BQ24133: DSN. File
Part Number: BQ24133
Hi
Is there reference design of BQ24133 *.DSN file available, if yes can you please share the link
  • Hi Gareth,
    Unfortunately, this EVM's design files are not available.  We laying a board, I recommend not following the EVM layout.  Instead, I recommend placing the PVCC capacitors across the top of the IC.  This requires using vias down and back up to connect to the inductor, pushed further away from the IC, if on the same layer.
    Jeff
