Other Parts Discussed in Thread: BQ40Z80, BQ34Z100
Hey, can I use BQ34Z100-G1 in standalone mode for gauging applications without using any AFE?
If so, what parameters (sensor data) are needed by BQ34Z100-G1??
Hi Prabhat,
No AFE is needed with bq34z100-g1. Check out our quickstart guide here: www.ti.com/.../sluubv2.pdf
Thanks for the quick reply.
I have one more question.
In the datasheet, it is mentioned that it
For my battery pack, I am expecting a peak discharge current of 250 Amps and a Charging current of 45 Amps. Can this gauge support in my design?
If so what are the changes I needed to make it work?
What is the difference between BQ34Z100 and BQ34Z100-G1?
In the datasheet of BQ34Z100, it is clearly mentioned that it supports a high current charge-discharge profile??
