Hi
Please help let me know the following questions
1. Is the execution method of PWM as described in "Figure 13. PWM Operation", If yes, what is the highest refresh rate?
2. Please provide information about Command (12bits)? Is it a fixed 3AAh? If so? Is it impossible to adjust the current gain of the driver by software?
3. What is the correspondence between data transmitted via SDI and Gray Scale (36bit)? Do you refer to "Figure 21. Common Shift Register and Control Data Latches Configuration"?
Thank
