Other Parts Discussed in Thread: TPS55340
Hi team,
A customer is looking for a boost converter to convert Li-Po voltage (3.6-4.2V) up to optimally 24V (min 18V) at optimally 1.5A (min 1A) for max 1 min at a time with very low repetition rate. Would this work with TPS611781? Telling from the efficiency diagrams in the datasheet it looks efficiency would be extremely low. But I can't find a better fitting boost either. Do you have an alternative solution?
Thank you,
Franz
