I have used TPS54302 in my below design.
Can you please check/verify my below design circuit and the layout and let me know if it is fine?
The above layout is referred from the user's guide of TPS54302 Evaluation Module.
TPS54302EVM-716 3-A Regulator Evaluation Module User's Guide (Rev. A)
Can you please clarify my below concerns
1.Is it okay to connect the SW trace through via (other layer) to inductor?
2.The trace width of the SW trace in between the capacitor C77 is 39mils, i.e. 1mm. Is the trace width enough for 3A output current?
Awaiting your reply.
Menaka
