Part Number: TPS53681
Hi E2E,
About DPS I have serval questions to consult:
1. With DPS and USR enabled, extra phases will suddenly add into loop, the interleaving order and number will suddenly change, any risk of: refreshed current sharing→ phase current inrush→ output voltage variation here?
And what is the typical delay time between USR triggered and more phase actived? Internal comparator delay+ blanking time between phases?
2. At load goes up, USR makes all phases in operation, but in new steady state, the running phase number may decrease to desired, due to present output current level.(it is the same if load goes down)
When phase drops in these two conditions, I know there's delay between dropping phases one by one, but @dropping timing, the same issue happens, interleaving order and number will suddenly change, any risk of phase current inrush/output voltage variation here, as what I already claimed in no.1?
