TPS63070: pre-bias startup
Part Number: TPS63070
Hi Team,
Just want to check if TPS63070 can support pre-bias startup. And if there is pre-bias voltage on Vout, will it bring risk to the part?
Customer has application : 3.0-3.6V Vin to 3.56V Vout, Iout is 570mA. And due to startup sequence of the whole system, there will be 1.96V on Vout before the part power up.  Since datasheet seems has no such description, customer want to know if there is risk at such application. Thanks.
BRs
Given
