BQ27441-G1: BQ27441-G1B Fuel gauge calibration
Part Number: BQ27441-G1
Other Parts Discussed in Thread: EV2400, BQSTUDIO
Hi Team, We are using bq27441-G1B part in one of our Low power design and want to measure minimum 500uA current, we are following document SLUA792 and are using the BQstudio tool , EV2400 (PC Interface Board). Below are the parameters we are using Paste table here. As we are multiplying the battery capacity, I am not able to understand how system will know the correct capacity and give correct readings.
We are using 100mE current sense resistor.
PARAMETER CLASS SUBCLASS STANDARD VALUE SCALED VALUE (STANDARD VALUE *10)
Taper Capacity (mAh) Configuration Charge Termination 45 450
Taper Rate (0.1 Hr Rate) Gas Gauging State 96 96
Chg Current Threshold Gas Gauging Current Thresholds 30 30
Dsg Current Threshold Gas Gauging Current Thresholds 2 2
Quit Current Threshold Gas Gauging Current Thresholds 23 23
Design Capacity (mAh) Gas Gauging State 470 4700
Design Energy (mWh) Gas Gauging State 1786 17860
V at Chg Term (mV) Chemistry Info Chem Data 4300 4300
Taper Voltage (mV) Chemistry Info Chem Data 4200 4200
