Hi team,
My customer is looking for PMIC for a 24V commercial vehicle EPS project. They would like to know whether TPS65381A-Q1 or other PMIC can be used for 24V system. Thanks
Hi team,
Hi Scarlett,
TPS65381A-Q1 can be used with input voltages up to 36V as can be found in the datasheet. Depending on their exact input and output needs TPS65381A-Q1 could work for them. If this PMIC does not work for them let me know and we can find another potential device.
Layne J
Hi Scarlett,
We do not currently have a 60V compatible device in this area, I would recommend using a pre-regulator is this is a desired input voltage. As long as the chosen pre-regulator voltage is within the minimum and maximum input voltage for TPS65381A-Q1 then this should be a good solution.
Layne J
