BQ76942EVM: Write All failed
Part Number: BQ76942EVM
Other Parts Discussed in Thread: BQ76942, BQSTUDIO
Hi team,
I am learning bq76942 to support customer with EVM. However, I found that the default configuration can not be write all, many default configuration beyond the minimum or maximum value. While the default configuration should be loaded through OTP, and the OTP should be blank, right? How could these default configuration be set? I did not set them before. Should the configuration be written all successfully until I set all the more than 200 parameters? It seems a little difficult for a beginner to set all the configuration.
Furthermore, I don't know the firmware well, does it include default configuration of data memory? Should I load it manually? Or the BQStudio would load it automatically?
