Other Parts Discussed in Thread: LM5069,
Hi, I am going to use two parallel TPS26631 for my system.
I learned that using parallel TPS26631 from the this thread. https://e2e.ti.com/support/power-management/f/196/p/955040/3530866#3530866
In addition, I have some more questions about TPS26631.
1. Don't I need any schottky diode at VOUT? When using Hot swap IC, normally I used schottky diode for protection. (ex. LM5069)
2. I want to know how to set unused pins. I just want to use TPS26631 for simple load switch, So I don't need PGOOD or FET Blocking or Imonitoring.
In this case, can I set below pins as NC? or GND?
1. B_Gate
2. DRV
3. PGTH
4. PGOOD
5. FLT
6. IMON
Thanks.
