BQ25155: JEITA operation by measuring battery temperature via ADCIN
Part Number: BQ25155
Our customer is planning to use 104 thermistor for measuring the battery temperature and control JEITA operation. Although temperature measurement via TS is able to JEITA control COLD/COOL/WARM/HOT, could you please help him if temperature measurement via ADCIN is able to do same JEITA control with TS measurement.
  • Hello Toshiro-San,
    The ADCIN pin can measure the voltage on the thermistor. however, no action will be taken by the device with this information. You can use the 3 comparators on the device to send interrupts to the MCU whenever any threshold is crossed. The TS pin is the best option for full JEITA control.
