We have been testing out a bq24610 design and finding the devices are being damaged approximately 30 minutes after power up. The boards tested OK in production, but during assembly and calibration of the system the boards started to fail.
After removing the IC we found SRN and SRP has low impedance to ground (21 ohms versus 245K for correlation unit).
Since the SRN & SRP are connected to the output, it didn't' seem like ringing on the phase node would cause this damage.
Have you seen this failure mode before? Thank you, Keith
