Hi Team,
Just want to check if the dual channel of TPS22976 has same charge pump driver or separate charge pump.
The block diagram in datasheet shows it seems from same charge pump, not sure if that's the real case. Thanks.
BRs
Given
Hi Team,
BRs
Given
Hi Given,
I believe there is one charge pump that has individual outputs for CH1 and CH2.
The device's channels can be individually controlled.
