FD13 5 76 5089 6737 23664 -747 58.3 801 0 65535 5608 7256 409 65535 -10 33648 -811 376 990 65389 404 54.3 15 96 0 0 1649 0 0 2951 -751
    908 ######## 10935 FD17 5 76 5087 6737 23664 -747 58.2 801 0 65535 5606 7256 409 65535 -10 33636 -811 376 990 65389 404 54.3 15 96 0 0 1650 0 0 2951 -752
    909 ######## 10947 FD12 5 76 5085 6737 23664 -748 58.2 801 0 65535 5603 7256 408 65535 -10 33618 -811 376 989 65389 404 54.3 15 96 0 0 1653 0 0 2951 -747
    910 ######## 10959 FD14 5 76 5080 6737 23664 -748 58.7 801 0 65535 5599 7256 407 65535 -10 33594 -811 376 989 65389 404 54.4 15 96 0 0 1657 0 0 2951 -747
    911 ######## 10971 FD11 5 76 5078 6737 23664 -748 58.6 801 0 65535 5597 7256 407 65535 -10 33582 -811 376 988 65388 401 54.5 15 96 0 0 1659 0 0 2951 -763
    912 ######## 10983 FD17 5 76 5076 6737 23652 -749 59 801 0 65535 5595 7256 407 65535 -10 33570 -811 376 988 65389 403 54.6 15 96 0 0 1661 0 0 2951 -753
    913 ######## 10995 FD18 5 76 5074 6737 23664 -749 58.9 801 0 65535 5593 7256 406 65535 -10 33558 -811 375 987 65389 400 54.6 15 96 0 0 1664 0 0 2951 -749
    914 ######## 11007 FD15 5 76 5072 6737 23652 -748 59 801 0 65535 5590 7256 407 65535 -10 33540 -811 375 987 65388 400 54.6 15 96 0 0 1666 0 0 2951 -749
    915 ######## 11019 FD17 5 75 4910 6578 23652 -748 58.5 801 0 65535 5633 7301 394 65535 -10 33798 -811 363 946 65389 386 54.6 15 96 0 0 1668 0 0 2951 -748
    916 ######## 11031 FD19 5 75 4906 6578 23652 -747 59 801 0 65535 5629 7301 394 65535 -10 33774 -811 363 946 65389 381 54.7 15 96 0 0 1672 0 0 2951 -755
    917 ######## 11043 FD17 5 75 4904 6578 23652 -747 59.1 801 0 65535 5627 7301 394 65535 -10 33762 -811 363 945 65388 383 54.7 15 96 0 0 1674 0 0 2951 -748
    918 ######## 11055 FD17 5 75 4902 6578 23640 -748 58.8 801 0 65535 5625 7301 393 65535 -10 33750 -811 363 945 65388 383 54.7 15 96 0 0 1677 0 0 2951 -751
    919 ######## 11067 FD15 5 75 4899 6578 23640 -751 59.1 801 0 65535 5622 7301 391 65535 -10 33732 -811 362 944 65388 383 54.8 15 96 0 0 1679 0 0 2951 -752
    920 ######## 11079 FD13 5 75 4897 6578 23640 -751 58.9 801 0 65535 5620 7301 391 65535 -10 33720 -811 362 944 65388 383 54.8 15 96 0 0 1681 0 0 2951 -753
    921 ######## 11091 FD11 5 75 4895 6578 23640 -751 59.3 801 0 65535 5618 7301 391 65535 -10 33708 -811 362 943 65388 382 54.8 15 96 0 0 1683 0 0 2951 -749
    922 ######## 11103 FD14 5 75 4893 6578 23640 -750 59 801 0 65535 5616 7301 391 65535 -10 33696 -811 362 943 65388 382 54.8 15 96 0 0 1685 0 0 2951 -753
    923 ######## 11115 FD14 5 75 4889 6578 23628 -749 59.2 801 0 65535 5611 7301 392 65535 -10 33666 -811 362 942 65388 382 54.9 15 96 0 0 1690 0 0 2951 -754
    924 ######## 11127 FD19 5 75 4886 6578 23628 -749 59.2 801 0 65535 5609 7301 391 65535 -10 33654 -811 361 942 65389 384 55 15 96 0 0 1692 0 0 2951 -752
    925 ######## 11139 FD17 5 75 4884 6578 23628 -748 59.4 801 0 65535 5607 7301 392 65535 -10 33642 -811 361 941 65389 384 55 15 96 0 0 1694 0 0 2951 -749
    926 ######## 11151 FD11 5 75 4882 6578 23628 -748 59.1 801 0 65535 5605 7301 392 65535 -10 33630 -811 361 941 65388 381 54.9 15 96 0 0 1696 0 0 2951 -746
    927 ######## 11163 FD18 5 75 4880 6578 23616 -747 59.3 801 0 65535 5603 7301 392 65535 -10 33618 -811 361 941 65389 384 55 15 96 0 0 1699 0 0 2951 -749
    928 ######## 11175 FD13 5 75 4878 6578 23616 -747 59.1 801 0 65535 5601 7301 392 65535 -10 33600 -811 361 940 65389 384 55 15 96 0 0 1701 0 0 2951 -747
    929 ######## 11188 FD15 5 75 4876 6578 23616 -747 59.4 801 0 65535 5599 7301 392 65535 -10 33588 -811 361 940 65389 384 55.1 15 96 0 0 1703 0 0 2951 -753
    930 ######## 11200 FD15 5 75 4871 6578 23616 -747 59.8 801 0 65535 5594 7301 391 65535 -10 33564 -811 360 939 65389 383 55.2 15 96 0 0 1707 0 0 2951 -749
    931 ######## 11212 FD17 5 75 4869 6578 23616 -747 59.9 801 0 65535 5592 7301 391 65535 -10 33552 -811 360 938 65389 383 55.2 15 96 0 0 1709 0 0 2951 -747
    932 ######## 11224 FD14 5 74 4867 6578 23616 -748 59.8 801 0 65535 5590 7301 390 65535 -10 33540 -811 360 938 65389 383 55.2 15 96 0 0 1712 0 0 2951 -752
    933 ######## 11236 FD16 5 74 4865 6578 23616 -749 59.8 801 0 65535 5588 7301 390 65535 -10 33528 -811 360 938 65389 380 55.3 15 96 0 0 1714 0 0 2951 -750
    934 ######## 11248 FD18 5 74 4862 6578 23616 -749 59.8 801 0 65535 5585 7301 389 65535 -10 33510 -811 360 937 65389 382 55.2 15 96 0 0 1716 0 0 2951 -751
    935 ######## 11260 FD13 5 74 4860 6578 23604 -750 60 801 0 65535 5583 7301 389 65535 -10 33498 -811 360 937 65388 380 55.3 15 96 0 0 1718 0 0 2951 -754
    936 ######## 11272 FD15 5 74 4858 6578 23592 -750 60.2 4801 0 65535 5581 7301 389 65535 -10 33486 -811 359 936 65388 379 55.3 15 96 0 0 1720 0 0 2951 -757
    937 ######## 11284 FD14 5 74 4854 6578 23592 -754 60.1 4801 0 65535 5576 7301 387 65535 -10 33456 -811 359 935 65388 379 55.2 15 96 0 0 1725 0 0 2951 -753
    938 ######## 11296 FD16 5 74 4852 6578 23592 -752 60.3 4801 0 65535 5574 7301 387 65535 -10 33444 -811 359 935 65388 379 55.2 15 96 0 0 1727 0 0 2951 -751
    939 ######## 11308 FD12 5 74 4849 6578 23580 -751 60.3 4801 0 65535 5572 7301 387 65535 -10 33432 -811 359 934 65389 381 55.2 15 96 0 0 1729 0 0 2951 -749
    940 ######## 11320 FD12 5 74 4847 6578 23580 -751 60.4 4801 0 65535 5570 7301 387 65535 -10 33420 -811 359 934 65388 379 55.2 15 96 0 0 1731 0 0 2951 -750
    941 ######## 11332 FD13 5 74 4845 6578 23568 -750 60.5 4801 0 65535 5568 7301 388 65535 -10 33408 -811 358 934 65389 381 55.2 15 96 0 0 1733 0 0 2951 -753
    942 ######## 11344 FD12 5 74 4843 6578 23580 -751 59.6 4801 0 65535 5566 7301 387 65535 -10 33396 -811 358 933 65388 378 55.1 15 96 0 0 1735 0 0 2951 -752
    943 ######## 11356 FD12 5 74 4841 6578 23568 -751 59.9 4801 0 65535 5564 7301 387 65535 -10 33384 -811 358 933 65388 378 55.1 15 96 0 0 1737 0 0 2951 -755
    944 ######## 11368 FD12 5 74 4837 6578 23568 -751 60.1 4801 0 65535 5559 7301 386 65535 -10 33354 -811 358 932 65387 380 55.2 15 96 0 0 1742 0 0 2951 -751
    945 ######## 11380 FD10 5 74 4834 6578 23568 -752 59.8 4801 0 65535 5557 7301 386 65535 -10 33342 -811 358 931 65389 380 55 15 96 0 0 1744 0 0 2951 -753
    946 ######## 11392 FD10 5 74 4832 6578 23568 -752 59.6 4801 0 65535 5555 7301 386 65535 -10 33330 -811 357 931 65389 380 55 15 96 0 0 1746 0 0 2951 -751
    947 ######## 11404 FD0F 5 74 4830 6578 23568 -751 59.7 4801 0 65535 5553 7301 386 65535 -10 33318 -811 357 931 65388 377 55 15 96 0 0 1748 0 0 2951 -753
    948 ######## 11416 FD10 5 74 4828 6578 23568 -751 59.7 4801 0 65535 5551 7301 386 65535 -10 33306 -811 357 930 65389 380 55 15 96 0 0 1750 0 0 2951 -752
    949 ######## 11428 FD14 5 74 4826 6578 23556 -751 59.7 4801 0 65535 5548 7301 385 65535 -10 33288 -811 357 930 65389 380 55 15 96 0 0 1753 0 0 2951 -752
    950 ######## 11440 FD13 5 74 4821 6578 23556 -750 60.3 4801 0 65535 5544 7301 386 65535 -10 33264 -811 357 929 65389 379 55 15 96 0 0 1757 0 0 2951 -752
    951 ######## 11452 FD15 5 74 4819 6578 23556 -750 60.2 4801 0 65535 5542 7301 386 65535 -10 33252 -811 357 929 65388 377 55 15 96 0 0 1759 0 0 2951 -752
    952 ######## 11464 FD12 5 74 4817 6578 23544 -751 60 4801 0 65535 5540 7301 385 65535 -10 33240 -811 356 928 65389 379 55 15 96 0 0 1761 0 0 2951 -753
    953 ######## 11476 FD13 5 74 4815 6578 23544 -750 59.8 4801 0 65535 5538 7301 385 65535 -10 33228 -811 356 928 65389 379 54.8 15 96 0 0 1764 0 0 2951 -756
    954 ######## 11488 FD15 5 74 4813 6578 23544 -749 59.8 4801 0 65535 5536 7301 385 65535 -10 33210 -811 356 927 65388 376 54.9 15 96 0 0 1766 0 0 2951 -751
    955 ######## 11500 FD15 5 74 4810 6578 23532 -750 59.9 4801 0 65535 5533 7301 385 65535 -10 33198 -811 356 927 65388 376 55 15 96 0 0 1768 0 0 2951 -757
    956 ######## 11512 FD11 5 74 4808 6578 23532 -751 60 4801 0 65535 5531 7301 384 65535 -10 33186 -811 356 926 65389 378 55 15 96 0 0 1770 0 0 2951 -755
    957 ######## 11524 FD0F 5 74 4804 6578 23532 -752 60.3 4801 0 65535 5527 7301 383 65535 -10 33162 -811 355 926 65389 378 55.2 15 96 0 0 1774 0 0 2951 -752
    958 ######## 11536 FD13 5 74 4802 6578 23532 -752 60.1 4801 0 65535 5524 7301 383 65535 -10 33144 -811 355 925 65389 378 55.1 15 96 0 0 1777 0 0 2951 -752
    959 ######## 11548 FD0F 5 73 4799 6578 23532 -752 59.9 4801 0 65535 5522 7301 383 65535 -10 33132 -811 355 925 65389 378 55 15 96 0 0 1779 0 0 2951 -751
    960 ######## 11560 FD11 5 73 4797 6578 23532 -752 60 4801 0 65535 5520 7301 383 65535 -10 33120 -811 355 924 65389 377 55.1 15 96 0 0 1781 0 0 2951 -751
    961 ######## 11572 FD11 5 73 4795 6578 23532 -751 60 4801 0 65535 5518 7301 383 65535 -10 33108 -811 355 924 65389 377 55.1 15 96 0 0 1783 0 0 2951 -756
    962 ######## 11584 FD0F 5 73 4793 6578 23520 -753 60.1 4801 0 65535 5516 7301 382 65535 -10 33096 -811 355 923 65389 377 55.1 15 96 0 0 1785 0 0 2951 -753
    963 ######## 11597 FD13 5 73 4789 6578 23520 -751 60.2 4801 0 65535 5512 7301 383 65535 -10 33072 -811 354 923 65389 377 55.1 15 96 0 0 1790 0 0 2951 -750
    964 ######## 11609 FD0C 5 73 4786 6578 23508 -754 60 4801 0 65535 5509 7301 381 65535 -10 33054 -811 354 922 65388 374 55.1 15 96 0 0 1792 0 0 2951 -757
    965 ######## 11621 FD12 5 73 4784 6578 23508 -753 58.9 4801 0 65535 5507 7301 381 65535 -10 33042 -811 354 922 65388 374 54.9 15 96 0 0 1794 0 0 2951 -757
    966 ######## 11633 FD14 5 73 4782 6578 23520 -753 59.3 4801 0 65535 5505 7301 381 65535 -10 33030 -811 354 921 65389 376 54.9 15 96 0 0 1796 0 0 2951 -752
    967 ######## 11645 FD13 5 73 4780 6578 23508 -753 59.8 4801 0 65535 5503 7301 381 65535 -10 33018 -811 354 921 65388 373 55 15 96 0 0 1798 0 0 2951 -756
    968 ######## 11657 FD14 5 73 4778 6578 23508 -753 60.1 4801 0 65535 5501 7301 381 65535 -10 33006 -811 353 920 65389 376 55.1 16 96 0 0 1801 0 0 2951 -757
    969 ######## 11669 FD0F 5 73 4776 6578 23508 -753 60.3 4801 0 65535 5498 7301 380 65535 -10 32988 -811 353 920 65388 373 55.1 16 96 0 0 1803 0 0 2951 -756
    970 ######## 11681 FD0C 5 73 4771 6578 23496 -756 59.6 4801 0 65535 5494 7301 379 65535 -10 32964 -811 353 919 65388 373 55.1 16 96 0 0 1807 0 0 2951 -760
    971 ######## 11693 FD0F 5 73 4769 6578 23496 -756 59.8 4801 0 65535 5492 7301 378 65535 -10 32952 -811 353 919 65389 375 55 16 96 0 0 1809 0 0 2951 -763
    972 ######## 11705 FD03 5 73 4767 6578 23496 -757 60 4801 0 65535 5490 7301 378 65535 -10 32940 -811 353 918 65387 370 55 16 96 0 0 1811 0 0 2951 -762
    973 ######## 11717 FD1D 5 73 4765 6578 23508 -754 60 4801 0 65535 5488 7301 379 65535 -10 32922 -811 352 918 65390 377 55 16 96 0 0 1814 0 0 2951 -744
    974 ######## 11729 FD1D 5 73 4763 6578 23508 -750 60.1 4801 0 65535 5485 7301 381 65535 -10 32910 -811 352 917 65391 379 55 16 96 0 0 1816 0 0 2951 -742
    975 ######## 11741 FD17 5 73 4760 6578 23496 -746 59.6 4801 0 65535 5483 7301 383 65535 -10 32898 -811 352 917 65390 377 54.9 16 96 0 0 1818 0 0 2951 -740
    976 ######## 11753 FD1F 5 73 4758 6578 23508 -742 59.4 4801 0 65535 5481 7301 385 65535 -10 32886 -811 352 917 65391 379 54.8 16 96 0 0 1820 0 0 2951 -739
    977 ######## 11765 FD1F 5 73 4754 6578 23496 -741 58.9 4801 0 65535 5477 7301 385 65535 -10 32862 -811 352 916 65391 379 54.7 16 96 0 0 1824 0 0 2951 -738
    978 ######## 11777 FD20 5 73 4752 6578 23496 -739 59.4 4801 0 65535 5474 7301 386 65535 -10 32844 -811 351 915 65391 379 54.8 16 96 0 0 1827 0 0 2951 -741
    979 ######## 11789 FD1F 5 73 4749 6578 23496 -738 59.4 4801 0 65535 5472 7301 386 65535 -10 32832 -811 351 915 65392 381 54.8 16 96 0 0 1829 0 0 2951 -742
    980 ######## 11801 FD1A 5 73 4748 6578 23496 -738 59.2 4801 0 65535 5470 7301 386 65535 -10 32820 -811 351 914 65391 378 54.7 16 96 0 0 1831 0 0 2951 -738
    981 ######## 11813 FD20 5 73 4745 6578 23484 -738 59.5 4801 0 65535 5468 7301 386 65535 -10 32808 -811 351 914 65392 381 54.8 16 96 0 0 1833 0 0 2951 -756
    982 ######## 11825 FD21 5 73 4743 6578 23484 -738 59.1 4801 0 65535 5466 7301 386 65535 -10 32796 -811 351 914 65392 381 54.7 16 96 0 0 1835 0 0 2951 -737
    983 ######## 11837 FD21 5 73 4739 6578 23484 -739 59.4 4801 0 65535 5462 7301 385 65535 -10 32772 -811 351 913 65391 378 54.7 16 96 0 0 1839 0 0 2951 -741
    984 ######## 11849 FD1C 5 73 4737 6578 23484 -739 59.4 4801 0 65535 5460 7301 384 65535 -10 32760 -811 350 912 65390 375 54.7 16 96 0 0 1842 0 0 2951 -741
    985 ######## 11862 FD1C 5 72 4735 6578 23484 -739 59.3 4801 0 65535 5458 7301 384 65535 -10 32742 -811 350 912 65391 377 54.6 16 96 0 0 1844 0 0 2951 -742
    986 ######## 11874 FD1E 5 72 4733 6578 23472 -740 59 4801 0 65535 5456 7301 383 65535 -10 32730 -811 350 911 65391 377 54.6 16 96 0 0 1846 0 0 2951 -754
    987 ######## 11886 FD1F 5 72 4731 6578 23472 -741 59.2 4801 0 65535 5453 7301 383 65535 -10 32718 -811 350 911 65389 372 54.6 16 96 0 0 1848 0 0 2951 -761
    988 ######## 11898 FD1F 5 72 4728 6578 23472 -741 59.3 4801 0 65535 5451 7301 383 65535 -10 32706 -811 350 911 65392 380 54.6 16 96 0 0 1850 0 0 2951 -736
    989 ######## 11910 FD1D 5 72 4726 6578 23472 -739 59.5 4801 0 65535 5449 7301 384 65535 -10 32694 -811 350 910 65391 377 54.6 16 96 0 0 1852 0 0 2951 -739
    990 ######## 11922 FD21 5 72 4722 6578 23472 -737 59.3 4801 0 65535 5445 7301 384 65535 -10 32670 -811 349 909 65392 379 54.6 16 96 0 0 1857 0 0 2951 -737
    991 ######## 11934 FD1C 5 72 4720 6578 23460 -737 59.3 4801 0 65535 5443 7301 384 65535 -10 32652 -811 349 909 65391 376 54.5 16 96 0 0 1859 0 0 2951 -737
    992 ######## 11946 FD24 5 72 4717 6578 23460 -737 58.9 4801 0 65535 5440 7301 384 65535 -10 32640 -811 349 909 65392 379 54.5 16 96 0 0 1861 0 0 2951 -735
    993 ######## 11958 FD1F 5 72 4715 6578 23460 -737 59 4801 0 65535 5438 7301 384 65535 -10 32628 -811 349 908 65392 378 54.5 16 96 0 0 1863 0 0 2951 -736
    994 ######## 11970 FD1F 5 72 4713 6578 23460 -737 59 4801 0 65535 5436 7301 384 65535 -10 32616 -811 349 908 65392 378 54.5 16 96 0 0 1865 0 0 2951 -737
    995 ######## 11982 FD1C 5 72 4711 6578 23460 -736 59.2 4801 0 65535 5434 7301 384 65535 -10 32604 -811 349 907 65393 381 54.5 16 96 0 0 1867 0 0 2951 -739
    996 ######## 11994 FD22 5 72 4709 6578 23460 -736 59.3 4801 0 65535 5432 7301 384 65535 -10 32592 -811 348 907 65392 378 54.4 16 96 0 0 1869 0 0 2951 -739
    997 ######## 12006 FD22 5 72 4704 6578 23448 -739 58.6 4801 0 65535 5427 7301 382 65535 -10 32562 -811 348 906 65392 378 54.4 16 96 0 0 1874 0 0 2951 -754
    998 ######## 12018 FD21 5 72 4702 6578 23448 -739 58.9 4801 0 65535 5425 7301 382 65535 -10 32550 -811 348 906 65392 378 54.4 16 96 0 0 1876 0 0 2951 -738
    999 ######## 12030 FD23 5 72 4700 6578 23448 -739 58.9 4801 0 65535 5423 7301 382 65535 -10 32538 -811 348 905 65391 374 54.5 16 96 0 0 1878 0 0 2951 -739
    1000 ######## 12042 FD21 5 72 4698 6578 23448 -738 59 4801 0 65535 5421 7301 382 65535 -10 32526 -811 348 905 65393 380 54.5 16 96 0 0 1880 0 0 2951 -741
    1001 ######## 12054 FD14 5 72 4696 6578 23436 -739 59.1 4801 0 65535 5419 7301 381 65535 -10 32514 -811 347 904 65392 377 54.5 16 96 0 0 1882 0 0 2951 -737
    1002 ######## 12066 FD22 5 72 4694 6578 23436 -739 59.1 4801 0 65535 5417 7301 381 65535 -10 32502 -811 347 904 65391 374 54.4 16 96 0 0 1884 0 0 2951 -751
    1003 ######## 12078 FD24 5 72 4692 6578 23436 -738 59.4 4801 0 65535 5415 7301 381 65535 -10 32490 -811 347 903 65392 376 54.5 16 96 0 0 1887 0 0 2951 -739
    1004 ######## 12090 FD25 5 72 4687 6578 23436 -736 58.9 4801 0 65535 5410 7301 382 65535 -10 32460 -811 347 903 65392 376 54.4 16 96 0 0 1891 0 0 2951 -737
    1005 ######## 12102 FD21 5 72 4685 6578 23436 -736 58.6 4801 0 65535 5408 7301 382 65535 -10 32448 -811 347 902 65392 376 54.4 16 96 0 0 1893 0 0 2951 -735
    1006 ######## 12114 FD23 5 72 4683 6578 23436 -736 58.7 4801 0 65535 5406 7301 382 65535 -10 32436 -811 346 902 65392 376 54.4 16 96 0 0 1895 0 0 2951 -743
    1007 ######## 12126 FD1C 5 72 4681 6578 23424 -736 58.5 4801 0 65535 5404 7301 382 65535 -10 32424 -811 346 902 65392 376 54.3 16 96 0 0 1897 0 0 2951 -738
    1008 ######## 12138 FD1E 5 72 4679 6578 23424 -736 58.7 4801 0 65535 5402 7301 381 65535 -10 32412 -811 346 901 65392 375 54.3 16 96 0 0 1899 0 0 2951 -736
    1009 ######## 12150 FD1F 5 72 4677 6578 23424 -736 58.6 4801 0 65535 5400 7301 381 65535 -10 32400 -811 346 901 65392 375 54.3 16 96 0 0 1902 0 0 2951 -737
    1010 ######## 12162 FD1E 5 72 4675 6578 23424 -738 58.9 4801 0 65535 5398 7301 380 65535 -10 32382 -811 346 900 65392 375 54.4 16 96 0 0 1904 0 0 2951 -737
    1011 ######## 12174 FD21 5 71 4670 6578 23412 -739 59.1 4801 0 65535 5393 7301 379 65535 -10 32358 -811 345 899 65391 372 54.4 16 96 0 0 1908 0 0 2951 -741
    1012 ######## 12186 FD1E 5 71 4668 6578 23412 -740 59.1 4801 0 65535 5391 7301 378 65535 -10 32346 -811 345 899 65392 375 54.4 16 96 0 0 1910 0 0 2951 -738
    1013 ######## 12198 FD1F 5 71 4666 6578 23412 -739 58.9 4801 0 65535 5389 7301 379 65535 -10 32334 -811 345 899 65392 375 54.4 16 96 0 0 1912 0 0 2951 -738
    1014 ######## 12211 FD21 5 71 4664 6578 23412 -738 59.1 4801 0 65535 5387 7301 379 65535 -10 32322 -811 345 898 65392 374 54.4 16 96 0 0 1915 0 0 2951 -740
    1015 ######## 12223 FD23 5 71 4662 6578 23412 -737 58.9 4801 0 65535 5384 7301 379 65535 -10 32304 -811 345 898 65392 374 54.4 16 96 0 0 1917 0 0 2951 -739
    1016 ######## 12235 FD16 5 71 4659 6578 23400 -738 58.7 4801 0 65535 5382 7301 379 65535 -10 32292 -811 345 897 65391 371 54.4 16 96 0 0 1919 0 0 2951 -744
    1017 ######## 12247 FD24 5 71 4657 6578 23412 -738 58.8 4801 0 65535 5380 7301 379 65535 -10 32280 -811 345 897 65392 374 54.3 16 96 0 0 1921 0 0 2951 -737
    1018 ######## 12259 FD20 5 71 4653 6578 23400 -737 58.8 4801 0 65535 5376 7301 379 65535 -10 32256 -811 344 896 65392 373 54.3 16 96 0 0 1925 0 0 2951 -737
    1019 ######## 12271 FD21 5 71 4651 6578 23400 -737 59.2 4801 0 65535 5374 7301 379 65535 -10 32244 -811 344 896 65392 373 54.4 16 96 0 0 1927 0 0 2951 -734
    1020 ######## 12283 FD1D 5 71 4649 6578 23388 -736 59.1 4801 0 65535 5372 7301 378 65535 -10 32232 -811 344 895 65390 368 54.4 16 96 0 0 1929 0 0 2951 -734
    1021 ######## 12295 FD1C 5 71 4647 6578 23400 -738 59 4801 0 65535 5369 7301 378 65535 -10 32214 -811 344 895 65391 370 54.4 16 96 0 0 1932 0 0 2951 -742
    1022 ######## 12307 FD18 5 71 4644 6578 23388 -740 59 4801 0 65535 5367 7301 377 65535 -10 32202 -811 344 894 65392 373 54.3 16 96 0 0 1934 0 0 2951 -741
    1023 ######## 12319 FD1C 5 71 4642 6578 23376 -740 58.8 4801 0 65535 5365 7301 376 65535 -10 32190 -811 343 894 65392 373 54.3 16 96 0 0 1936 0 0 2951 -742
    1024 ######## 12331 FD1C 5 71 4640 6578 23376 -741 58.6 4801 0 65535 5363 7301 376 65535 -10 32178 -811 343 894 65391 370 54.3 16 96 0 0 1938 0 0 2951 -741
    1025 ######## 12343 FD1D 5 71 4638 6578 23388 -740 59.1 4801 0 65535 5361 7301 376 65535 -10 32166 -811 343 893 65392 372 54.4 16 96 0 0 1940 0 0 2951 -740
    1026 ######## 12355 FD1D 5 71 4634 6578 23376 -740 58.8 4801 0 65535 5357 7301 376 65535 -10 32136 -811 343 892 65392 372 54.3 16 96 0 0 1945 0 0 2951 -742
    1027 ######## 12367 FD1A 5 71 4631 6578 23376 -741 59.1 4801 0 65535 5354 7301 375 65535 -10 32124 -811 343 892 65392 372 54.4 16 96 0 0 1947 0 0 2951 -740
    1028 ######## 12379 FD1D 5 71 4629 6578 23376 -740 59.3 4801 0 65535 5352 7301 375 65535 -10 32112 -811 342 891 65392 371 54.4 16 96 0 0 1949 0 0 2951 -740
    1029 ######## 12391 FD20 5 71 4627 6578 23376 -739 58.8 4801 0 65535 5350 7301 376 65535 -10 32100 -811 342 891 65393 374 54.3 16 96 0 0 1951 0 0 2951 -743
    1030 ######## 12403 FD1C 5 71 4625 6578 23364 -739 59.1 4801 0 65535 5348 7301 376 65535 -10 32088 -811 342 891 65393 374 54.4 16 96 0 0 1953 0 0 2951 -737
    1031 ######## 12415 FD1F 5 71 4623 6578 23364 -738 59.3 4801 0 65535 5346 7301 376 65535 -10 32076 -811 342 890 65391 368 54.4 16 96 0 0 1955 0 0 2951 -738
    1032 ######## 12427 FD19 5 71 4621 6578 23352 -741 59.3 4801 0 65535 5344 7301 375 65535 -10 32064 -811 342 890 65393 373 54.4 16 96 0 0 1958 0 0 2951 -737
    1033 ######## 12439 FD18 5 71 4616 6578 23364 -740 59.2 4801 0 65535 5339 7301 375 65535 -10 32034 -811 342 889 65393 373 54.4 16 96 0 0 1962 0 0 2951 -738
    1034 ######## 12451 FD0D 5 71 4614 6578 23352 -740 58.9 4801 0 65535 5337 7301 374 65535 -10 32022 -811 341 888 65392 370 54.4 16 96 0 0 1964 0 0 2951 -741
    1035 ######## 12463 FD1A 5 71 4612 6578 23352 -742 59.2 4801 0 65535 5335 7301 373 65535 -10 32010 -811 341 888 65392 370 54.4 16 96 0 0 1966 0 0 2951 -742
    1036 ######## 12475 FD1F 5 71 4610 6578 23352 -741 59 4801 0 65535 5333 7301 373 65535 -10 31998 -811 341 888 65392 370 54.4 16 96 0 0 1968 0 0 2951 -771
    1037 ######## 12487 FD14 5 71 4608 6578 23352 -749 59.1 4801 0 65535 5331 7301 369 65535 -10 31986 -811 341 887 65391 367 54.4 16 96 0 0 1970 0 0 2951 -745
    1038 ######## 12499 FD1A 5 71 4606 6578 23352 -746 58.5 4801 0 65535 5328 7301 370 65535 -10 31968 -811 341 887 65392 370 54.4 16 96 0 0 1973 0 0 2951 -751
    1039 ######## 12511 FD1F 5 70 4601 6578 23352 -742 59.2 4801 0 65535 5324 7301 372 65535 -10 31944 -811 340 886 65392 369 54.4 16 96 0 0 1977 0 0 2951 -742
    1040 ######## 12523 FD20 5 70 4599 6578 23352 -742 59.1 4801 0 65535 5322 7301 372 65535 -10 31932 -811 340 886 65392 369 54.4 16 96 0 0 1979 0 0 2951 -744
    1041 ######## 12535 FD1C 5 70 4597 6578 23340 -741 59.3 4801 0 65535 5320 7301 372 65535 -10 31920 -811 340 885 65392 369 54.5 16 96 0 0 1981 0 0 2951 -742
    1042 ######## 12547 FD1F 5 70 4595 6578 23340 -741 59.1 4801 0 65535 5318 7301 372 65535 -10 31908 -811 340 885 65392 369 54.5 16 96 0 0 1983 0 0 2951 -740
    1043 ######## 12559 FD1A 5 70 4593 6578 23328 -741 59.3 4801 0 65535 5316 7301 372 65535 -10 31896 -811 340 884 65392 368 54.5 16 96 0 0 1985 0 0 2951 -739
    1044 ######## 12571 FD24 5 70 4590 6578 23340 -738 59.3 4801 0 65535 5313 7301 373 65535 -10 31878 -811 340 884 65394 374 54.5 16 96 0 0 1988 0 0 2951 -738
    1045 ######## 12583 FD20 5 70 4589 6578 23328 -738 59.4 4801 0 65535 5311 7301 373 65535 -10 31866 -811 339 883 65393 370 54.6 16 96 0 0 1990 0 0 2951 -738
    1046 ######## 12595 FD1D 5 70 4584 6578 23328 -738 58.9 4801 0 65535 5307 7301 373 65535 -10 31842 -811 339 883 65393 370 54.5 16 96 0 0 1994 0 0 2951 -740
    1047 ######## 12607 FD16 5 70 4582 6578 23328 -741 59.3 4801 0 65535 5305 7301 371 65535 -10 31830 -811 339 882 65392 368 54.5 16 96 0 0 1996 0 0 2951 -739
    1048 ######## 12619 FD1C 5 70 4580 6578 23316 -742 59.5 4801 0 65535 5303 7301 370 65535 -10 31818 -811 339 882 65392 368 54.7 16 96 0 0 1998 0 0 2951 -747
    1049 ######## 12631 FD1C 5 70 4578 6578 23328 -742 59.5 4801 0 65535 5301 7301 370 65535 -10 31806 -811 339 881 65392 367 54.6 16 96 0 0 2000 0 0 2951 -739
    1050 ######## 12643 FD1C 5 70 4576 6578 23328 -741 59.2 4801 0 65535 5298 7301 370 65535 -10 31788 -811 338 881 65392 367 54.6 16 96 0 0 2003 0 0 2951 -739
    1051 ######## 12655 FD1C 5 70 4574 6578 23316 -741 59 4801 0 65535 5296 7301 370 65535 -10 31776 -811 338 880 65393 369 54.5 16 96 0 0 2005 0 0 2951 -741
    1052 ######## 12667 FD1A 5 70 4571 6578 23316 -741 59 4801 0 65535 5294 7301 370 65535 -10 31764 -811 338 880 65393 369 54.5 16 96 0 0 2007 0 0 2951 -743
    1053 ######## 12679 FD18 5 70 4567 6578 23304 -741 58.7 4801 0 65535 5290 7301 370 65535 -10 31740 -811 338 879 65392 366 54.4 16 96 0 0 2011 0 0 2951 -738
    1054 ######## 12692 FD20 5 70 4565 6578 23304 -740 58.9 4801 0 65535 5288 7301 370 65535 -10 31728 -811 338 879 65393 369 54.4 16 96 0 0 2013 0 0 2951 -737
    1055 ######## 12704 FD1C 5 70 4563 6578 23304 -739 59.1 4801 0 65535 5286 7301 370 65535 -10 31716 -811 338 879 65393 368 54.5 16 96 0 0 2016 0 0 2951 -737
    1056 ######## 12716 FD22 5 70 4560 6578 23304 -738 58.6 4801 0 65535 5283 7301 371 65535 -10 31698 -811 337 878 65393 368 54.3 16 96 0 0 2018 0 0 2951 -741
    1057 ######## 12728 FD1F 5 70 4559 6578 23304 -739 58.9 4801 0 65535 5281 7301 370 65535 -10 31686 -811 337 878 65393 368 54.4 16 96 0 0 2020 0 0 2951 -738
    1058 ######## 12740 FD1D 5 70 4556 6578 23304 -740 58.8 4801 0 65535 5279 7301 369 65535 -10 31674 -811 337 877 65392 365 54.4 16 96 0 0 2022 0 0 2951 -746
    1059 ######## 12752 FCF2 5 70 4552 6578 23256 -755 58.6 4801 0 65535 5275 7301 360 65535 -10 31650 -811 337 876 65381 339 54.3 16 96 0 0 2026 0 0 2951 -788
    1060 ######## 12764 FD1D 5 70 4550 6578 23292 -754 58.9 4801 0 65535 5273 7301 362 65535 -10 31638 -811 337 876 65393 368 54.3 16 96 0 0 2028 0 0 2951 -744
    1061 ######## 12776 FD17 5 70 4548 6578 23292 -750 58.9 4801 0 65535 5271 7301 364 65535 -10 31626 -811 336 876 65392 365 54.3 16 96 0 0 2031 0 0 2951 -746
    1062 ######## 12788 FD1A 5 70 4545 6578 23292 -747 58.9 4801 0 65535 5268 7301 365 65535 -10 31608 -811 336 875 65391 362 54.4 16 96 0 0 2033 0 0 2951 -746
    1063 ######## 12800 FD15 5 70 4543 6578 23280 -747 59.3 4801 0 65535 5266 7301 364 65535 -10 31596 -811 336 875 65390 360 54.5 16 96 0 0 2035 0 0 2951 -742
    1064 ######## 12812 FD1C 5 70 4541 6578 23280 -746 59.3 4801 0 65535 5264 7301 365 65535 -10 31584 -811 336 874 65392 364 54.5 16 96 0 0 2037 0 0 2951 -750
    1065 ######## 12824 FD1C 5 70 4539 6578 23280 -744 59 4801 0 65535 5262 7301 366 65535 -10 31572 -811 336 874 65391 362 54.5 16 96 0 0 2039 0 0 2951 -745
    1066 ######## 12836 FD1B 5 69 4535 6578 23280 -743 59.4 4801 0 65535 5258 7301 366 65535 -10 31548 -811 336 873 65392 364 54.6 16 96 0 0 2043 0 0 2951 -740
    1067 ######## 12848 FD1A 5 69 4532 6578 23268 -743 59.5 4801 0 65535 5255 7301 366 65535 -10 31530 -811 335 873 65392 364 54.7 16 96 0 0 2046 0 0 2951 -744
    1068 ######## 12860 FD1B 5 69 4530 6578 23280 -742 59.7 4801 0 65535 5253 7301 366 65535 -10 31518 -811 335 872 65391 361 54.8 16 96 0 0 2048 0 0 2951 -743
    1069 ######## 12872 FD19 5 69 4528 6578 23268 -744 59.5 4801 0 65535 5251 7301 365 65535 -10 31506 -811 335 872 65392 363 54.7 16 96 0 0 2050 0 0 2951 -744
    1070 ######## 12884 FD17 5 69 4526 6578 23268 -744 59.7 4801 0 65535 5249 7301 365 65535 -10 31494 -811 335 871 65392 363 54.7 16 96 0 0 2052 0 0 2951 -743
    1071 ######## 12896 FD1B 5 69 4524 6578 23268 -744 59.7 4801 0 65535 5247 7301 365 65535 -10 31482 -811 335 871 65392 363 54.8 16 96 0 0 2054 0 0 2951 -741
    1072 ######## 12908 FD17 5 69 4522 6578 23256 -744 59.7 4801 0 65535 5245 7301 365 65535 -10 31470 -811 335 871 65392 363 54.8 16 96 0 0 2057 0 0 2951 -743
    1073 ######## 12920 FD1F 5 69 4517 6578 23256 -743 59.4 4801 0 65535 5240 7301 365 65535 -10 31440 -811 334 870 65392 363 54.7 16 96 0 0 2061 0 0 2951 -739
    1074 ######## 12932 FD1C 5 69 4515 6578 23256 -742 59.7 4801 0 65535 5238 7301 365 65535 -10 31428 -811 334 869 65393 365 54.7 16 96 0 0 2063 0 0 2951 -761
    1075 ######## 12944 FD1F 5 69 4513 6578 23256 -743 59.9 4801 0 65535 5236 7301 364 65535 -10 31416 -811 334 869 65393 365 54.8 16 96 0 0 2065 0 0 2951 -740
    1076 ######## 12956 FD1D 5 69 4511 6578 23256 -742 59.2 4801 0 65535 5234 7301 365 65535 -10 31404 -811 334 868 65392 362 54.7 16 96 0 0 2067 0 0 2951 -740
    1077 ######## 12968 FD1F 5 69 4509 6578 23256 -741 59.6 4801 0 65535 5232 7301 365 65535 -10 31392 -811 334 868 65393 364 54.8 16 96 0 0 2069 0 0 2951 -746
    1078 ######## 12980 FD1F 5 69 4507 6578 23256 -741 59.5 4801 0 65535 5230 7301 365 65535 -10 31374 -811 333 867 65393 364 54.8 16 96 0 0 2072 0 0 2951 -744
    1079 ######## 12992 FD21 5 69 4505 6578 23256 -741 59.5 4801 0 65535 5227 7301 365 65535 -10 31362 -811 333 867 65393 364 54.7 16 96 0 0 2074 0 0 2951 -744
    1080 ######## 13004 FD1E 5 69 4500 6578 23244 -741 59.4 4801 0 65535 5223 7301 364 65535 -10 31338 -811 333 866 65392 361 54.7 16 96 0 0 2078 0 0 2951 -748
    1081 ######## 13016 FD17 5 69 4498 6578 23232 -742 59.4 4801 0 65535 5221 7301 364 65535 -10 31326 -811 333 866 65392 361 54.7 16 96 0 0 2080 0 0 2951 -747
    1082 ######## 13028 FD19 5 69 4496 6578 23244 -743 59.3 4801 0 65535 5219 7301 363 65535 -10 31314 -811 333 866 65392 361 54.7 16 96 0 0 2082 0 0 2951 -743
    1083 ######## 13040 FD1B 5 69 4494 6578 23232 -743 59.6 4801 0 65535 5217 7301 363 65535 -10 31302 -811 332 865 65392 363 54.7 16 96 0 0 2085 0 0 2951 -741
    1084 ######## 13052 FD09 5 69 4492 6578 23232 -745 59.1 4801 0 65535 5214 7301 362 65535 -10 31284 -811 332 865 65393 363 54.7 16 96 0 0 2087 0 0 2951 -741
    1085 ######## 13064 FD19 5 69 4489 6578 23232 -744 59.5 4801 0 65535 5212 7301 362 65535 -10 31272 -811 332 864 65393 363 54.7 16 96 0 0 2089 0 0 2951 -744
    1086 ######## 13076 FD19 5 69 4485 6578 23232 -744 59.7 4801 0 65535 5208 7301 362 65535 -10 31248 -811 332 863 65391 357 54.8 16 96 0 0 2093 0 0 2951 -747
    1087 ######## 13088 FD18 5 69 4483 6578 23220 -744 59.7 4801 0 65535 5206 7301 362 65535 -10 31236 -811 332 863 65392 360 54.9 16 96 0 0 2095 0 0 2951 -741
    1088 ######## 13100 FD19 5 69 4481 6578 23208 -745 60.2 4801 0 65535 5204 7301 361 65535 -10 31224 -811 332 863 65392 360 54.9 16 96 0 0 2097 0 0 2951 -744
    1089 ######## 13112 FD1B 5 69 4479 6578 23220 -743 60.1 4801 0 65535 5202 7301 362 65535 -10 31212 -811 331 862 65393 362 54.9 16 96 0 0 2099 0 0 2951 -741
    1090 ######## 13124 FD1A 5 69 4477 6578 23220 -743 59.9 4801 0 65535 5200 7301 362 65535 -10 31200 -811 331 862 65393 362 54.9 16 96 0 0 2102 0 0 2951 -743
    1091 ######## 13136 FD1B 5 69 4474 6578 23220 -743 59.7 4801 0 65535 5197 7301 361 65535 -10 31182 -811 331 861 65393 361 54.9 16 96 0 0 2104 0 0 2951 -740
    1092 ######## 13149 FD1D 5 68 4472 6578 23220 -742 60 4801 0 65535 5195 7301 362 65535 -10 31170 -811 331 861 65392 359 54.9 16 96 0 0 2106 0 0 2951 -743
    1093 ######## 13161 FD1C 5 68 4470 6578 23208 -743 59.8 4801 0 65535 5193 7301 361 65535 -10 31158 -811 331 861 65392 359 54.9 16 96 0 0 2108 0 0 2951 -743
    1094 ######## 13173 FD1A 5 68 4466 6578 23208 -743 59.8 4801 0 65535 5189 7301 361 65535 -10 31128 -811 330 860 65392 358 55 16 96 0 0 2113 0 0 2951 -742
    1095 ######## 13185 FD1B 5 68 4463 6578 23196 -742 59.3 4801 0 65535 5186 7301 361 65535 -10 31116 -811 330 859 65393 360 54.8 16 96 0 0 2115 0 0 2951 -740
    1096 ######## 13197 FD15 5 68 4461 6578 23196 -745 59.7 4801 0 65535 5184 7301 359 65535 -10 31104 -811 330 859 65392 358 54.8 16 96 0 0 2117 0 0 2951 -743
    1097 ######## 13209 FD1B 5 68 4459 6578 23196 -745 59.1 4801 0 65535 5182 7301 359 65535 -10 31092 -811 330 858 65392 358 54.7 16 96 0 0 2119 0 0 2951 -747
    1098 ######## 13221 FD18 5 68 4457 6578 23196 -746 59.1 4801 0 65535 5180 7301 358 65535 -10 31080 -811 330 858 65393 360 54.8 16 96 0 0 2121 0 0 2951 -742
    1099 ######## 13233 FD18 5 68 4455 6578 23196 -745 59.1 4801 0 65535 5178 7301 359 65535 -10 31068 -811 330 858 65391 355 54.8 16 96 0 0 2124 0 0 2951 -746
    1100 ######## 13245 FD1C 5 68 4453 6578 23196 -744 59.7 4801 0 65535 5176 7301 359 65535 -10 31056 -811 329 857 65392 357 54.9 16 96 0 0 2126 0 0 2951 -744
    1101 ######## 13257 FD1D 5 68 4448 6578 23196 -743 60 4801 0 65535 5171 7301 359 65535 -10 31026 -811 329 856 65393 359 54.9 16 96 0 0 2130 0 0 2951 -750
    1102 ######## 13269 FD18 5 68 4446 6578 23196 -743 59.8 4801 0 65535 5169 7301 359 65535 -10 31014 -811 329 856 65392 357 55 16 96 0 0 2132 0 0 2951 -744
    1103 ######## 13281 FD18 5 68 4444 6578 23184 -743 60.1 4801 0 65535 5167 7301 359 65535 -10 31002 -811 329 855 65391 354 55 16 96 0 0 2134 0 0 2951 -751
    1104 ######## 13293 FD18 5 68 4442 6578 23172 -744 60.3 4801 0 65535 5165 7301 358 65535 -10 30990 -811 329 855 65393 359 55.1 16 96 0 0 2136 0 0 2951 -743
    1105 ######## 13305 FD0A 5 68 4440 6578 23172 -746 59.6 4801 0 65535 5163 7301 357 65535 -10 30978 -811 328 855 65393 359 55.1 16 96 0 0 2139 0 0 2951 -742
    1106 ######## 13317 FD1A 5 68 4437 6578 23172 -745 59.9 4801 0 65535 5160 7301 357 65535 -10 30960 -811 328 854 65392 356 55 16 96 0 0 2141 0 0 2951 -747
    1107 ######## 13329 FD17 5 68 4435 6578 23172 -745 59.5 4801 0 65535 5158 7301 357 65535 -10 30948 -811 328 854 65393 358 55 16 96 0 0 2143 0 0 2951 -744
    1108 ######## 13341 FD17 5 68 4431 6578 23172 -745 59.2 4801 0 65535 5154 7301 357 65535 -10 30924 -811 328 853 65393 358 55 16 96 0 0 2147 0 0 2951 -742
    1109 ######## 13353 FD1C 5 68 4429 6578 23172 -744 59.9 4801 0 65535 5152 7301 357 65535 -10 30912 -811 328 853 65393 358 55 16 96 0 0 2149 0 0 2951 -750
    1110 ######## 13365 FD1C 5 68 4427 6578 23172 -744 60.1 4801 0 65535 5150 7301 357 65535 -10 30900 -811 327 852 65393 357 55.1 16 96 0 0 2152 0 0 2951 -741
    1111 ######## 13377 FD10 5 68 4425 6578 23148 -745 60.1 4801 0 65535 5148 7301 356 65535 -10 30882 -811 327 852 65391 353 55.1 16 96 0 0 2154 0 0 2951 -744
    1112 ######## 13389 FD18 5 68 4422 6578 23160 -745 60.2 4801 0 65535 5145 7301 356 65535 -10 30870 -811 327 851 65392 355 55.2 16 96 0 0 2156 0 0 2951 -744
    1113 ######## 13401 FD0D 5 68 4420 6578 23160 -745 59.8 4801 0 65535 5143 7301 356 65535 -10 30858 -811 327 851 65392 355 55.2 16 96 0 0 2158 0 0 2951 -746
    1114 ######## 13413 FD1C 5 68 4418 6578 23148 -744 60.2 4801 0 65535 5141 7301 356 65535 -10 30846 -811 327 850 65392 354 55.2 16 96 0 0 2160 0 0 2951 -744
    1115 ######## 13425 FD1A 5 68 4416 6578 23148 -744 60.2 4801 0 65535 5139 7301 356 65535 -10 30834 -811 327 850 65392 354 55.1 16 96 0 0 2162 0 0 2951 -744
    1116 ######## 13437 FD1A 5 68 4411 6578 23148 -744 60.7 4801 0 65535 5134 7301 356 65535 -10 30804 -811 326 849 65392 354 55.4 16 96 0 0 2167 0 0 2951 -744
    1117 ######## 13449 FE0C 5 68 4409 6578 23304 -713 60.5 4801 0 65535 5132 7301 378 65535 -10 30792 -811 326 849 65439 525 55.4 16 96 0 0 2169 0 0 2951 -500
    1118 ######## 13461 FE07 5 68 4408 6578 23316 -602 60.2 4801 0 65535 5131 7301 445 65535 -10 30786 -811 326 849 65439 525 55.3 16 96 0 0 2171 0 0 2951 -500
    1119 ######## 13473 FE0E 5 67 4406 6578 23328 -549 60.1 4801 0 65535 5129 7301 482 65535 -10 30774 -811 326 848 65439 525 55.1 16 96 0 0 2172 0 0 2951 -504
    1120 ######## 13485 FE09 5 67 4405 6578 23304 -526 59.2 4801 0 65535 5128 7301 502 65535 -10 30768 -811 326 848 65438 519 54.8 16 96 0 0 2173 0 0 2951 -537
    1121 ######## 13497 FE11 5 67 4403 6578 23328 -515 58.8 4801 0 65535 5126 7301 513 65535 -10 30756 -811 326 848 65436 509 54.3 16 96 0 0 2175 0 0 2951 -512
    1122 ######## 13509 FE10 5 67 4402 6578 23328 -507 58.2 4801 0 65535 5125 7301 521 65535 -10 30750 -811 326 847 65439 524 53.8 16 96 0 0 2176 0 0 2951 -497
    1123 ######## 13521 FE02 5 67 4399 6578 23304 -503 56.7 4801 0 65535 5122 7301 525 65535 -10 30732 -811 325 847 65437 513 52.9 16 96 0 0 2179 0 0 2951 -509
    1124 ######## 13533 FDFF 5 67 4398 6578 23304 -508 56 4801 0 65535 5121 7301 519 65535 -10 30720 -811 325 846 65437 513 52.4 16 96 0 0 2181 0 0 2951 -512
    1125 ######## 13545 FE03 5 67 4396 6578 23316 -510 55.2 4801 0 65535 5119 7301 517 65535 -10 30714 -811 325 846 65437 513 52 16 96 0 0 2182 0 0 2951 -517
    1126 ######## 13557 FE00 5 67 4395 6578 23340 -512 54.2 801 0 65535 5118 7301 515 65535 -10 30708 -811 325 846 65436 508 51.5 16 96 28200 2250 2184 0 0 2951 -516
    1127 ######## 13569 FDFB 5 67 4393 6578 23328 -514 53.6 801 0 65535 5116 7301 513 65535 -10 30696 -811 325 846 65435 503 51.1 16 96 28200 2250 2185 0 0 2951 -527
    1128 ######## 13581 FDC4 5 67 4392 6578 23292 -531 53.1 801 0 65535 5114 7301 493 65535 -10 30684 -811 325 845 65423 449 50.7 16 96 28200 2250 2187 0 0 2951 -593
    1129 ######## 13594 FD78 5 67 4390 6578 23232 -582 52.3 801 0 65535 5113 7301 453 65535 -10 30672 -811 325 845 65411 406 50.4 16 96 28200 2250 2189 0 0 2951 -649
    1130 ######## 13606 FD6F 5 67 4386 6578 23208 -641 51.8 801 0 65535 5109 7301 411 65535 -10 30654 -811 324 844 65408 396 49.9 16 96 28200 2250 2193 0 0 2951 -659
    1131 ######## 13618 FD72 5 67 4384 6578 23208 -650 51.8 801 0 65535 5107 7301 405 65535 -10 30642 -811 324 844 65408 396 49.9 16 96 28200 2250 2194 0 0 2951 -659
    1132 ######## 13630 FD67 5 67 4382 6578 23208 -658 51.7 801 0 65535 5105 7301 400 65535 -10 30630 -811 324 843 65407 392 49.9 16 96 28200 2250 2196 0 0 2951 -665
    1133 ######## 13642 FD6A 5 67 4380 6578 23208 -661 51.5 801 0 65535 5103 7301 398 65535 -10 30618 -811 324 843 65407 392 49.8 16 96 28200 2250 2198 0 0 2951 -673
    1134 ######## 13654 FD6B 5 67 4378 6578 23208 -663 51.6 801 0 65535 5101 7301 396 65535 -10 30606 -811 324 843 65408 395 49.8 16 96 28200 2250 2200 0 0 2951 -663
    1135 ######## 13666 FD57 5 67 4376 6578 23184 -665 51.6 801 0 65535 5099 7301 395 65535 -10 30594 -811 324 842 65408 395 49.8 16 96 28200 2250 2202 0 0 2951 -666
    1136 ######## 13678 FD6D 5 67 4374 6578 23196 -663 51.9 801 0 65535 5097 7301 396 65535 -10 30582 -811 324 842 65408 395 49.9 16 96 28200 2250 2204 0 0 2951 -667
    1137 ######## 13690 FD69 5 67 4370 6578 23184 -664 52.2 801 0 65535 5093 7301 395 65535 -10 30558 -811 323 841 65407 391 50.1 16 96 28200 2250 2208 0 0 2951 -666
    1138 ######## 13702 FD6C 5 67 4368 6578 23184 -663 52.5 801 0 65535 5091 7301 395 65535 -10 30546 -811 323 841 65408 394 50.2 16 96 28200 2250 2210 0 0 2951 -660
    1139 ######## 13714 FD6B 5 67 4366 6578 23184 -663 52.7 801 0 65535 5089 7301 395 65535 -10 30534 -811 323 840 65408 394 50.3 16 96 28200 2250 2212 0 0 2951 -663
    1140 ######## 13726 FD68 5 67 4364 6578 23184 -663 52.8 801 0 65535 5087 7301 395 65535 -10 30522 -811 323 840 65408 394 50.4 16 96 28200 2250 2214 0 0 2951 -664
    1141 ######## 13738 FD6A 5 67 4363 6578 23184 -663 53.1 801 0 65535 5086 7301 395 65535 -10 30516 -811 323 840 65407 391 50.5 16 96 28200 2250 2216 0 0 2951 -664
    1142 ######## 13750 FD6B 5 67 4361 6578 23184 -664 53 801 0 65535 5084 7301 394 65535 -10 30504 -811 323 839 65408 393 50.6 16 96 28200 2250 2217 0 0 2951 -673
    1143 ######## 13762 FD6C 5 67 4357 6578 23184 -664 53.7 801 0 65535 5080 7301 394 65535 -10 30480 -811 322 839 65408 393 50.9 16 96 28200 2250 2221 0 0 2951 -668
    1144 ######## 13774 FD68 5 67 4355 6578 23172 -664 54.1 801 0 65535 5078 7301 394 65535 -10 30468 -811 322 838 65407 390 51.1 16 96 28200 2250 2223 0 0 2951 -665
    1145 ######## 13786 FD6B 5 67 4353 6578 23172 -664 54.5 801 0 65535 5076 7301 393 65535 -10 30456 -811 322 838 65408 390 51.3 16 96 28200 2250 2225 0 0 2951 -667
    1146 ######## 13798 FD67 5 67 4351 6578 23160 -663 55.1 801 0 65535 5074 7301 394 65535 -10 30444 -811 322 838 65408 393 51.6 16 96 0 0 2227 0 0 2951 -662
    1147 ######## 13810 FD65 5 67 4349 6578 23160 -664 54.8 801 0 65535 5072 7301 393 65535 -10 30432 -811 322 837 65408 392 51.7 16 96 28200 2250 2229 0 0 2951 -661
    1148 ######## 13822 FD6A 5 67 4347 6578 23160 -664 55.1 801 0 65535 5070 7301 393 65535 -10 30420 -811 322 837 65408 392 51.7 16 96 0 0 2231 0 0 2951 -667
    1149 ######## 13834 FD6B 5 67 4345 6578 23160 -663 55.5 801 0 65535 5068 7301 393 65535 -10 30408 -811 321 836 65409 395 51.8 16 96 0 0 2233 0 0 2951 -663
    1150 ######## 13846 FD6D 5 67 4343 6578 23160 -664 55.6 801 0 65535 5066 7301 392 65535 -10 30396 -811 321 836 65408 392 51.9 16 96 0 0 2235 0 0 2951 -664
    1151 ######## 13858 FD6C 5 66 4340 6578 23160 -663 56.4 801 0 65535 5062 7301 393 65535 -10 30372 -811 321 835 65408 391 52.1 16 96 0 0 2239 0 0 2951 -663
    1152 ######## 13870 FD66 5 66 4337 6578 23160 -664 56.5 801 0 65535 5060 7301 392 65535 -10 30360 -811 321 835 65408 391 52.3 16 96 0 0 2241 0 0 2951 -665
    1153 ######## 13882 FD6A 5 66 4336 6578 23160 -663 56.7 801 0 65535 5058 7301 392 65535 -10 30348 -811 321 834 65409 394 52.4 16 96 0 0 2243 0 0 2951 -663
    1154 ######## 13894 FD6E 5 66 4334 6578 23136 -663 56.2 801 0 65535 5057 7301 392 65535 -10 30336 -811 321 834 65408 391 52.4 16 96 0 0 2245 0 0 2951 -668
    1155 ######## 13906 FD66 5 66 4332 6578 23124 -666 56.7 801 0 65535 5055 7301 390 65535 -10 30330 -811 320 834 65404 379 52.4 16 96 0 0 2246 0 0 2951 -684
    1156 ######## 13918 FD68 5 66 4330 6578 23124 -667 56.7 801 0 65535 5053 7301 390 65535 -10 30318 -811 320 833 65408 390 52.5 16 96 0 0 2248 0 0 2951 -668
    1157 ######## 13930 FD6A 5 66 4328 6578 23124 -666 57 801 0 65535 5051 7301 390 65535 -10 30306 -811 320 833 65408 390 52.5 16 96 0 0 2250 0 0 2951 -667
    1158 ######## 13942 FD66 5 66 4324 6578 23124 -665 58.1 801 0 65535 5047 7301 390 65535 -10 30282 -811 320 832 65408 390 52.8 16 96 0 0 2254 0 0 2951 -666
    1159 ######## 13954 FD6C 5 66 4322 6578 23124 -665 58.1 801 0 65535 5045 7301 390 65535 -10 30270 -811 320 832 65408 390 52.9 16 96 0 0 2256 0 0 2951 -666
    1160 ######## 13966 FD6C 5 66 4320 6578 23124 -665 58 801 0 65535 5043 7301 390 65535 -10 30258 -811 320 832 65407 387 53 16 96 0 0 2258 0 0 2951 -667
    1161 ######## 13978 FD6C 5 66 4318 6578 23124 -667 58.1 801 0 65535 5041 7301 388 65535 -10 30246 -811 319 831 65408 390 53 16 96 0 0 2260 0 0 2951 -671
    1162 ######## 13990 FD64 5 66 4317 6578 23100 -667 58.2 801 0 65535 5039 7301 388 65535 -10 30234 -811 319 831 65408 390 53.1 16 96 0 0 2262 0 0 2951 -668
    1163 ######## 14002 FD6A 5 66 4315 6578 23112 -666 57.8 801 0 65535 5038 7301 389 65535 -10 30228 -811 319 831 65408 386 53.1 16 96 0 0 2264 0 0 2951 -669
    1164 ######## 14014 FD63 5 66 4311 6578 23100 -667 57.5 801 0 65535 5034 7301 388 65535 -10 30198 -811 319 830 65408 389 53.2 16 96 0 0 2268 0 0 2951 -666
    1165 ######## 14026 FD6C 5 66 4309 6578 23112 -666 57.9 801 0 65535 5032 7301 388 65535 -10 30192 -811 319 829 65408 389 53.2 16 96 0 0 2269 0 0 2951 -670
    1166 ######## 14038 FD68 5 66 4307 6578 23100 -666 57.7 801 0 65535 5030 7301 388 65535 -10 30180 -811 319 829 65408 389 53.3 16 96 0 0 2271 0 0 2951 -665
    1167 ######## 14050 FD6A 5 66 4305 6578 23100 -666 57.5 801 0 65535 5028 7301 388 65535 -10 30168 -811 318 829 65408 389 53.3 16 96 0 0 2273 0 0 2951 -669
    1168 ######## 14063 FD68 5 66 4303 6578 23100 -665 57.7 801 0 65535 5026 7301 388 65535 -10 30156 -811 318 828 65408 388 53.4 16 96 0 0 2275 0 0 2951 -667
    1169 ######## 14075 FD59 5 66 4301 6578 23076 -667 57.3 801 0 65535 5024 7301 387 65535 -10 30144 -811 318 828 65406 382 53.3 16 96 0 0 2277 0 0 2951 -673
    1170 ######## 14087 FD64 5 66 4297 6578 23088 -667 56.9 801 0 65535 5020 7301 387 65535 -10 30120 -811 318 827 65408 388 53.1 16 96 0 0 2281 0 0 2951 -663
    1171 ######## 14099 FD67 5 66 4295 6578 23100 -666 56.8 801 0 65535 5018 7301 387 65535 -10 30108 -811 318 827 65408 388 53.1 16 96 0 0 2283 0 0 2951 -665
    1172 ######## 14111 FD62 5 66 4293 6578 23076 -666 56.6 801 0 65535 5016 7301 387 65535 -10 30096 -811 318 826 65408 387 53 16 96 0 0 2285 0 0 2951 -664
    1173 ######## 14123 FD66 5 66 4291 6578 23088 -666 56.7 801 0 65535 5014 7301 387 65535 -10 30084 -811 317 826 65407 384 53 16 96 0 0 2287 0 0 2951 -669
    1174 ######## 14135 FD66 5 66 4290 6578 23076 -666 56.7 801 0 65535 5013 7301 386 65535 -10 30072 -811 317 826 65408 387 53 16 96 0 0 2289 0 0 2951 -663
    1175 ######## 14147 FD69 5 66 4288 6578 23076 -666 57.1 801 0 65535 5011 7301 386 65535 -10 30066 -811 317 825 65408 387 53.1 16 96 0 0 2290 0 0 2951 -667
    1176 ######## 14159 FD5C 5 66 4286 6578 23076 -683 57 801 0 65535 5009 7301 377 65535 -10 30048 -811 317 825 65400 364 53.1 16 96 0 0 2293 0 0 2951 -710
    1177 ######## 14171 FD67 5 66 4282 6578 23076 -676 57.1 801 0 65535 5004 7301 381 65535 -10 30024 -811 317 824 65408 386 53.2 16 96 0 0 2297 0 0 2951 -667
    1178 ######## 14183 FD68 5 66 4280 6578 23076 -672 57.4 801 0 65535 5003 7301 382 65535 -10 30018 -811 317 824 65408 386 53.3 16 96 0 0 2299 0 0 2951 -667
    1179 ######## 14195 FD65 5 66 4278 6578 23076 -670 57.3 801 0 65535 5001 7301 383 65535 -10 30006 -811 316 823 65408 386 53.3 16 96 0 0 2300 0 0 2951 -666
    1180 ######## 14207 FD68 5 66 4276 6578 23076 -668 57.2 801 0 65535 4999 7301 384 65535 -10 29994 -811 316 823 65408 386 53.4 16 96 0 0 2302 0 0 2951 -667
    1181 ######## 14219 FD64 5 65 4274 6578 23076 -668 57.4 801 0 65535 4997 7301 384 65535 -10 29982 -811 316 823 65408 386 53.4 16 96 0 0 2304 0 0 2951 -665
    1182 ######## 14231 FD67 5 65 4272 6578 23064 -668 57.2 801 0 65535 4995 7301 384 65535 -10 29970 -811 316 822 65408 385 53.3 16 96 0 0 2306 0 0 2951 -674
    1183 ######## 14243 FD67 5 65 4270 6578 23064 -668 57 801 0 65535 4993 7301 384 65535 -10 29958 -811 316 822 65408 385 53.3 16 96 0 0 2308 0 0 2951 -670
    1184 ######## 14255 FD69 5 65 4268 6578 23064 -668 57.5 801 0 65535 4991 7301 383 65535 -10 29946 -811 316 822 65408 385 53.4 16 96 0 0 2310 0 0 2951 -669
    1185 ######## 14267 FD64 5 65 4264 6578 23052 -667 57.6 801 0 65535 4987 7301 384 65535 -10 29922 -811 315 821 65408 385 53.5 16 96 0 0 2314 0 0 2951 -667
    1186 ######## 14279 FD63 5 65 4262 6578 23052 -669 57.6 801 0 65535 4985 7301 382 65535 -10 29910 -811 315 820 65407 381 53.5 16 96 0 0 2316 0 0 2951 -669
    1187 ######## 14291 FD63 5 65 4260 6578 23052 -669 57.2 801 0 65535 4983 7301 381 65535 -10 29898 -811 315 820 65405 376 53.4 16 96 0 0 2318 0 0 2951 -707
    1188 ######## 14303 FD66 5 65 4258 6578 23052 -673 57.1 801 0 65535 4981 7301 380 65535 -10 29886 -811 315 820 65407 381 53.3 16 96 0 0 2320 0 0 2951 -669
    1189 ######## 14315 FD67 5 65 4256 6578 23052 -670 57.2 801 0 65535 4979 7301 381 65535 -10 29874 -811 315 819 65407 381 53.3 16 96 0 0 2322 0 0 2951 -667
    1190 ######## 14327 FD62 5 65 4254 6578 23040 -669 57.2 801 0 65535 4977 7301 382 65535 -10 29862 -811 315 819 65407 381 53.3 16 96 0 0 2324 0 0 2951 -669
    1191 ######## 14339 FD67 5 65 4252 6578 23040 -668 57.6 801 0 65535 4975 7301 382 65535 -10 29850 -811 315 818 65408 383 53.5 16 96 0 0 2326 0 0 2951 -668
    1192 ######## 14351 FD65 5 65 4249 6578 23040 -668 58.5 801 0 65535 4972 7301 382 65535 -10 29826 -811 314 818 65408 383 53.7 16 96 0 0 2330 0 0 2951 -665
    1193 ######## 14363 FD6A 5 65 4247 6578 23040 -668 58.3 801 0 65535 4970 7301 382 65535 -10 29820 -811 314 817 65408 383 53.7 16 96 0 0 2332 0 0 2951 -664
    1194 ######## 14375 FD67 5 65 4245 6578 23040 -667 57.9 801 0 65535 4968 7301 382 65535 -10 29808 -811 314 817 65409 386 53.7 16 96 0 0 2333 0 0 2951 -664
    1195 ######## 14387 FD66 5 65 4243 6578 23028 -667 58.1 801 0 65535 4966 7301 382 65535 -10 29796 -811 314 817 65407 380 53.7 16 96 0 0 2335 0 0 2951 -670
    1196 ######## 14399 FD68 5 65 4241 6578 23028 -668 57.7 801 0 65535 4964 7301 381 65535 -10 29784 -811 314 816 65409 380 53.7 16 96 0 0 2337 0 0 2951 -671
    1197 ######## 14411 FD69 5 65 4239 6578 23016 -668 57.1 801 0 65535 4962 7301 381 65535 -10 29772 -811 314 816 65408 383 53.5 16 96 0 0 2339 0 0 2951 -670
    1198 ######## 14423 FD69 5 65 4235 6578 23016 -668 57.5 801 0 65535 4958 7301 380 65535 -10 29748 -811 313 815 65407 379 53.4 16 96 0 0 2343 0 0 2951 -668
    1199 ######## 14436 FD65 5 65 4233 6578 23016 -668 57.2 801 0 65535 4956 7301 380 65535 -10 29736 -811 313 815 65408 382 53.4 16 96 0 0 2345 0 0 2951 -667
    1200 ######## 14448 FD62 5 65 4231 6578 23016 -668 57.1 801 0 65535 4954 7301 380 65535 -10 29724 -811 313 814 65407 379 53.3 16 96 0 0 2347 0 0 2951 -667
    1201 ######## 14460 FD66 5 65 4229 6578 23016 -669 57 801 0 65535 4952 7301 379 65535 -10 29712 -811 313 814 65408 382 53.3 16 96 0 0 2349 0 0 2951 -665
    1202 ######## 14472 FD5F 5 65 4227 6578 23016 -669 56.9 801 0 65535 4950 7301 379 65535 -10 29700 -811 313 814 65408 382 53.2 16 96 0 0 2351 0 0 2951 -666
    1203 ######## 14484 FD66 5 65 4225 6578 23004 -668 56.9 801 0 65535 4948 7301 379 65535 -10 29688 -811 313 813 65407 378 53.2 16 96 0 0 2353 0 0 2951 -673
    1204 ######## 14496 FD69 5 65 4223 6578 23004 -668 56.7 801 0 65535 4946 7301 379 65535 -10 29676 -811 312 813 65408 381 53.1 16 96 0 0 2355 0 0 2951 -669
    1205 ######## 14508 FD67 5 65 4221 6578 23004 -669 56.9 801 0 65535 4944 7301 379 65535 -10 29664 -811 312 813 65404 370 53.2 16 96 0 0 2357 0 0 2951 -675
    1206 ######## 14520 FD69 5 65 4217 6578 23004 -668 56.7 801 0 65535 4940 7301 379 65535 -10 29640 -811 312 812 65408 381 53.1 16 96 0 0 2361 0 0 2951 -671
    1207 ######## 14532 FD6A 5 65 4215 6578 22992 -667 56.6 801 0 65535 4938 7301 379 65535 -10 29628 -811 312 811 65408 380 53 16 96 0 0 2363 0 0 2951 -669
    1208 ######## 14544 FD68 5 65 4213 6578 22992 -667 56.4 801 0 65535 4936 7301 379 65535 -10 29616 -811 312 811 65408 380 53 16 96 0 0 2365 0 0 2951 -666
    1209 ######## 14556 FD68 5 65 4211 6578 22992 -667 56.2 801 0 65535 4934 7301 379 65535 -10 29604 -811 312 811 65407 377 52.9 16 96 0 0 2367 0 0 2951 -672
    1210 ######## 14568 FD67 5 65 4210 6578 22992 -667 56.3 801 0 65535 4933 7301 379 65535 -10 29598 -811 311 810 65408 380 52.9 16 96 0 0 2369 0 0 2951 -668
    1211 ######## 14580 FD61 5 64 4208 6578 22980 -669 56.2 801 0 65535 4931 7301 377 65535 -10 29586 -811 311 810 65407 377 52.8 16 96 0 0 2371 0 0 2951 -665
    1212 ######## 14592 FD66 5 64 4206 6578 22992 -669 56.2 801 0 65535 4929 7301 377 65535 -10 29568 -811 311 809 65409 382 52.8 16 96 0 0 2373 0 0 2951 -665
    1213 ######## 14604 FD65 5 64 4202 6578 22980 -668 56 801 0 65535 4925 7301 377 65535 -10 29550 -811 311 809 65408 379 52.8 16 96 0 0 2376 0 0 2951 -669
    1214 ######## 14616 FD66 5 64 4200 6578 22980 -668 55.8 801 0 65535 4923 7301 377 65535 -10 29538 -811 311 808 65408 379 52.7 16 96 0 0 2378 0 0 2951 -666
    1215 ######## 14628 FD62 5 64 4198 6578 22968 -669 56 801 0 65535 4921 7301 377 65535 -10 29526 -811 311 808 65408 379 52.7 16 96 0 0 2381 0 0 2951 -669
    1216 ######## 14640 FD66 5 64 4196 6578 22968 -670 55.8 801 0 65535 4919 7301 376 65535 -10 29514 -811 310 808 65408 379 52.7 16 96 0 0 2382 0 0 2951 -667
    1217 ######## 14652 FD64 5 64 4194 6578 22968 -670 55.9 801 0 65535 4917 7301 376 65535 -10 29502 -811 310 807 65409 381 52.7 16 96 0 0 2384 0 0 2951 -672
    1218 ######## 14664 FD68 5 64 4192 6578 22968 -669 56.1 801 0 65535 4915 7301 376 65535 -10 29490 -811 310 807 65407 375 52.8 16 96 0 0 2386 0 0 2951 -674
    1219 ######## 14676 FD68 5 64 4190 6578 22968 -669 56.2 801 0 65535 4913 7301 376 65535 -10 29478 -811 310 807 65407 375 52.7 16 96 0 0 2388 0 0 2951 -672
    1220 ######## 14688 FD66 5 64 4188 6578 22968 -670 56.3 801 0 65535 4911 7301 375 65535 -10 29466 -811 310 806 65408 378 52.9 16 96 0 0 2390 0 0 2951 -670
    1221 ######## 14700 FD65 5 64 4184 6578 22968 -669 56.1 801 0 65535 4907 7301 375 65535 -10 29442 -811 310 805 65408 377 52.9 16 96 0 0 2394 0 0 2951 -670
    1222 ######## 14712 FD62 5 64 4182 6578 22956 -671 56.4 801 0 65535 4905 7301 374 65535 -10 29430 -811 309 805 65408 377 52.9 16 96 0 0 2396 0 0 2951 -673
    1223 ######## 14724 FD65 5 64 4180 6578 22956 -670 56.4 801 0 65535 4903 7301 374 65535 -10 29418 -811 309 805 65409 380 52.8 16 96 0 0 2398 0 0 2951 -666
    1224 ######## 14737 FD68 5 64 4178 6578 22956 -669 56.4 801 0 65535 4901 7301 375 65535 -10 29406 -811 309 804 65408 377 52.8 16 96 0 0 2400 0 0 2951 -673
    1225 ######## 14749 FD67 5 64 4176 6578 22944 -668 56 801 0 65535 4899 7301 375 65535 -10 29394 -811 309 804 65408 377 52.7 16 96 0 0 2402 0 0 2951 -668
    1226 ######## 14761 FD63 5 64 4174 6578 22944 -668 56.1 801 0 65535 4897 7301 375 65535 -10 29382 -811 309 804 65409 380 52.8 16 96 0 0 2404 0 0 2951 -671
    1227 ######## 14773 FD65 5 64 4172 6578 22944 -669 56.5 801 0 65535 4895 7301 374 65535 -10 29370 -811 309 803 65408 376 52.8 16 96 0 0 2406 0 0 2951 -670
    1228 ######## 14785 FD65 5 64 4168 6578 22944 -669 56.5 801 0 65535 4891 7301 374 65535 -10 29346 -811 308 802 65408 376 52.8 16 96 0 0 2410 0 0 2951 -672
    1229 ######## 14797 FD66 5 64 4167 6578 22944 -668 56.4 801 0 65535 4890 7301 374 65535 -10 29334 -811 308 802 65408 376 52.9 16 96 0 0 2412 0 0 2951 -669
    1230 ######## 14809 FD67 5 64 4165 6578 22932 -669 56.7 801 0 65535 4888 7301 374 65535 -10 29322 -811 308 802 65408 376 52.9 16 96 0 0 2414 0 0 2951 -667
    1231 ######## 14821 FD63 5 64 4163 6578 22932 -669 56.6 801 0 65535 4886 7301 373 65535 -10 29316 -811 308 801 65408 375 52.9 16 96 0 0 2416 0 0 2951 -667
    1232 ######## 14833 FD63 5 64 4161 6578 22932 -670 56.5 801 0 65535 4883 7301 373 65535 -10 29298 -811 308 801 65408 375 52.9 16 96 0 0 2418 0 0 2951 -669
    1233 ######## 14845 FD64 5 64 4159 6578 22920 -669 56.5 801 0 65535 4882 7301 373 65535 -10 29292 -811 308 801 65408 375 52.9 16 96 0 0 2420 0 0 2951 -671
    1234 ######## 14857 FD64 5 64 4157 6578 22920 -668 56.6 801 0 65535 4880 7301 373 65535 -10 29280 -811 308 800 65408 375 52.9 16 96 0 0 2421 0 0 2951 -668
    1235 ######## 14869 FD65 5 64 4153 6578 22920 -668 56 801 0 65535 4876 7301 373 65535 -10 29256 -811 307 799 65407 372 52.8 16 96 0 0 2425 0 0 2951 -686
    1236 ######## 14881 FD64 5 64 4151 6578 22920 -670 55.9 801 0 65535 4874 7301 372 65535 -10 29244 -811 307 799 65408 375 52.7 16 96 0 0 2427 0 0 2951 -667
    1237 ######## 14893 FD61 5 64 4149 6578 22920 -670 55.9 801 0 65535 4872 7301 372 65535 -10 29232 -811 307 799 65408 375 52.7 16 96 0 0 2429 0 0 2951 -668
    1238 ######## 14905 FD64 5 64 4147 6578 22920 -671 56.2 801 0 65535 4870 7301 371 65535 -10 29220 -811 307 798 65408 374 52.7 16 96 0 0 2431 0 0 2951 -666
    1239 ######## 14917 FD61 5 64 4145 6578 22908 -670 56.1 801 0 65535 4868 7301 371 65535 -10 29208 -811 307 798 65409 377 52.7 16 96 0 0 2433 0 0 2951 -671
    1240 ######## 14929 FD63 5 63 4143 6578 22908 -669 56.5 801 0 65535 4866 7301 372 65535 -10 29196 -811 307 798 65408 374 52.8 16 96 0 0 2435 0 0 2951 -671
    1241 ######## 14941 FD68 5 63 4141 6578 22908 -669 56.3 801 0 65535 4864 7301 371 65535 -10 29184 -811 306 797 65408 374 52.8 16 96 0 0 2437 0 0 2951 -671
    1242 ######## 14953 FD67 5 63 4139 6578 22896 -669 56.2 801 0 65535 4862 7301 371 65535 -10 29172 -811 306 797 65408 374 52.8 16 96 0 0 2439 0 0 2951 -675
    1243 ######## 14965 FD66 5 63 4135 6578 22896 -668 56.2 801 0 65535 4858 7301 371 65535 -10 29148 -811 306 796 65408 373 52.7 16 96 0 0 2443 0 0 2951 -666
    1244 ######## 14977 FD65 5 63 4133 6578 22896 -669 56 801 0 65535 4856 7301 371 65535 -10 29136 -811 306 796 65409 376 52.7 16 96 0 0 2445 0 0 2951 -668
    1245 ######## 14989 FD5F 5 63 4131 6578 22896 -668 55.8 801 0 65535 4854 7301 371 65535 -10 29124 -811 306 795 65409 376 52.6 16 96 0 0 2447 0 0 2951 -671
    1246 ######## 15001 FD63 5 63 4129 6578 22896 -669 55.7 801 0 65535 4852 7301 370 65535 -10 29112 -811 305 795 65409 376 52.6 16 96 0 0 2449 0 0 2951 -669
    1247 ######## 15013 FD44 5 63 4127 6578 22860 -674 55.8 801 0 65535 4850 7301 366 65535 -10 29100 -811 305 795 65402 356 52.6 16 96 0 0 2451 0 0 2951 -701
    1248 ######## 15025 FD48 5 63 4125 6578 22848 -689 55.9 801 0 65535 4848 7301 359 65535 -10 29088 -811 305 794 65403 358 52.6 16 96 0 0 2453 0 0 2951 -697
    1249 ######## 15037 FD44 5 63 4123 6578 22848 -695 55.6 801 0 65535 4846 7301 356 65535 -10 29076 -811 305 794 65402 356 52.5 16 96 0 0 2455 0 0 2951 -674
    1250 ######## 15049 FD52 5 63 4119 6578 22848 -683 55.4 801 0 65535 4842 7301 362 65535 -10 29052 -811 305 793 65407 369 52.5 16 96 0 0 2459 0 0 2951 -687
    1251 ######## 15061 FD4F 5 63 4117 6578 22848 -685 55.6 801 0 65535 4840 7301 361 65535 -10 29040 -811 305 793 65405 363 52.5 16 96 0 0 2461 0 0 2951 -687
    1252 ######## 15073 FD4B 5 63 4115 6578 22848 -688 55.4 801 0 65535 4838 7301 359 65535 -10 29028 -811 304 792 65405 363 52.5 16 96 0 0 2463 0 0 2951 -689
    1253 ######## 15085 FD63 5 63 4113 6578 22860 -682 55.8 801 0 65535 4836 7301 362 65535 -10 29016 -811 304 792 65409 374 52.5 16 96 0 0 2465 0 0 2951 -669
    1254 ######## 15097 FD64 5 63 4112 6578 22860 -677 55.8 801 0 65535 4834 7301 364 65535 -10 29004 -811 304 791 65408 371 52.6 16 96 0 0 2467 0 0 2951 -675
    1255 ######## 15109 FD63 5 63 4110 6578 22860 -674 55.9 801 0 65535 4833 7301 366 65535 -10 28992 -811 304 791 65408 371 52.6 16 96 0 0 2469 0 0 2951 -676
    1256 ######## 15121 FD64 5 63 4108 6578 22860 -671 55.7 801 0 65535 4830 7301 367 65535 -10 28980 -811 304 791 65408 371 52.6 16 96 0 0 2471 0 0 2951 -674
    1257 ######## 15134 FD60 5 63 4104 6578 22848 -670 55.7 801 0 65535 4827 7301 368 65535 -10 28962 -811 304 790 65409 373 52.5 16 96 0 0 2475 0 0 2951 -674
    1258 ######## 15146 FD64 5 63 4101 6578 22848 -670 55.3 801 0 65535 4824 7301 367 65535 -10 28944 -811 303 790 65409 373 52.4 16 96 0 0 2477 0 0 2951 -667
    1259 ######## 15158 FD62 5 63 4100 6578 22848 -670 55.5 801 0 65535 4822 7301 367 65535 -10 28932 -811 303 789 65409 373 52.4 16 96 0 0 2479 0 0 2951 -669
    1260 ######## 15170 FD66 5 63 4098 6578 22848 -669 55.5 801 0 65535 4821 7301 368 65535 -10 28926 -811 303 789 65409 373 52.4 16 96 0 0 2481 0 0 2951 -670
    1261 ######## 15182 FD5D 5 63 4096 6578 22836 -671 55.5 801 0 65535 4819 7301 366 65535 -10 28914 -811 303 789 65409 373 52.4 16 96 0 0 2482 0 0 2951 -676
    1262 ######## 15194 FD62 5 63 4094 6578 22836 -671 55.4 801 0 65535 4817 7301 366 65535 -10 28902 -811 303 788 65408 369 52.4 16 96 0 0 2484 0 0 2951 -670
    1263 ######## 15206 FD65 5 63 4092 6578 22836 -670 55.2 801 0 65535 4815 7301 366 65535 -10 28890 -811 303 788 65408 369 52.4 16 96 0 0 2486 0 0 2951 -670
    1264 ######## 15218 FD63 5 63 4090 6578 22848 -669 55.2 801 0 65535 4813 7301 366 65535 -10 28878 -811 303 787 65406 363 52.3 16 96 0 0 2488 0 0 2951 -668
    1265 ######## 15230 FD5F 5 63 4086 6578 22824 -670 55.8 801 0 65535 4809 7301 366 65535 -10 28854 -811 302 787 65409 372 52.4 16 96 0 0 2492 0 0 2951 -666
    1266 ######## 15242 FD62 5 63 4084 6578 22824 -670 55.7 801 0 65535 4807 7301 366 65535 -10 28842 -811 302 786 65409 371 52.5 16 96 0 0 2494 0 0 2951 -669
    1267 ######## 15254 FD67 5 63 4082 6578 22824 -669 56.4 801 0 65535 4805 7301 366 65535 -10 28830 -811 302 786 65408 368 52.7 16 96 0 0 2496 0 0 2951 -667
    1268 ######## 15266 FD62 5 63 4080 6578 22812 -671 56.8 801 0 65535 4803 7301 365 65535 -10 28818 -811 302 786 65409 371 52.8 16 96 0 0 2498 0 0 2951 -672
    1269 ######## 15278 FD5E 5 62 4013 6513 22824 -671 56.6 801 0 65535 4834 7334 359 65535 -10 29004 -811 297 766 65409 362 52.9 16 96 0 0 2500 0 0 2951 -668
    1270 ######## 15290 FD66 5 62 4011 6513 22812 -670 57.1 801 0 65535 4832 7334 359 65535 -10 28992 -811 297 766 65408 359 52.9 16 96 0 0 2502 0 0 2951 -671
    1271 ######## 15302 FD65 5 62 4007 6513 22800 -669 57.8 801 0 65535 4828 7334 359 65535 -10 28968 -811 296 765 65409 361 53.1 16 96 0 0 2506 0 0 2951 -670
    1272 ######## 15314 FD67 5 62 4006 6513 22812 -669 57.6 801 0 65535 4826 7334 359 65535 -10 28956 -811 296 765 65409 361 53.2 16 96 0 0 2508 0 0 2951 -669
    1273 ######## 15326 FD62 5 62 4004 6513 22800 -669 58.3 801 0 65535 4825 7334 359 65535 -10 28944 -811 296 764 65409 361 53.3 16 96 0 0 2510 0 0 2951 -667
    1274 ######## 15338 FD68 5 62 4002 6513 22800 -668 58.5 801 0 65535 4823 7334 359 65535 -10 28938 -811 296 764 65409 361 53.3 16 96 0 0 2511 0 0 2951 -673
    1275 ######## 15350 FD67 5 62 4000 6513 22788 -668 58.6 801 0 65535 4821 7334 359 65535 -10 28926 -811 296 764 65409 361 53.4 16 96 0 0 2514 0 0 2951 -667
    1276 ######## 15362 FD68 5 62 3998 6513 22788 -667 59 801 0 65535 4819 7334 360 65535 -10 28914 -811 296 763 65410 363 53.5 16 96 0 0 2516 0 0 2951 -671
    1277 ######## 15374 FD67 5 62 3996 6513 22788 -668 58.7 801 0 65535 4817 7334 359 65535 -10 28902 -811 296 763 65409 360 53.5 16 96 0 0 2517 0 0 2951 -672
    1278 ######## 15386 FD66 5 62 3992 6513 22788 -669 58.2 801 0 65535 4813 7334 358 65535 -10 28878 -811 295 762 65408 357 53.5 16 96 0 0 2521 0 0 2951 -672
    1279 ######## 15399 FD68 5 62 3990 6513 22788 -669 58.4 801 0 65535 4811 7334 358 65535 -10 28866 -811 295 762 65409 360 53.6 16 96 0 0 2523 0 0 2951 -670
    1280 ######## 15411 FD67 5 62 3988 6513 22776 -669 58.6 801 0 65535 4809 7334 358 65535 -10 28854 -811 295 761 65409 360 53.6 16 96 0 0 2525 0 0 2951 -669
    1281 ######## 15423 FD60 5 62 3986 6513 22776 -669 58.6 801 0 65535 4807 7334 357 65535 -10 28842 -811 295 761 65409 360 53.6 16 96 0 0 2527 0 0 2951 -669
    1282 ######## 15435 FD40 5 62 3984 6513 22752 -678 58.5 801 0 65535 4805 7334 351 65535 -10 28830 -811 295 761 65403 343 53.6 16 96 0 0 2529 0 0 2951 -704
    1283 ######## 15447 FD64 5 62 3982 6513 22764 -677 58.8 801 0 65535 4803 7334 353 65535 -10 28818 -811 295 760 65409 359 53.6 16 96 0 0 2531 0 0 2951 -669
    1284 ######## 15459 FD64 5 62 3980 6513 22764 -673 58.2 801 0 65535 4801 7334 355 65535 -10 28806 -811 294 760 65409 359 53.6 16 96 0 0 2533 0 0 2951 -669
    1285 ######## 15471 FD65 5 62 3978 6513 22764 -672 58.8 801 0 65535 4799 7334 356 65535 -10 28794 -811 294 760 65410 362 53.7 16 96 0 0 2535 0 0 2951 -673
    1286 ######## 15483 FD50 5 62 3974 6513 22740 -672 59.7 801 0 65535 4795 7334 355 65535 -10 28770 -811 294 759 65409 359 53.9 16 96 0 0 2539 0 0 2951 -669
    1287 ######## 15495 FD65 5 61 3972 6513 22764 -671 59.9 801 0 65535 4793 7334 355 65535 -10 28758 -811 294 758 65410 361 54.1 16 96 0 0 2541 0 0 2951 -666
    1288 ######## 15507 FD64 5 61 3970 6513 22740 -670 59.8 4801 0 65535 4791 7334 356 65535 -10 28746 -811 294 758 65410 361 54.1 16 96 0 0 2543 0 0 2951 -670
    1289 ######## 15519 FD67 5 61 3968 6513 22740 -669 59.8 4801 0 65535 4789 7334 356 65535 -10 28734 -811 294 758 65409 358 54 16 96 0 0 2545 0 0 2951 -675
    1290 ######## 15531 FD65 5 61 3966 6513 22740 -670 59.7 4801 0 65535 4787 7334 355 65535 -10 28722 -811 293 757 65409 358 54 16 96 0 0 2547 0 0 2951 -673
    1291 ######## 15543 FD66 5 61 3964 6513 22740 -669 59.8 4801 0 65535 4785 7334 355 65535 -10 28710 -811 293 757 65409 358 54 16 96 0 0 2549 0 0 2951 -668
    1292 ######## 15555 FD5E 5 61 3962 6513 22728 -671 60 4801 0 65535 4783 7334 354 65535 -10 28698 -811 293 757 65410 358 54 16 96 0 0 2551 0 0 2951 -668
    1293 ######## 15567 FD65 5 61 3958 6513 22716 -670 60.2 4801 0 65535 4779 7334 354 65535 -10 28674 -811 293 756 65410 360 54 16 96 0 0 2555 0 0 2951 -673
    1294 ######## 15579 FD63 5 61 3957 6513 22716 -670 60.2 4801 0 65535 4777 7334 355 65535 -10 28662 -811 293 755 65410 360 53.9 16 96 0 0 2557 0 0 2951 -667
    1295 ######## 15591 FD64 5 61 3955 6513 22716 -670 60.6 4801 0 65535 4776 7334 354 65535 -10 28650 -811 293 755 65407 351 54 16 96 0 0 2559 0 0 2951 -667
    1296 ######## 15603 FD67 5 61 3953 6513 22716 -669 60.4 4801 0 65535 4774 7334 355 65535 -10 28644 -811 292 755 65410 360 54 16 96 0 0 2561 0 0 2951 -667
    1297 ######## 15615 FD5F 5 61 3951 6513 22704 -670 60.3 4801 0 65535 4772 7334 354 65535 -10 28626 -811 292 754 65407 351 54.1 16 96 0 0 2563 0 0 2951 -667
    1298 ######## 15627 FD66 5 61 3949 6513 22704 -671 59.5 4801 0 65535 4770 7334 354 65535 -10 28620 -811 292 754 65410 359 53.9 16 96 0 0 2564 0 0 2951 -670
    1299 ######## 15639 FD65 5 61 3947 6513 22704 -670 59.6 4801 0 65535 4768 7334 353 65535 -10 28608 -811 292 754 65408 353 54 16 96 0 0 2566 0 0 2951 -675
    1300 ######## 15651 FD67 5 61 3943 6513 22692 -669 59.8 4801 0 65535 4764 7334 354 65535 -10 28584 -811 292 753 65409 356 53.8 16 96 0 0 2570 0 0 2951 -668
    1301 ######## 15664 FD66 5 61 3941 6513 22680 -670 59.6 4801 0 65535 4762 7334 353 65535 -10 28572 -811 292 753 65410 359 53.8 16 96 0 0 2572 0 0 2951 -671
    1302 ######## 15676 FD65 5 61 3939 6513 22680 -669 60 4801 0 65535 4760 7334 353 65535 -10 28560 -811 291 752 65410 358 53.8 16 96 0 0 2574 0 0 2951 -673
    1303 ######## 15688 FD62 5 61 3937 6513 22680 -670 59.4 4801 0 65535 4758 7334 353 65535 -10 28548 -811 291 752 65410 358 53.7 16 96 0 0 2576 0 0 2951 -668
    1304 ######## 15700 FD66 5 61 3935 6513 22680 -669 59.6 4801 0 65535 4756 7334 353 65535 -10 28536 -811 291 751 65410 358 53.7 16 96 0 0 2578 0 0 2951 -674
    1305 ######## 15712 FD63 5 61 3933 6513 22680 -669 59.7 4801 0 65535 4754 7334 352 65535 -10 28524 -811 291 751 65409 355 53.7 16 96 0 0 2580 0 0 2951 -668
    1306 ######## 15724 FD65 5 61 3931 6513 22680 -670 59.9 4801 0 65535 4752 7334 352 65535 -10 28512 -811 291 751 65410 358 53.7 16 96 0 0 2582 0 0 2951 -672
    1307 ######## 15736 FD64 5 61 3927 6513 22668 -669 59.9 4801 0 65535 4748 7334 352 65535 -10 28488 -811 291 750 65410 357 53.8 16 96 0 0 2586 0 0 2951 -672
    1308 ######## 15748 FD64 5 61 3925 6513 22656 -669 59.6 4801 0 65535 4746 7334 352 65535 -10 28476 -811 290 750 65410 357 53.7 16 96 0 0 2588 0 0 2951 -669
    1309 ######## 15760 FD5D 5 61 3923 6513 22644 -670 59.4 4801 0 65535 4744 7334 351 65535 -10 28464 -811 290 749 65410 357 53.6 16 96 0 0 2590 0 0 2951 -670
    1310 ######## 15772 FD68 5 61 3921 6513 22656 -669 60.2 4801 0 65535 4742 7334 352 65535 -10 28452 -811 290 749 65409 354 53.8 16 96 0 0 2592 0 0 2951 -673
    1311 ######## 15784 FD5F 5 61 3920 6513 22656 -670 60.2 4801 0 65535 4741 7334 351 65535 -10 28446 -811 290 749 65410 357 53.8 16 96 0 0 2594 0 0 2951 -670
    1312 ######## 15796 FD67 5 61 3918 6513 22656 -669 59.6 4801 0 65535 4739 7334 351 65535 -10 28434 -811 290 748 65409 353 53.8 16 96 0 0 2596 0 0 2951 -668
    1313 ######## 15808 FD64 5 61 3916 6513 22656 -669 59.1 4801 0 65535 4737 7334 351 65535 -10 28422 -811 290 748 65410 356 53.7 16 96 0 0 2598 0 0 2951 -669
    1314 ######## 15820 FD63 5 61 3912 6513 22644 -670 58.2 4801 0 65535 4733 7334 350 65535 -10 28398 -811 289 747 65410 356 53.4 16 96 0 0 2601 0 0 2951 -668
    1315 ######## 15832 FD63 5 61 3910 6513 22632 -672 57.7 4801 0 65535 4731 7334 349 65535 -10 28386 -811 289 747 65409 353 53.3 16 96 0 0 2603 0 0 2951 -670
    1316 ######## 15844 FD62 5 61 3908 6513 22632 -671 57.7 4801 0 65535 4729 7334 349 65535 -10 28374 -811 289 746 65410 355 53.2 16 96 0 0 2605 0 0 2951 -672
    1317 ######## 15856 FD62 5 60 3906 6513 22632 -671 57.6 4801 0 65535 4727 7334 349 65535 -10 28362 -811 289 746 65410 355 53.2 16 96 0 0 2607 0 0 2951 -668
    1318 ######## 15868 FD63 5 60 3904 6513 22632 -670 57.9 4801 0 65535 4725 7334 350 65535 -10 28350 -811 289 746 65410 355 53.2 16 96 0 0 2609 0 0 2951 -671
    1319 ######## 15880 FD65 5 60 3902 6513 22632 -671 57.8 4801 0 65535 4723 7334 349 65535 -10 28338 -811 289 745 65410 355 53.2 16 96 0 0 2611 0 0 2951 -672
    1320 ######## 15892 FD64 5 60 3900 6513 22620 -671 57.4 4801 0 65535 4721 7334 349 65535 -10 28326 -811 289 745 65410 355 53.1 16 96 0 0 2613 0 0 2951 -669
    1321 ######## 15904 FD61 5 60 3896 6513 22608 -671 56.8 4801 0 65535 4717 7334 348 65535 -10 28302 -811 288 744 65410 354 52.8 16 96 0 0 2617 0 0 2951 -674
    1322 ######## 15916 FD67 5 60 3894 6513 22620 -670 56.9 4801 0 65535 4715 7334 349 65535 -10 28290 -811 288 744 65411 357 52.8 16 96 0 0 2619 0 0 2951 -677
    1323 ######## 15928 FD66 5 60 3892 6513 22608 -670 56.5 4801 0 65535 4713 7334 349 65535 -10 28278 -811 288 743 65409 351 52.6 16 96 0 0 2621 0 0 2951 -669
    1324 ######## 15940 FD64 5 60 3890 6513 22608 -670 56.3 4801 0 65535 4711 7334 348 65535 -10 28266 -811 288 743 65409 351 52.5 16 96 0 0 2623 0 0 2951 -673
    1325 ######## 15952 FD63 5 60 3888 6513 22608 -670 56.2 4801 0 65535 4709 7334 348 65535 -10 28254 -811 288 743 65409 351 52.4 16 96 0 0 2625 0 0 2951 -669
    1326 ######## 15964 FD5E 5 60 3886 6513 22596 -670 56.5 4801 0 65535 4707 7334 348 65535 -10 28242 -811 287 742 65410 353 52.5 16 96 0 0 2627 0 0 2951 -671
    1327 ######## 15976 FD63 5 60 3883 6513 22596 -671 56.5 4801 0 65535 4704 7334 347 65535 -10 28224 -811 287 742 65409 351 52.6 16 96 0 0 2630 0 0 2951 -667
    1328 ######## 15988 FD64 5 60 3881 6513 22596 -670 56.6 4801 0 65535 4702 7334 348 65535 -10 28212 -811 287 741 65410 353 52.6 16 96 0 0 2632 0 0 2951 -673
    1329 ######## 16001 FD63 5 60 3879 6513 22584 -670 56.8 4801 0 65535 4700 7334 347 65535 -10 28200 -811 287 741 65410 353 52.7 16 96 0 0 2634 0 0 2951 -667
    1330 ######## 16013 FD55 5 60 3877 6513 22584 -672 57.4 4801 0 65535 4698 7334 346 65535 -10 28188 -811 287 740 65407 344 52.8 16 96 0 0 2636 0 0 2951 -671
    1331 ######## 16025 FD63 5 60 3875 6513 22584 -671 57.2 4801 0 65535 4696 7334 346 65535 -10 28176 -811 287 740 65410 352 52.8 16 96 0 0 2638 0 0 2951 -667
    1332 ######## 16037 FD62 5 60 3873 6513 22572 -671 56.8 4801 0 65535 4694 7334 346 65535 -10 28164 -811 287 740 65410 352 52.7 16 96 0 0 2640 0 0 2951 -670
    1333 ######## 16049 FD66 5 60 3871 6513 22572 -670 56.8 4801 0 65535 4692 7334 347 65535 -10 28152 -811 286 739 65410 352 52.7 16 96 0 0 2642 0 0 2951 -669
    1334 ######## 16061 FD67 5 60 3867 6513 22560 -670 56.8 4801 0 65535 4688 7334 346 65535 -10 28128 -811 286 739 65411 355 52.6 16 96 0 0 2646 0 0 2951 -674
    1335 ######## 16073 FD58 5 60 3865 6513 22536 -672 56.8 4801 0 65535 4686 7334 345 65535 -10 28116 -811 286 738 65409 349 52.6 16 96 0 0 2648 0 0 2951 -673
    1336 ######## 16085 FD62 5 60 3863 6513 22560 -671 57.1 4801 0 65535 4684 7334 345 65535 -10 28104 -811 286 738 65410 351 52.7 16 96 0 0 2650 0 0 2951 -671
    1337 ######## 16097 FD67 5 60 3861 6513 22560 -670 57 4801 0 65535 4682 7334 346 65535 -10 28092 -811 286 737 65410 351 52.7 16 96 0 0 2652 0 0 2951 -671
    1338 ######## 16109 FD59 5 60 3859 6513 22536 -670 56.8 4801 0 65535 4680 7334 346 65535 -10 28080 -811 285 737 65410 351 52.7 16 96 0 0 2654 0 0 2951 -670
    1339 ######## 16121 FD63 5 60 3857 6513 22548 -669 56.7 4801 0 65535 4678 7334 345 65535 -10 28068 -811 285 737 65410 351 52.6 16 96 0 0 2656 0 0 2951 -675
    1340 ######## 16133 FD67 5 60 3855 6513 22536 -671 56.6 4801 0 65535 4676 7334 345 65535 -10 28056 -811 285 736 65410 350 52.6 16 96 0 0 2658 0 0 2951 -667
    1341 ######## 16145 FD66 5 60 3852 6513 22536 -671 56.5 4801 0 65535 4672 7334 344 65535 -10 28032 -811 285 736 65410 350 52.6 16 96 0 0 2662 0 0 2951 -675
    1342 ######## 16157 FD61 5 60 3850 6513 22536 -670 56.8 4801 0 65535 4671 7334 345 65535 -10 28020 -811 285 735 65411 353 52.5 16 96 0 0 2664 0 0 2951 -672
    1343 ######## 16169 FD68 5 60 3848 6513 22536 -669 56.6 4801 0 65535 4668 7334 345 65535 -10 28008 -811 285 735 65410 350 52.4 16 96 0 0 2666 0 0 2951 -673
    1344 ######## 16181 FD59 5 60 3846 6513 22524 -670 56.3 4801 0 65535 4667 7334 344 65535 -10 28002 -811 285 735 65411 353 52.4 16 96 0 0 2668 0 0 2951 -667
    1345 ######## 16193 FD66 5 60 3844 6513 22536 -669 56.1 4801 0 65535 4665 7334 345 65535 -10 27990 -811 284 734 65411 352 52.3 16 96 0 0 2669 0 0 2951 -675
    1346 ######## 16205 FD68 5 59 3842 6513 22536 -669 56.2 4801 0 65535 4663 7334 345 65535 -10 27978 -811 284 734 65411 352 52.3 16 96 0 0 2671 0 0 2951 -668
    1347 ######## 16217 FD63 5 59 3840 6513 22524 -669 56.1 4801 0 65535 4661 7334 344 65535 -10 27966 -811 284 734 65410 349 52.2 16 96 0 0 2674 0 0 2951 -670
    1348 ######## 16229 FD67 5 59 3838 6513 22524 -669 55.9 4801 0 65535 4659 7334 344 65535 -10 27954 -811 284 733 65410 349 52.1 16 96 0 0 2676 0 0 2951 -672
    1349 ######## 16242 FD65 5 59 3834 6513 22512 -670 55.7 4801 0 65535 4655 7334 343 65535 -10 27930 -811 284 732 65410 349 52.1 16 96 0 0 2679 0 0 2951 -673
    1350 ######## 16254 FD64 5 59 3832 6513 22512 -670 55.6 4801 0 65535 4653 7334 343 65535 -10 27918 -811 284 732 65410 349 52 16 96 0 0 2681 0 0 2951 -668
    1351 ######## 16266 FD5B 5 59 3830 6513 22500 -670 55.6 4801 0 65535 4651 7334 343 65535 -10 27906 -811 283 732 65410 349 52 16 96 0 0 2683 0 0 2951 -669
    1352 ######## 16278 FD63 5 59 3828 6513 22500 -672 55.4 4801 0 65535 4649 7334 342 65535 -10 27894 -811 283 731 65411 351 51.9 16 96 0 0 2685 0 0 2951 -668
    1353 ######## 16290 FD60 5 59 3826 6513 22488 -671 55.7 4801 0 65535 4647 7334 343 65535 -10 27882 -811 283 731 65411 351 52 16 96 0 0 2687 0 0 2951 -671
    1354 ######## 16302 FD64 5 59 3824 6513 22488 -670 55.5 4801 0 65535 4645 7334 342 65535 -10 27870 -811 283 731 65411 351 52 16 96 0 0 2689 0 0 2951 -672
    1355 ######## 16314 FD5F 5 59 3822 6513 22488 -670 55.9 4801 0 65535 4643 7334 342 65535 -10 27858 -811 283 730 65411 350 52 16 96 0 0 2691 0 0 2951 -672
    1356 ######## 16326 FD64 5 59 3818 6513 22464 -670 56.1 4801 0 65535 4639 7334 342 65535 -10 27834 -811 282 729 65410 347 52.1 16 96 0 0 2695 0 0 2951 -672
    1357 ######## 16338 FD63 5 59 3816 6513 22476 -670 56.3 4801 0 65535 4637 7334 342 65535 -10 27822 -811 282 729 65410 347 52.1 16 96 0 0 2697 0 0 2951 -670
    1358 ######## 16350 FD66 5 59 3814 6513 22476 -669 56.3 4801 0 65535 4635 7334 342 65535 -10 27810 -811 282 729 65410 347 52.2 16 96 0 0 2699 0 0 2951 -675
    1359 ######## 16362 FD66 5 59 3812 6513 22464 -669 56.1 4801 0 65535 4633 7334 342 65535 -10 27798 -811 282 728 65410 347 52.2 17 96 0 0 2701 0 0 2951 -672
    1360 ######## 16374 FD63 5 59 3810 6513 22464 -669 56 4801 0 65535 4631 7334 342 65535 -10 27786 -811 282 728 65410 347 52.2 17 96 0 0 2703 0 0 2951 -667
    1361 ######## 16386 FD64 5 59 3809 6513 22464 -671 56 4801 0 65535 4629 7334 341 65535 -10 27774 -811 282 728 65410 347 52.2 17 96 0 0 2705 0 0 2951 -673
    1362 ######## 16398 FD63 5 59 3805 6513 22452 -671 56.2 4801 0 65535 4625 7334 340 65535 -10 27750 -811 281 727 65411 349 52.2 17 96 0 0 2709 0 0 2951 -672
    1363 ######## 16411 FD61 5 59 3803 6513 22452 -671 56.2 4801 0 65535 4624 7334 340 65535 -10 27744 -811 281 726 65411 348 52.2 17 96 0 0 2711 0 0 2951 -668
    1364 ######## 16423 FD60 5 59 3801 6513 22440 -671 56 4801 0 65535 4622 7334 340 65535 -10 27732 -811 281 726 65410 346 52.2 17 96 0 0 2712 0 0 2951 -674
    1365 ######## 16435 FD5C 5 59 3799 6513 22440 -671 56.4 4801 0 65535 4620 7334 340 65535 -10 27720 -811 281 726 65411 348 52.3 17 96 0 0 2714 0 0 2951 -669
    1366 ######## 16447 FD63 5 59 3797 6513 22440 -671 56.3 4801 0 65535 4618 7334 340 65535 -10 27708 -811 281 725 65411 348 52.3 17 96 0 0 2717 0 0 2951 -670
    1367 ######## 16459 FD65 5 59 3795 6513 22428 -671 56.2 4801 0 65535 4616 7334 339 65535 -10 27696 -811 281 725 65411 348 52.2 17 96 0 0 2718 0 0 2951 -674
    1368 ######## 16471 FD63 5 59 3793 6513 22428 -671 56.2 4801 0 65535 4614 7334 339 65535 -10 27684 -811 281 725 65410 345 52.2 17 96 0 0 2720 0 0 2951 -669
    1369 ######## 16483 FD64 5 59 3791 6513 22428 -671 56.1 4801 0 65535 4612 7334 339 65535 -10 27672 -811 280 724 65409 342 52.2 17 96 0 0 2722 0 0 2951 -675
    1370 ######## 16495 FD5F 5 59 3787 6513 22416 -671 56.6 4801 0 65535 4608 7334 339 65535 -10 27648 -811 280 724 65411 348 52.4 17 96 0 0 2726 0 0 2951 -673
    1371 ######## 16507 FD66 5 59 3785 6513 22404 -670 56.7 4801 0 65535 4606 7334 339 65535 -10 27636 -811 280 723 65411 347 52.5 17 96 0 0 2728 0 0 2951 -674
    1372 ######## 16519 FD65 5 59 3783 6513 22404 -671 57.3 4801 0 65535 4604 7334 338 65535 -10 27624 -811 280 723 65411 347 52.7 17 96 0 0 2730 0 0 2951 -671
    1373 ######## 16531 FD66 5 59 3781 6513 22392 -670 58 4801 0 65535 4602 7334 339 65535 -10 27612 -811 280 722 65410 344 52.8 17 96 0 0 2732 0 0 2951 -674
    1374 ######## 16543 FD65 5 59 3779 6513 22380 -672 57.9 4801 0 65535 4600 7334 337 65535 -10 27600 -811 280 722 65411 347 52.8 17 96 0 0 2734 0 0 2951 -672
    1375 ######## 16555 FD66 5 58 3777 6513 22380 -671 57.8 4801 0 65535 4598 7334 338 65535 -10 27588 -811 279 722 65410 344 52.8 17 96 0 0 2736 0 0 2951 -675
    1376 ######## 16567 FD62 5 58 3774 6513 22380 -670 58.1 4801 0 65535 4595 7334 338 65535 -10 27564 -811 279 721 65410 343 52.9 17 96 0 0 2740 0 0 2951 -667
    1377 ######## 16579 FD63 5 58 3772 6513 22368 -670 58.4 4801 0 65535 4592 7334 338 65535 -10 27552 -811 279 721 65411 346 52.9 17 96 0 0 2742 0 0 2951 -668
    1378 ######## 16591 FD5B 5 58 3770 6513 22344 -671 58.7 4801 0 65535 4590 7334 337 65535 -10 27540 -811 279 720 65412 348 53 17 96 0 0 2744 0 0 2951 -670
    1379 ######## 16603 FD64 5 58 3768 6513 22356 -670 58.5 4801 0 65535 4589 7334 337 65535 -10 27534 -811 279 720 65412 348 53 17 96 0 0 2746 0 0 2951 -674
    1380 ######## 16615 FD64 5 58 3766 6513 22344 -670 59.2 4801 0 65535 4587 7334 337 65535 -10 27522 -811 279 720 65412 348 53.1 17 96 0 0 2747 0 0 2951 -670
    1381 ######## 16627 FD66 5 58 3764 6513 22344 -670 59.3 4801 0 65535 4585 7334 337 65535 -10 27504 -811 278 719 65411 345 53.2 17 96 0 0 2750 0 0 2951 -674
    1382 ######## 16639 FD66 5 58 3762 6513 22344 -671 58.7 4801 0 65535 4583 7334 336 65535 -10 27498 -811 278 719 65412 348 53.2 17 96 0 0 2751 0 0 2951 -674
    1383 ######## 16651 FD67 5 58 3758 6513 22344 -670 59.2 4801 0 65535 4579 7334 337 65535 -10 27474 -811 278 718 65411 345 53.2 17 96 0 0 2755 0 0 2951 -672
    1384 ######## 16663 FD63 5 58 3756 6513 22332 -670 59 4801 0 65535 4577 7334 336 65535 -10 27462 -811 278 718 65411 345 53.2 17 96 0 0 2757 0 0 2951 -666
    1385 ######## 16675 FD64 5 58 3754 6513 22320 -670 58.7 4801 0 65535 4575 7334 336 65535 -10 27450 -811 278 717 65411 344 53.2 17 96 0 0 2759 0 0 2951 -685
    1386 ######## 16687 FD65 5 58 3752 6513 22320 -671 58.8 4801 0 65535 4573 7334 335 65535 -10 27438 -811 278 717 65411 344 53.2 17 96 0 0 2761 0 0 2951 -672
    1387 ######## 16699 FD60 5 58 3750 6513 22320 -672 58.8 4801 0 65535 4571 7334 335 65535 -10 27426 -811 277 717 65411 344 53.1 17 96 0 0 2763 0 0 2951 -674
    1388 ######## 16711 FD66 5 58 3748 6513 22320 -671 58.8 4801 0 65535 4569 7334 335 65535 -10 27414 -811 277 716 65411 344 53.1 17 96 0 0 2765 0 0 2951 -669
    1389 ######## 16723 FD61 5 58 3746 6513 22308 -670 59.2 4801 0 65535 4567 7334 335 65535 -10 27402 -811 277 716 65412 346 53.1 17 96 0 0 2767 0 0 2951 -670
    1390 ######## 16735 FD67 5 58 3742 6513 22296 -669 59.3 4801 0 65535 4563 7334 336 65535 -10 27378 -811 277 715 65412 346 53.1 17 96 0 0 2771 0 0 2951 -668
    1391 ######## 16747 FD63 5 58 3740 6513 22296 -669 59.4 4801 0 65535 4561 7334 335 65535 -10 27366 -811 277 715 65412 346 53.3 17 96 0 0 2773 0 0 2951 -669
    1392 ######## 16759 FD62 5 58 3739 6513 22284 -670 59.8 4801 0 65535 4559 7334 335 65535 -10 27354 -811 277 714 65412 345 53.5 17 96 0 0 2775 0 0 2951 -669
    1393 ######## 16771 FD64 5 58 3736 6513 22284 -670 59.7 4801 0 65535 4557 7334 335 65535 -10 27342 -811 276 714 65412 345 53.4 17 96 0 0 2777 0 0 2951 -667
    1394 ######## 16783 FD66 5 58 3734 6513 22272 -669 60.1 4801 0 65535 4555 7334 335 65535 -10 27330 -811 276 714 65413 348 53.5 17 96 0 0 2779 0 0 2951 -669
    1395 ######## 16795 FD5C 5 58 3733 6513 22272 -670 60.3 4801 0 65535 4554 7334 334 65535 -10 27324 -811 276 714 65412 345 53.6 17 96 0 0 2781 0 0 2951 -672
    1396 ######## 16807 FD67 5 58 3731 6513 22272 -670 60.2 4801 0 65535 4552 7334 334 65535 -10 27312 -811 276 713 65412 345 53.7 17 96 0 0 2782 0 0 2951 -668
    1397 ######## 16819 FD68 5 58 3729 6513 22272 -670 60.2 4801 0 65535 4550 7334 334 65535 -10 27300 -811 276 713 65412 345 53.6 17 96 0 0 2784 0 0 2951 -670
    1398 ######## 16831 FD64 5 58 3725 6513 22248 -670 59.8 4801 0 65535 4546 7334 334 65535 -10 27276 -811 276 712 65412 345 53.7 17 96 0 0 2788 0 0 2951 -671
    1399 ######## 16843 FD57 5 58 3723 6513 22236 -670 59.3 4801 0 65535 4544 7334 333 65535 -10 27264 -811 275 712 65411 342 53.6 17 96 0 0 2790 0 0 2951 -669
    1400 ######## 16855 FD64 5 58 3721 6513 22248 -670 59.3 4801 0 65535 4542 7334 333 65535 -10 27252 -811 275 711 65411 341 53.4 17 96 0 0 2792 0 0 2951 -673
    1401 ######## 16867 FD64 5 58 3719 6513 22236 -670 59.9 4801 0 65535 4540 7334 333 65535 -10 27240 -811 275 711 65412 344 53.5 17 96 0 0 2794 0 0 2951 -670
    1402 ######## 16879 FD63 5 58 3717 6513 22224 -670 60 4801 0 65535 4538 7334 333 65535 -10 27228 -811 275 711 65411 341 53.5 17 96 0 0 2796 0 0 2951 -669
    1403 ######## 16892 FD62 5 58 3715 6513 22224 -670 59.5 4801 0 65535 4536 7334 333 65535 -10 27216 -811 275 710 65412 344 53.5 17 96 0 0 2798 0 0 2951 -668
    1404 ######## 16904 FD61 5 58 3713 6513 22224 -669 59.4 4801 0 65535 4534 7334 333 65535 -10 27204 -811 275 710 65412 344 53.6 17 96 0 0 2800 0 0 2951 -668
    1405 ######## 16916 FD69 5 57 3709 6513 22212 -668 60.5 4801 0 65535 4530 7334 333 65535 -10 27180 -811 274 709 65412 343 54 17 96 0 0 2804 0 0 2951 -669
    1406 ######## 16928 FD66 5 57 3707 6513 22200 -668 60.6 4801 0 65535 4528 7334 333 65535 -10 27168 -811 274 709 65412 343 54 17 96 0 0 2806 0 0 2951 -672
    1407 ######## 16940 FD63 5 57 3705 6513 22200 -669 61.1 4801 0 65535 4526 7334 332 65535 -10 27156 -811 274 708 65411 340 54.1 17 96 0 0 2808 0 0 2951 -671
    1408 ######## 16952 FD61 5 57 3703 6513 22200 -669 60.7 4801 0 65535 4524 7334 332 65535 -10 27144 -811 274 708 65411 340 54.1 17 96 0 0 2810 0 0 2951 -670
    1409 ######## 16964 FD65 5 57 3701 6513 22188 -670 60 4801 0 65535 4522 7334 331 65535 -10 27132 -811 274 708 65412 343 54 17 96 0 0 2812 0 0 2951 -669
    1410 ######## 16976 FD61 5 57 3699 6513 22176 -669 60 4801 0 65535 4520 7334 332 65535 -10 27120 -811 274 707 65412 342 53.9 17 96 0 0 2814 0 0 2951 -690
    1411 ######## 16988 FD63 5 57 3697 6513 22176 -670 59.9 4801 0 65535 4518 7334 331 65535 -10 27108 -811 274 707 65412 342 53.9 17 96 0 0 2816 0 0 2951 -673
    1412 ######## 17000 FD5C 5 57 3695 6513 22164 -671 59.4 4801 0 65535 4516 7334 330 65535 -10 27096 -811 273 707 65413 345 53.9 17 96 0 0 2818 0 0 2951 -668
    1413 ######## 17012 FD65 5 57 3691 6513 22152 -670 59.6 4801 0 65535 4512 7334 331 65535 -10 27072 -811 273 706 65413 344 53.8 17 96 0 0 2822 0 0 2951 -667
    1414 ######## 17024 FD61 5 57 3690 6513 22152 -670 59.7 4801 0 65535 4510 7334 330 65535 -10 27060 -811 273 705 65413 344 53.7 17 96 0 0 2824 0 0 2951 -670
    1415 ######## 17036 FD65 5 57 3688 6513 22140 -669 59.4 4801 0 65535 4509 7334 331 65535 -10 27054 -811 273 705 65413 344 53.7 17 96 0 0 2826 0 0 2951 -673
    1416 ######## 17048 FD64 5 57 3686 6513 22140 -669 59.7 4801 0 65535 4507 7334 331 65535 -10 27042 -811 273 705 65413 344 53.7 17 96 0 0 2828 0 0 2951 -669
    1417 ######## 17060 FD64 5 57 3684 6513 22140 -669 59.8 4801 0 65535 4505 7334 330 65535 -10 27030 -811 273 704 65412 341 53.7 17 96 0 0 2829 0 0 2951 -672
    1418 ######## 17072 FD66 5 57 3682 6513 22128 -669 59.9 4801 0 65535 4503 7334 330 65535 -10 27018 -811 272 704 65413 343 53.7 17 96 0 0 2831 0 0 2951 -668
    1419 ######## 17084 FD62 5 57 3678 6513 22116 -669 59.7 4801 0 65535 4499 7334 330 65535 -10 26994 -811 272 703 65413 343 53.8 17 96 0 0 2835 0 0 2951 -671
    1420 ######## 17096 FD66 5 57 3676 6513 22104 -670 60.2 4801 0 65535 4497 7334 329 65535 -10 26982 -811 272 703 65413 343 53.9 17 96 0 0 2837 0 0 2951 -669
    1421 ######## 17108 FD63 5 57 3674 6513 22104 -670 59.8 4801 0 65535 4495 7334 330 65535 -10 26970 -811 272 703 65413 343 53.8 17 96 0 0 2839 0 0 2951 -668
    1422 ######## 17120 FD64 5 57 3672 6513 22104 -670 59.6 4801 0 65535 4493 7334 329 65535 -10 26958 -811 272 702 65413 342 53.7 17 96 0 0 2841 0 0 2951 -667
    1423 ######## 17132 FD63 5 57 3670 6513 22092 -670 60.1 4801 0 65535 4491 7334 329 65535 -10 26946 -811 272 702 65413 342 53.7 17 96 0 0 2843 0 0 2951 -670
    1424 ######## 17144 FD5F 5 57 3668 6513 22080 -670 60.2 4801 0 65535 4489 7334 328 65535 -10 26934 -811 271 702 65413 342 53.8 17 96 0 0 2845 0 0 2951 -667
    1425 ######## 17156 FD63 5 57 3666 6513 22068 -670 59.8 4801 0 65535 4487 7334 328 65535 -10 26922 -811 271 701 65413 342 53.7 17 96 0 0 2847 0 0 2951 -673
    1426 ######## 17168 FD62 5 57 3662 6513 22068 -670 60.1 4801 0 65535 4483 7334 328 65535 -10 26898 -811 271 700 65413 341 53.8 17 96 0 0 2851 0 0 2951 -667
    1427 ######## 17180 FD67 5 57 3660 6513 22056 -669 60 4801 0 65535 4481 7334 328 65535 -10 26886 -811 271 700 65413 341 53.8 17 96 0 0 2853 0 0 2951 -670
    1428 ######## 17192 FD60 5 57 3659 6513 22044 -671 60.2 4801 0 65535 4480 7334 327 65535 -10 26874 -811 271 700 65413 341 53.9 17 96 0 0 2855 0 0 2951 -667
    1429 ######## 17205 FD66 5 57 3656 6513 22032 -670 60 4801 0 65535 4477 7334 327 65535 -10 26862 -811 270 699 65413 341 53.8 17 96 0 0 2857 0 0 2951 -670
    1430 ######## 17217 FD66 5 57 3655 6513 22044 -669 60.7 4801 0 65535 4475 7334 328 65535 -10 26850 -811 270 699 65413 341 53.9 17 96 0 0 2859 0 0 2951 -668
    1431 ######## 17229 FD63 5 57 3653 6513 22020 -670 60.2 4801 0 65535 4474 7334 327 65535 -10 26844 -811 270 699 65411 336 53.8 17 96 0 0 2861 0 0 2951 -682
    1432 ######## 17241 FD61 5 57 3651 6513 22020 -671 59.6 4801 0 65535 4472 7334 326 65535 -10 26832 -811 270 698 65413 340 53.8 17 96 0 0 2862 0 0 2951 -677
    1433 ######## 17253 FD64 5 56 3647 6513 22008 -671 60 4801 0 65535 4468 7334 326 65535 -10 26808 -811 270 698 65413 340 53.9 17 96 0 0 2866 0 0 2951 -668
    1434 ######## 17265 FD67 5 56 3645 6513 21996 -671 60.2 4801 0 65535 4466 7334 326 65535 -10 26796 -811 270 697 65413 340 53.9 17 96 0 0 2868 0 0 2951 -673
    1435 ######## 17277 FD4E 5 56 3643 6513 21972 -675 60.4 4801 0 65535 4464 7334 324 65535 -10 26784 -811 270 697 65413 340 54 17 96 0 0 2871 0 0 2951 -672
    1436 ######## 17289 FD63 5 56 3641 6513 21984 -672 60.6 4801 0 65535 4462 7334 325 65535 -10 26772 -811 269 697 65413 340 54 17 96 0 0 2872 0 0 2951 -669
    1437 ######## 17301 FD61 5 56 3639 6513 21972 -672 60.5 4801 0 65535 4460 7334 325 65535 -10 26760 -811 269 696 65413 340 54.1 17 96 0 0 2874 0 0 2951 -671
    1438 ######## 17313 FD65 5 56 3637 6513 21960 -671 60.4 4801 0 65535 4458 7334 325 65535 -10 26748 -811 269 696 65414 342 54.1 17 96 0 0 2876 0 0 2951 -669
    1439 ######## 17325 FD61 5 56 3635 6513 21960 -670 60.1 4801 0 65535 4456 7334 326 65535 -10 26736 -811 269 695 65413 339 54 17 96 0 0 2878 0 0 2951 -670
    1440 ######## 17337 FD62 5 56 3633 6513 21948 -670 60.3 4801 0 65535 4454 7334 325 65535 -10 26724 -811 269 695 65413 339 54 17 96 0 0 2880 0 0 2951 -669
    1441 ######## 17349 FD61 5 56 3629 6513 21936 -671 60.3 4801 0 65535 4450 7334 325 65535 -10 26700 -811 268 694 65413 339 54 17 96 0 0 2884 0 0 2951 -676
    1442 ######## 17361 FD62 5 56 3627 6513 21924 -672 60.7 4801 0 65535 4448 7334 324 65535 -10 26688 -811 268 694 65414 341 54.1 17 96 0 0 2886 0 0 2951 -672
    1443 ######## 17373 FD63 5 56 3625 6513 21912 -672 61 4801 0 65535 4446 7334 324 65535 -10 26676 -811 268 694 65413 339 54.2 17 96 0 0 2888 0 0 2951 -671
    1444 ######## 17385 FD62 5 56 3623 6513 21912 -671 61.1 4801 0 65535 4444 7334 324 65535 -10 26664 -811 268 693 65414 341 54.2 17 96 0 0 2890 0 0 2951 -669
    1445 ######## 17397 FD64 5 56 3621 6513 21900 -670 60.5 4801 0 65535 4442 7334 324 65535 -10 26652 -811 268 693 65414 341 54 17 96 0 0 2892 0 0 2951 -669
    1446 ######## 17409 FD5F 5 56 3619 6513 21888 -670 60.9 4801 0 65535 4440 7334 324 65535 -10 26640 -811 268 693 65414 341 54.1 17 96 0 0 2894 0 0 2951 -669
    1447 ######## 17421 FD52 5 56 3617 6513 21876 -672 61 4801 0 65535 4438 7334 323 65535 -10 26628 -811 268 692 65413 338 54.1 17 96 0 0 2896 0 0 2951 -676
    1448 ######## 17433 FD62 5 56 3613 6513 21864 -671 61.2 4801 0 65535 4434 7334 323 65535 -10 26604 -811 267 691 65414 340 54.4 17 96 0 0 2900 0 0 2951 -675
    1449 ######## 17445 FD62 5 56 3612 6513 21852 -671 61.1 4801 0 65535 4433 7334 323 65535 -10 26592 -811 267 691 65414 340 54.3 17 96 0 0 2902 0 0 2951 -668
    1450 ######## 17457 FD65 5 56 3610 6513 21840 -670 61.1 4801 0 65535 4430 7334 323 65535 -10 26580 -811 267 691 65414 340 54.3 17 96 0 0 2904 0 0 2951 -668
    1451 ######## 17469 FD66 5 56 3608 6513 21828 -671 60.4 4801 0 65535 4428 7334 323 65535 -10 26568 -811 267 690 65414 339 54.3 17 96 0 0 2906 0 0 2951 -672
    1452 ######## 17481 FD60 5 56 3606 6513 21804 -671 61.5 4801 0 65535 4427 7334 322 65535 -10 26562 -811 267 690 65414 339 54.5 17 96 0 0 2908 0 0 2951 -673
    1453 ######## 17493 FD66 5 56 3604 6513 21804 -670 60.7 4801 0 65535 4425 7334 323 65535 -10 26550 -811 267 690 65414 339 54.5 17 96 0 0 2909 0 0 2951 -672
    1454 ######## 17505 FD66 5 56 3600 6513 21780 -671 59.6 4801 0 65535 4421 7334 322 65535 -10 26526 -811 266 689 65413 336 54.2 17 96 0 0 2913 0 0 2951 -676
    1455 ######## 17517 FD66 5 56 3598 6513 21756 -671 59.8 4801 0 65535 4419 7334 322 65535 -10 26514 -811 266 689 65415 342 54.2 17 96 0 0 2915 0 0 2951 -668
    1456 ######## 17529 FD60 5 56 3596 6513 21744 -672 59.8 4801 0 65535 4417 7334 321 65535 -10 26502 -811 266 688 65414 338 54.3 17 96 0 0 2917 0 0 2951 -674
    1457 ######## 17541 FD65 5 56 3594 6513 21744 -671 59.9 4801 0 65535 4415 7334 321 65535 -10 26490 -811 266 688 65414 338 54.3 17 96 0 0 2919 0 0 2951 -670
    1458 ######## 17553 FD60 5 56 3592 6513 21720 -671 60.3 4801 0 65535 4413 7334 321 65535 -10 26478 -811 266 688 65414 338 54.3 17 96 0 0 2921 0 0 2951 -671
    1459 ######## 17565 FD63 5 56 3590 6513 21708 -670 61 4801 0 65535 4411 7334 321 65535 -10 26466 -811 266 687 65415 341 54.4 17 96 0 0 2923 0 0 2951 -670
    1460 ######## 17577 FD65 5 56 3588 6513 21696 -670 60.7 4801 0 65535 4409 7334 321 65535 -10 26454 -811 265 687 65415 341 54.4 17 96 0 0 2925 0 0 2951 -684
    1461 ######## 17590 FD64 5 56 3584 6513 21672 -672 60.1 4801 0 65535 4405 7334 320 65535 -10 26430 -811 265 686 65415 340 54.4 17 96 0 0 2929 0 0 2951 -675
    1462 ######## 17602 FD64 5 55 3582 6513 21648 -672 60.9 4801 0 65535 4403 7334 320 65535 -10 26418 -811 265 686 65415 340 54.4 17 96 0 0 2931 0 0 2951 -669
    1463 ######## 17614 FD66 5 55 3580 6513 21636 -671 61.1 4801 0 65535 4401 7334 320 65535 -10 26406 -811 265 685 65416 343 54.4 17 96 0 0 2933 0 0 2951 -677
    1464 ######## 17626 FD5C 5 0 0 2934 21600 -671 61.1 4807 0 65535 4400 7334 0 65535 -10 26400 -811 0 0 65415 0 54.4 17 96 0 0 2935 0 0 2951 -676
    1465 ######## 17638 FD64 5 0 0 2934 21600 -672 61.1 5807 0 65535 4400 7334 0 65535 -10 26400 -811 0 0 65415 0 54.5 17 96 0 0 2937 0 0 2951 -673
    1466 ######## 17650 FD5F 5 0 0 2938 21576 -672 61.7 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65416 0 54.6 17 96 0 0 2939 0 0 2951 -676
    1467 ######## 17662 FD65 5 0 0 2938 21540 -670 61.8 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65416 0 54.7 17 96 0 0 2942 0 0 2951 -672
    1468 ######## 17674 FD3F 5 0 0 2938 21468 -677 62 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65411 0 54.8 17 96 0 0 2944 0 0 2951 -700
    1469 ######## 17686 FD65 5 0 0 2938 21492 -679 61 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65416 0 54.7 17 96 0 0 2946 0 0 2951 -672
    1470 ######## 17698 FD60 5 0 0 2938 21432 -677 60.7 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65415 0 54.6 17 96 0 0 2948 0 0 2951 -679
    1471 ######## 17710 FD64 5 0 0 2938 21432 -674 60.1 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65416 0 54.5 17 96 0 0 2950 0 0 2951 -672
    1472 ######## 17722 FD61 5 0 0 2938 21408 -673 59.7 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65417 0 54.4 17 96 0 0 2952 0 0 2951 -667
    1473 ######## 17734 FD62 5 0 0 2938 21372 -671 59.7 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65416 0 54.3 17 96 0 0 2954 0 0 2951 -679
    1474 ######## 17746 FD65 5 0 0 2938 21312 -671 59.6 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65417 0 54.3 17 96 0 0 2958 0 0 2951 -669
    1475 ######## 17758 FD60 5 0 0 2938 21264 -671 59.6 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65417 0 54.3 17 96 0 0 2960 0 0 2951 -670
    1476 ######## 17770 FD5E 5 0 0 2938 21216 -671 59.8 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65418 0 54.3 17 96 0 0 2962 0 0 2951 -668
    1477 ######## 17782 FD61 5 0 0 2938 21156 -674 59 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65418 0 54.1 17 96 0 0 2964 0 0 2951 -670
    1478 ######## 17794 FD60 5 0 0 2938 21132 -672 58.7 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65418 0 54 17 96 0 0 2966 0 0 2951 -671
    1479 ######## 17806 FD65 5 0 0 2938 21084 -671 59.2 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65418 0 54.1 17 96 0 0 2968 0 0 2951 -667
    1480 ######## 17818 FD62 5 0 0 2938 21048 -669 59.4 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65418 0 54.2 17 96 0 0 2970 0 0 2951 -670
    1481 ######## 17830 FD65 5 0 0 2938 21000 -669 59.6 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65420 0 54.2 17 96 0 0 2972 0 0 2951 -677
    1482 ######## 17842 FD67 5 0 0 2938 20892 -670 59.8 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65420 0 54.3 17 96 0 0 2976 0 0 2951 -670
    1483 ######## 17854 FD66 5 0 0 2938 20832 -669 59.5 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65420 0 54.3 17 96 0 0 2978 0 0 2951 -669
    1484 ######## 17867 FD65 5 0 0 2938 20784 -669 59.9 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65420 0 54.3 17 96 0 0 2980 0 0 2951 -668
    1485 ######## 17879 FD5C 5 0 0 2938 20688 -671 59.4 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65421 0 54.3 17 96 0 0 2982 0 0 2951 -667
    1486 ######## 17891 FD62 5 0 0 2938 20664 -670 59.6 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65421 0 54.2 17 96 0 0 2984 0 0 2951 -669
    1487 ######## 17903 FD64 5 0 0 2938 20616 -670 59.9 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65421 0 54.3 17 96 0 0 2986 0 0 2951 -670
    1488 ######## 17915 FD65 5 0 0 2938 20568 -670 59.9 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65421 0 54.3 17 96 0 0 2988 0 0 2951 -669
    1489 ######## 17927 FD65 5 0 0 2938 20448 -669 60 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65422 0 54.4 17 96 0 0 2991 0 0 2951 -665
    1490 ######## 17939 FD68 5 0 0 2938 20388 -668 60 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65422 0 54.4 17 96 0 0 2993 0 0 2951 -670
    1491 ######## 17951 FD60 5 0 0 2938 20328 -669 59.7 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65423 0 54.3 17 96 0 0 2995 0 0 2951 -667
    1492 ######## 17963 FD62 5 0 0 2938 20244 -669 59.7 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65423 0 54.3 17 96 0 0 2997 0 0 2951 -669
    1493 ######## 17975 FD64 5 0 0 2938 20208 -669 59.7 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65424 0 54.3 17 96 0 0 2999 0 0 2951 -671
    1494 ######## 17987 FD63 5 0 0 2938 20148 -670 59.8 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65423 0 54.5 17 96 0 0 3001 0 0 2951 -673
    1495 ######## 17999 FD62 5 0 0 2938 20052 -670 60.1 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65424 0 54.6 17 96 0 0 3003 0 0 2951 -667
    1496 ######## 18011 FD45 5 0 0 2938 19872 -673 61.2 5807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 65422 0 54.7 17 96 0 0 3007 0 0 2951 -689
    1497 ######## 18023 7 5 0 0 2938 22248 -491 61.7 4807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 1 65535 55 17 96 0 0 3008 0 0 2951 7
    1498 ######## 18035 7 5 0 0 2938 22560 -227 61.5 4807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 1 65535 55.1 17 96 0 0 3008 0 0 2951 7
    1499 ######## 18047 7 5 0 0 2938 22704 -82 61.3 4807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 1 65535 54.9 17 96 0 0 3008 0 0 2951 7
    1500 ######## 18059 7 5 0 0 2938 22764 -38 60.4 4807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 1 65535 54.4 17 96 0 0 3008 0 0 2951 7
    1501 ######## 18071 7 5 0 0 2938 22800 -16 59.5 4807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 1 65535 53.9 17 96 0 0 3008 0 0 2951 7
    1502 ######## 18083 7 5 0 0 2938 22836 -5 58.2 4807 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 1 65535 53.1 17 96 0 0 3008 0 0 2951 6
    1503 ######## 18095 6 805 0 0 2938 22872 1 56.7 C806 0 65535 4344 7282 0 65535 -10 26064 -811 0 0 1 65535 52.3 17 96 0 0 3008 0 0 2951 6
    1504 ######## 18107 6 5 0 0 2938 22908 3 55.5 C806 0 65535 4344 7282 65535 45120 -10 26064 -811 0 0 1 65535 51.6 17 96 0 0 3008 0 0 2951 6
    1505 ######## 18119 6 5 0 0 2938 22956 5 53 8806 0 65535 4344 7282 65535 36096 -10 26064 -811 0 0 1 65535 50.1 17 96 28200 2250 3008 0 0 2951 6
  • Hello Chien,
    It looks like when your SOC1 and SOCF flags are being set is when the SOC drops, I believe your terminate voltage is set too high, your voltage hits terminate voltage and forces RemCap to 0, setting the SOC1 and SOCF flags.
    Sincerely,
    Wyatt Keller
  • Hello Wyatt Keller,
    Thanks for your help, i already have my problem fix plan, i need more time to observe. I want to ask you one more problem is that the BQ34z110 can over-compute the battery life? If my PIN has been used for a long time, the capacity will be lower than before, and will the calculation of the BQ34z110 be affected?
    Trinh Minh Chien
    Roland Melad
  • Hello Chien,
    Are you referencing a pin on the bq34z110 you are using? The gauge will account for leakage current using periodic updates in relax mode.
    Sincerely,
    Wyatt Keller
    Yes, Im referencing a pin on the bq34z110. So do I need to keep the power supply for BQ34 ?
    Trinh Minh Chien
  • Hello Chien,
    I'm not sure which pin you are referencing, there's no pin defined as PIN. It depends on your application, the gauge has low power modes it can be put into instead of cutting power.
    Sincerely,
    Wyatt Keller
    Thanks for your support, I will test BQ34 even more.
    Trinh Minh Chien
