Other Parts Discussed in Thread: BQ76920, BQ76952, BQ76930, BQ76940, BQ78350, BQ34110, EV2400, BQSTUDIO, BQ76952EVM, TIDA-010030
Hi
I am designing a BMS and intend to use the IC BQ78350-R1A, already a very comprehensive technical reference has been provided and it helps a lot.
But, I have some questions regarding BQ78350-R1A and are as follows:
1. It is mentioned in the datasheet that they are compatible with AFE ICs like BQ76920,76930 and 76940, I want to know that are they compatible with other AFE ICs as well for example BQ76952.
2. It is mentioned in the datasheet that it is compatible with a battery pack with a capacity of 320000 mAh, but the companion AFEs are not compatible for that high current, please suggest a suitable AFE for realizing that capacity.
Thank You
