Part Number: TPS2595
Other Parts Discussed in Thread: TPS22946, TLC59108
I am looking for a part like the TPS2595 but that I could use as a low-side switch. The most important features are the adjustable current limit, microcontroller-friendly enable, and thermal regulation. A low-side linear LED driver is more or less what I'm looking for, but most of what I have found tends to be lower current, less "smart", and requiring putting the load current through a sense resistor.
Is there any way to use the TPS2595 on the low side? Or, can you recommend another component that is designed for low-side use (either an LED driver or other current) of similar package size and functionality?
