Other Parts Discussed in Thread: BQ27421EVM-G1B
I have facing the same problem too.
This problem impacts the sleep current which should be according to spec <21uA but the actual is ~45uA.
I have the same connection as S.Satoshi. I have used your EVK with external power rail for pull up resistor of 3V.
The voltage of 3V is used because my host microcontroller has the same power rail (in my custom PCB)
Can you explain why sleep current is more than the spec current when external power is apply for SCL/SDA pull-up?
Eran
