Could you please let me know about "Force Disabled by default?" and "Mask CTL/PG by default?" in Sequencing tab in TPS65086100 OTP Generator?
- Force Disabled by default? ( Default = Yes) : If this setting is Yes, will VR not work after POR?
- Mask CTL/PG by default? (Default = No) : The comment shows below:
Masking the CTL/PG by default will cause the rail to be always on unless force disabled by default. | ||||||||
What is this mean? does VR always on and cannot control sequence by PG or CTL pin if the setting is Yes?
Nagata.
