Hi
Out customer has problems with fuses and caps burning on power up. It seems that the input capacitors to the LM25011 for some reason shorts which in turn burns the fuse. The problem is very hard to reproduce, we have put a couple of cards in a testbench switching them on and off 4-5 times per minute and it can take almost a month before one of the testcards actually fails. The capacitors that burn are C218,C200,C201 and C207. Sometimes all of them are shorted and sometimes just 1 or 2 of them. It always seems to happen directly when you power up the card. We can't find an obvious solution or reason why this happens and would like some feedback on the design.
lm25011_power.pdf
