Part Number: BQ78350-R2-DEVICE-FW
Hi team,
I’m working on BQ78350 battery fuel (gas) gauges product. I was writing a .srec file to “BQ78350-R2” IC with using “bqStudio” and then i read the .srec file from the same IC with the “bqStudio”.
After I opened read and written .srec files with notepad but .srec files are different from each other. They are similar but not completely the same.
- Is this an expected situation ? If yes, what are the meanings of these different bytes ? If it's not, what causes the problem and what do you recommend to solve this problem?
Thanks.
