I need to design with TPS659037. Do you have a design tool to help me design with TPS659037 to provide voltages and currents I need?
Thank you
Thank you
Ramin,
Hi, the TPS659037 has fixed default voltages and power up sequences to power the AM57x Sitara processors. The default settings can be found in this user's guide: https://www.ti.com/lit/pdf/sliu011
This device is one-time programmable (OTP) so you cannot change these default voltages after they are programmed in the TI factory. You can change the voltage levels through I2C after start up if it is okay in you system to startup with the provided defaults.
Nastasha
