Our application has a removable battery. We have 0 ohm connected to TTC (disable safety timer and charge termination -- our MCU is controlling charge termination).
The steps are:
- Power up BQ24172 with no battery connected.
- STAT is blinking.
- Install depleted battery.
- STAT goes low (charging).
- Remove battery.
- STAT stays low.
This does not seem to match the documented function for STAT pin (DS pg. 5 -- STAT pin: "Blinking at 0.5 Hz when fault occurs,
including charge suspend, input overvoltage, timer fault and battery absent.")
The only way to get the STAT pin to blink again seems to be to remove power from the BQ24172 or toggle ISET low/release.
Can you confirm this behavior?
Jackson
