Other Parts Discussed in Thread: BQSTUDIO, EV2400
Hi TI Team,
I currently have some communication issue between host and 40z50 device. More specifically, I found that in some cases, 40z50 device may NACK the commend from the host. And once NACK happens, the next 2 same commends will be NACK as well. Then host will set alarm.
For example, host needs to read temperature. When it send 0x08, the device may NACK it. Then host will repeat sending 0x08 for another 2 times and the device may continue NACK those.
So can you please advise what may be the cause?
Additionally, once device NACK the commend, is there any "rest time" required for the device? For example, if the device NACK the 1st 0x08 commend, does host need to wait for certain period then send 2nd 0x08 commend to avoid continuous NACK from the device?
Zhihan
