TPS2546: mode change behavior TPS2546 v.s. TPS2547
Part Number: TPS2546
Other Parts Discussed in Thread: TPS2547,
My customer has issue by TPS2547 during Transition from BC1.2 or Apple mode connection
--> then if difference TPS2547 disconnect VBUS -> then reconnect again.
From the user point of view, Charge rump is one shot turn off.  So Can you check This behavior will not happen on the TPS2546 or another devices?
I would like to promote TPS2546 instead of TPS2547.  Do you think TPS2546 do not turn off during power swap?
If TPS2546 do not work well, Do you have alternative proposal?
Hironori Yoshimura
