Part Number: BQ24650EVM-639
Other Parts Discussed in Thread: BQ24650
Hi Team,
May we request for a 3D model/step file for BQ24650EVM-639 on behalf of our customer? This is needed for mechanical modeling.
Thanks in advance!
Kind Regards,
Jejomar
Hi Team,
Thanks in advance!
Kind Regards,
Jejomar
Hi Jeff,
Thank you very much looking into this. We may be able to share the volumetric dimensions of the board (LxWxH) in this case. Would it be the same with the actual PCB dimensions given on the user guide? Can you also help us with the mounting hole dimensions?
Kind Regards,
Jejomar
Hi Jejomar,
I do not think the dimensions in the user's guide are correct. There is a link to the board gerbers files below. You should be able to download a free gerber file viewer and get the information need:
Jeff
