Other Parts Discussed in Thread: BQSTUDIO, BQ78350
We have designed a battery pack + BMS based on reference TI Design TIDA-00792 but modified+dimensioned according to our application. In our design we use a battery pack of 14 series cells of 3,7V.
The cells used are from Yuntong supplier. In the list of Chemistry Programming cells of bqStudio, it doesn't appears (I've already updated these cell's list without success). So, at the moment I've choosen the most similar cell Chemistry ID that I've found.
I've seen the document SLVA725A - "Simple Guide to Chemical ID Selection Tool (GPC)". Initially I thought that it was intended for creating my own Chemistry ID, but as fas as I've finally understood it's more related for the gas gauging impedance track algorithm. In our case we are using CEDV.
Are there any way/procedure for creating my own Chemistry ID to be programmed? Or I've to continue developping with most similar chemistry ID that I've found for my cells.
Marco
