TPS65132: TPS65132 supports dynamic Vout on the fly?
Part Number: TPS65132
Hi sir,
    Can I change TPS65132 Vout in register while it's operating? Does it support DVS (dynamic voltage scaling) function?
  • Hi Alan,
    Yes you can change output voltage level while the device is operating by writing the appropriate register. I assume you mean the same thing of changing output voltage on the fly by dynamic voltage scaling. If so, then yes it supports it.
    Kind Regards,
    Liaqat
