Part Number: LMZ34202
Other Parts Discussed in Thread: LMZ31704
Hi Experts,
My customer want to use buck module to step 15V input down to 5V output. The problem is there is >2200uF of capacitance on 5V rail, however all our buck module specified a max limitation on output capacitance. I am wondered is there any solution making our module can work with higher load capacitance? I noted some of module has adjustable soft-start time, i am wondered if we can implement higher output capacitance through setting longer soft-start time?
Thank you!
John
