Hello TI,
Since, Online parameters search does not support this temp range. Please share a list of parts supporting fly-buck topology targeting less than 2W DC-DC converter with multiple isolated outputs. Input could be 7 to more than 50V DC
Hello TI,
Hello
Most of our devices will specify a junction temperature range, rather than an ambient temperature range.
The junction temperature will depend on the ambient temperature and the power loss in the device.
I don't believe that we have many devices with a -55C lower limit for junction temperature. However we
do have devices with an upper limit of 150C for junction temperature. You will need to search for a device with
a junction temperature of 150C; that might meet your needs.
Thanks Dear,
Appreciate the prompt support.
To achieve operating temp range -55 to 135 deg C, would you recommend ambient measures, like Potting (material?) or other means !
Target product dimension is supposed to be within 20mm radius and 10mm height
Hello
It would be best if you could relax you ambient to something like -40C to 85C or 105C or at most 125C.
I am not sure what the best way to do that is for your specific case.
