Other Parts Discussed in Thread: BQ40Z50, EV2400, BQSTUDIO
I have a battery that I've designed and had another company program the registers using the BQ40Z50 but I've run into an issue. My circuitry doesn't have the dedicated pre-charge FET to handle pre-charging. Instead we were relying on using the charge FET to handle the pre-charge. The problem is, the company forgot to set FET Options [PCGH_COMM] = 1 so it's relying on a pre-charge that doesn't exist. The IC is set to full access but I'm not sure what command to actually send it in order to change this value to 0.
The documentation is pretty confusing so if I could get a hand I'd appreciate it.
