TPS745: How to connect an unused PG pin?
Part Number: TPS745
Hello team,
If the PGOOD pin is not being used externally, can it be left floating or tied to ground, or does the IC use the voltage on the PG pin to change some other functional setting, and thus need to be pulled up to an external supply voltage through a resistance?
