BQ34Z100-G1: Field with IT Track Disabled
Part Number: BQ34Z100-G1
Other Parts Discussed in Thread: BQ34Z100
My BQ34Z100 is fielded in an application that may never achieve a successful learning cycle in field use.  The learning cycle will be interrupted by constant use (no rest periods between charge/discharge), lack of complete charging or charger profile does not match BQ34 data flash.
Under these circumstances is it better to not enable IT Track?  I am concerned that IT Track enabled may lead to improper learning if the learning cycle is erratic.
Steve
