Part Number: BQ25703A
Hi sir/madam,
I have used this chip only to charge the battery with no system but regn value it is showing as 1.1v what may be the reason...
Hi sir/madam,
Hi Vinith,
REGN has a load limit of 60mA. Your IC could also be damaged. Remove and replace the IC.
thank you for the reply sir,
at the output of the circuit i am getting constant 13.4 even if i change the value in maxcharge voltage what may be the reason..and gate of mosfets are not switching....
and sir in my circuit I don't have a system ,vsys is connected to output of the buck boost circuit .
Hi Vinith,
What is the status of ChargeStatusRegister? You could be running into a fault condition that is disabling the charger.
