Other Parts Discussed in Thread: UCC27611
Could the driver be used to drive the top egan on a full bridge configuration. The input PWM signal is isolated from ground by a pulse tranformer and then fed to the input of the egan driver.
An isolated or a booth-strap supply will feed the driver.
I tred to simulate the driver with LTspice in a full bridge configuration without any success. Is there a reason for not being able to simulate the circuit?
No problem with the bottom egan transistors and driver, that is connected connected to circuit ground.
