Part Number: LM10010EVM
Hi team,
This is the LM10010EVM board, the waveform captured by the P1 connector VIDC (8 pins).
and it's used to set the parameters of LM10010, please kindly help to check if there's any problem?
Hi team,
Hello Dane,
Let me forward this thread to the correct forum so you can get support.
Cheers,
Denislav
Hello Dane,
I will order the EVM and check this behavior.
What is the orange curve you measured here ?
Thank you,
Dorian
Hello Dane,
Do you have answer from the question above ?
I received the EVM today, I will start evaluation and come back to you early next week.
Thanks a lot!
Dorian
Hi Dorian,
Thanks, wait your test result
and customer think the EVM is broken will apply another one to have the test.
Hello Dane,
Can you tell me what was the configuration the customer was testing ?
The more information the better.
I indeed would not expect the VIDC waveform to behave like that, either this has a LOW or HIGH Logic state.
Thank you!
Dorian
Hello Dane,
Do you have any updates here ?
I haven't heard back from you.
Dorian
Hi Dorian,
They got a new EVM to do the test and I will check their test result.
any feedback will let you know. thanks!
